Old 05-23-2012, 06:27 PM   #51
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by mboulton View Post
What is the Indiana plate area??
Mel
after some searching around, I think the Indiana plate is the plate that you remove at the rear passenger side (USDM) to access the wrist pin and clip. Not sure what needs to be smoothed out back there though.
That's the one.
I just debur, radius some edges and do some opening up.
Old 05-23-2012, 07:47 PM   #52
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I'm actually doing this now so I'll update this in a min but here is a pic of what you need to port and smooth out. Arrows pointing right at them lol
wrxsubiemod is offline   Reply With Quote
Old 05-23-2012, 07:52 PM   #53
mboulton
Member#: 174433
Ah thanks! I was starting to think I was slowly going insane and seeing shapes of faces in oil blotches. Haha I even googled an image of Indiana and compared it to the plate. I fell better knowing this.
Canadian eh? Gotta learn my US state geography and EJ257b anatomy.
mboulton is offline   Reply With Quote
Old 05-23-2012, 09:35 PM   #54
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Before
After
bypass and inlet area removed of restrictions. steps removed that impeded flow
gear area smoothed out
exit hole enlarged to match seal area and radiused
gear area knive edged on the exit and tapered into
this takes a steady hand and I will caution everyone to be careful! dont run with scissors..
Old 05-23-2012, 09:43 PM   #55
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Looks good! Definitely going to do this to my pump when I pull the motor out
alcoolaid is offline   Reply With Quote
Old 05-23-2012, 09:57 PM   #56
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
This is my P&L ported 11mm pump for you guys to reference.
Kind of crappy pics but you get the idea. I plan on porting a couple of the passages on my block at some point. I know I bought that die grinder for a reason more than just my TGV's.
RicersWetDream is offline   Reply With Quote
Old 05-23-2012, 10:06 PM   #57
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I would actually stay away from the bypass area^^
One little burr or sharp edge and that plungers sticking..
As mentioned, very sensitive work
Old 05-23-2012, 11:52 PM   #58
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Thanks for the pictures guys! Going to do this for sure and I agree wrxsubiemod, I am going to just de-burr the bypass area. Not sure what the gains would be screwing with the bypass anyhow? Possibly help with not not heating the bypassed oil up?
I'll post pics when I do my pump, but it is going to be a while. I haven't ordered my pump yet. I just replaced mine about 8k ago and might just use it if I don't find any crap in the motor when I go to do my swap. I haven't had any type of failure with my current engine, so it should be ok. It's an 11mm pump and I don't want to get a new one if there is nothing wrong with this one on my current block.
I am going to replace the cooler because I have no way to inspect it. The pump on the other hand can be inspected and cleaned.
Crazykev is offline   Reply With Quote
Old 05-24-2012, 12:08 AM   #59
smitty5788
Member#: 267886
2011 STI
Some pics of my block. Nothing different that what has already been posted.
smitty5788 is offline   Reply With Quote
Old 05-24-2012, 12:24 AM   #60
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Make sure you DO NOT open up the port going into the block from the oil pickup. Increasing that diameter or adding a radius to that surface can cause the o-ring to not seal properly and you will suck air. This area is also not even close to being a restriction and there's no reason to touch it.
KillerBMotorsport is offline   Reply With Quote
Old 05-24-2012, 01:43 AM   #61
Homemade WRX
Member#: 33782
96 bastard child
I would certainly hope that anyone doing any porting on the oil pump would have it completely disassembled and cleaned before even thinking about putting it into use.
Old 05-24-2012, 01:52 AM   #62
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^ I agree, and can not stress enough how careful one needs to be with the oil pump.
How many oem pumps fail on start up? How well can someone trust themselves to do a better job than OEM?
Old 05-24-2012, 07:02 PM   #63
mboulton
Member#: 174433
A beautiful thing. Thanks to everyone for sharing.
Old 05-24-2012, 11:51 PM   #64
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I thought that was a bad place to mess with. I didn't touch the pick-up side of that port, just the other end at the pump. I figured it needed to be left alone, plus the pick-uptube slides into that port, so enlarging it would do nothing.
Old 06-04-2012, 02:36 PM   #65
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Any updates and or pics from anyone? I havent had time but should do a lil work on my FXT block halves before everything goes in... Also thinking about doing a lil work on my 11mm oil pump.
