Old 04-11-2012, 11:02 AM   #26
3MI Racing
Member#: 200987
yeah, I go further in and hit points not shown here.
I only dive that deep into the block for more extreme duty engines. I spend a couple hours doing it.
The touch up stuff for the oil pick up, Indiana plate area, oil filter area, etc are all pretty quick and easy to get too.
3MI Racing is offline   Reply With Quote
Old 04-12-2012, 02:05 PM   #27
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
This is a great post Ive been searching on what can help with the oiling issues we have. Keep the pictures coming!
Bamofo is offline   Reply With Quote
Old 04-13-2012, 02:59 PM   #28
JayMeagher
Member#: 187911
03 WRX
Redish
Have you guys taken numbered drill bits and plunge the galleys to see how "manufacturing" changes from day to day?
JayMeagher is offline   Reply With Quote
Old 04-14-2012, 12:54 AM   #29
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
This is my first Subaru block that I have done porting to, but it may be tough to measure some of the galleys because they are long tapers.
Crazykev is offline   Reply With Quote
Old 04-14-2012, 01:30 AM   #30
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I'm just starting my motor build I wish I knew exactly what I was looking at in those pictures. I have run out of money and will have some free days to port varoius things until I can collect more funds. Porting everything I possibly can has been my keep busy lately on this thing.
medamullet is offline   Reply With Quote
Old 04-14-2012, 01:54 PM   #31
col5555
Member#: 142017
Originally Posted by Crazykev View Post
Question for the engine builders:
I already sanded the sharp edges on the main bearing bridges that you see when looking into the cylinders, but has anyone ever thought of shaping those a bit? That air behind the cylinders is being pumped back and forth in the block and I was thinking that making them more aerodynamic would be beneficial possibly?
Something like knife edging a crank.
Check this link out http://forums.pelicanparts.com/911-e...main-webs.html
Some Porsche engines have mini scavange pumps in the heads to vacate the pooling oil.
col5555 is offline   Reply With Quote
Old 04-14-2012, 11:40 PM   #32
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Cool! This is EXACTLY what I was thinking of doing. I'm going to go ahead and do it.
Old 04-20-2012, 09:50 PM   #33
mboulton
Member#: 174433
What is the Indiana plate area??
Mel
mboulton is offline   Reply With Quote
Old 04-21-2012, 11:14 AM   #34
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I think he is refering to the chamber after the oil pickup tube.
Old 04-21-2012, 05:56 PM   #35
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Good stuff guys lets keep it going. I did most of the above to my wrx motor. Im building a motor for my Forester fxt and plan to do a mild job on it. I dont have any proven results but I feel that cleaning up the casting inside the oil return on block and heads. IMO a car that is built and tracked, autoxed, or some form of rally should deff do the oil return passages and the pick up point. Weekend warrior to the more serious...
Just my thoughts
rexworx is offline   Reply With Quote
Old 04-22-2012, 12:30 AM   #36
mboulton
Member#: 174433
after some searching around, I think the Indiana plate is the plate that you remove at the rear passenger side (USDM) to access the wrist pin and clip. Not sure what needs to be smoothed out back there though.
ideas?
Old 04-22-2012, 01:08 AM   #37
mboulton
Member#: 174433
thanks for the ideas CrazyKev. Just in the process of drilling my cam bolts off and then onto splitting the halves and cleaning up all the rough oil passages as so nicely outlined in above posts.
mel
Old 04-23-2012, 04:35 PM   #38
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
No problem. After I did the porting, I found out that it's semi-common?
Old 05-20-2012, 02:19 AM   #39
jesterjames
Member#: 252663
Chapter/Region: HIIC
Anybody got any pics of a ported oil pump?
jesterjames is offline   Reply With Quote
Old 05-20-2012, 03:00 AM   #40
B.R.E.D
Member#: 289606
06 WRX
white
I've got pictures I can try and dig up this weekend. I'm fairly certain I have pictures of Cosworths Pumps and our in house pumps.
B.R.E.D is offline   Reply With Quote
Old 05-20-2012, 12:12 PM   #41
B.R.E.D
Member#: 289606
06 WRX
white
Its more common for guys in the industry, its pretty uncommon for a do it yourselfer to do.
Its good info for the community regardless.
Old 05-21-2012, 12:04 AM   #42
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I'd love to these pics. It's all I have left to do.
Old 05-21-2012, 12:05 AM   #43
3MI Racing
Member#: 200987
I know I have some that I'd put up years ago under my Homemade WRX account. I'm not sure when I'll be 'cleaning' the next batch.
Old 05-21-2012, 12:26 AM   #44
B.R.E.D
Member#: 289606
06 WRX
white
Ill order one and port it this week and Ill document the process. Its something we sell but the process isn't a secret and if guys want to do it themselves that's fine with me.
Ill try and get something together by mid week.
Matt
Old 05-21-2012, 02:14 AM   #45
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Its not much. Just match the seal area on the pressure side and smooth out the intake. You should remove the gear cover and port some castings from in there as well. Takes about five mins. Need to shim it? Remove the allen key and add a washer to the bottom of the spring.
I would also check the plunger if its sticking. Deburr if necessary
Edit: here is a horrible diy someone did. If no one does a diy in a couple of days ill write one up for u.
http://flat4nc.com/forumnew/viewtopic.php?f=33&t=4122
wrxsubiemod is offline   Reply With Quote
Old 05-22-2012, 09:47 PM   #46
mboulton
Member#: 174433
Any updates? My burr is just itching to open up the oil pump outflow port, but I would love to see some examples from the pros first.
Old 05-22-2012, 09:56 PM   #47
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
I wish I took better pics, but I used a thin dremel attachment to port my oil pump. i might have one pic.
I was able to clean up the inlet and outlets to the rotor. As well as the o-ring port that mates up with the engine block. Oil pressure is amazing in my motor.
AdamBOMB_STi is offline   Reply With Quote
Old 05-22-2012, 10:11 PM   #48
smitty5788
Member#: 267886
2011 STI
I can post mine when I get home. Nothing special or different than already posted though. I haven't gotten to my pump yet but it's next on the list.
smitty5788 is offline   Reply With Quote
Old 05-22-2012, 11:23 PM   #49
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Well if my last post and link were useless ill be doing this tomorrow along with another thread.
Id honestly wouldn't attempt this if this is someones first try. I really don't see much that could be gained from porting the oil pump. I would actually advise everyone to just check the plunger operation for any sticking. That's it!
Your better off just buying the pump you need for your build and maybe modifying a few passages on your block.
Old 05-23-2012, 05:06 PM   #50
mboulton
Member#: 174433
I am confident that I can do it. But it never hurts to see what other people have done, so as to learn from their victories and follies.
Still eager to see.
FS : STL: Stock Oil Cooler, Exhaust Hanger, Oil Galley Plug, GBOD, etc. misc. ThreeEleven Engine/Power/Exhaust 5 03-31-2011 04:17 PM
Oil galley plug leak? Or crush gaskets on oil sending line? eodtech Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-04-2008 12:26 PM
For sale Gc8 tapped oil pan, for turbo kit, with SS lines and oil galley tap felixwankel88 Engine/Power/Exhaust 4 01-29-2007 06:31 PM
WTB: Oil galley plug for oil sensor. 04RCSTI Private 'Wanted' Classifieds 4 07-19-2006 04:37 PM
Subaru OEM Oil Galley Adapter for oil pressure gauge 02BlueSuperRoo Private 'For Sale' Classifieds 4 12-14-2005 01:34 AM