Thanks
Ian,
rexworx is offline   Reply With Quote
Old 06-04-2012, 07:32 PM   #66
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Hey smitty5788, I am just pointing this out so if you haven't done it, you can, but the port from the pump to the block really needs to be radiused the opposite way that you did. The port to the block split goes nowhere and is blocked off and is only there so they can machine the galley to the oil filter. You need the other side to flow better being that the oil is flowing to the filter if you catch what I'm saying? I radiused both, but the side leading to the filter is radiused MUCH more than the other way going to the split.
Old 06-06-2012, 09:41 AM   #67
StandardSti
Member#: 171471
2002 35r wrx
The 11mm oil pump by the by pass area is really thin in the first place, I wouldn't even touch it with a porting bit, maybe polish it up that is it. The first 11mm pump we started to port on, and it as very light! We blew through the wall on it. SO just a little warning.
I have done a ton of block porting, What I found is just keep it simple and don't get porting happy.
The pick up tube area Just radius the flat edges and then leave the pick up hole alone.
The other side of the block "oil pump o ring area" port the bump out of the block. o ring match it as well. Then I take all of the oil hole ridges and smooth every hole, head matting side too.
Radius the oil filter side and open it up Just as CrazyKev posted..
I all ways run Subaru oem 11mm oil pump they are plenty for just about every car even high horse power. 12mm pump have there issues , and if you are running a 12mm check how tight the pump gear cover bolts are, I have seen them lose right out of the box.
StandardSti is offline   Reply With Quote
Old 06-06-2012, 10:03 AM   #68
rexworx
Member#: 103232
GTX 3071R'd 11WRX
^^^Thanks Shaun!!!^^^
Old 06-08-2012, 12:50 AM   #69
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Well I did most of all my work above to the block im building for the fxt. I was looking at the through the machined hole in the bearing journal. I could see the machining didnt go all the way through to the oil galley that feeds them. The hole is machined to around 1/4", but the casting hole is only about 1/8-3/16" on #3 and #5.
I really want to just punch them out to 1/4" with a drill bit. Anyone doing this?
Thanks,
Ian,
Old 06-08-2012, 08:02 AM   #70
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I can say I haven't enlarged any of the galleys, just really smoothed them out and got rid of steps. Not saying it would be a bad idea, but I just don't know?
Old 06-08-2012, 09:10 AM   #71
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Yeah I cant see it being a bad thing... If you look into the hole on the bearing journal you will see the casting imperfections at the bottom of teh hole right where oil makes a 90* turn.
Im not too good at explaining things sometimes sorry.
Old 06-08-2012, 09:12 AM   #72
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Originally Posted by JayMeagher View Post
Have you guys taken numbered drill bits and plunge the galleys to see how "manufacturing" changes from day to day?
Im rather interseted in the casting changes they have.
Old 06-08-2012, 09:30 AM   #73
Samurai Jack
Member#: 21145
2002 Enemy of Aku
subscribing for future project
Samurai Jack is offline   Reply With Quote
Old 06-08-2012, 09:32 PM   #74
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Well I opened up the holes in the casting where the machined holes feed the journal bearings. I used a 1/4 drill bit and opened up the bottom of the hole to match the machined size. Sorry Im terrible at explaining things. does thats make sense at all?
Now that a have done it I fear I effed up big time and shouldnt have touched them. Maybe subaru did this for a reason? I assume no but Im trembling non the less.
So anyone, Was this a really bad idea? I know I should have taken the time to reasearch this more before I did it. I dont know what I was thinking.
Old 06-09-2012, 10:56 AM   #75
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Well from what I can see, DO NOT open up the restricters. Dont be a dbag like me!
FS : STL: Stock Oil Cooler, Exhaust Hanger, Oil Galley Plug, GBOD, etc. misc. ThreeEleven Engine/Power/Exhaust 5 03-31-2011 04:17 PM
Oil galley plug leak? Or crush gaskets on oil sending line? eodtech Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-04-2008 12:26 PM
For sale Gc8 tapped oil pan, for turbo kit, with SS lines and oil galley tap felixwankel88 Engine/Power/Exhaust 4 01-29-2007 06:31 PM
WTB: Oil galley plug for oil sensor. 04RCSTI Private 'Wanted' Classifieds 4 07-19-2006 04:37 PM
Subaru OEM Oil Galley Adapter for oil pressure gauge 02BlueSuperRoo Private 'For Sale' Classifieds 4 12-14-2005 01:34 AM
