Old 02-07-2014, 04:05 PM   #126
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
Finally getting off my butt and gathering parts to get my motor back together! Sponsors welcomed! lol
AdamBOMB_STi is offline   Reply With Quote
Old 02-08-2014, 01:34 PM   #127
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I just wanted to give a little update while this thread is back from the dead. My build has about 21,000 miles on it. Still running strong. Knocks on wood...
04 sti single avcs built EJ257 "04 forester xt"
Mains .0015", Rods .0018" Edited as I missed a zero 0"
Castrol GTX 10w-40 non synthetic
11mm ported with 3 shims total
Oil Galley porting and cleaned up returns to pan
AEM digital oil pressure gauge 0-150psi Sensor placed in the oil galley plug next to the PCV bung/coolant crossover pipe
95-101psi Cold startup @ idle 1500rpm
22-30psi hot idle @ 850rpm
40-45psi hot @ 1500rpm
55-70psi hot @ 2000-6000rpm
70+psi hot @ 7000+rpm.
Id like to see if swapping in a ported shimmed 10mm pump might give me more oil pressure in the higher rpm range.
I know it would help if I had a oil temp gauge so I could be more specific with my readings. Thats next on my gauge list...
rexworx is offline   Reply With Quote
Old 02-08-2014, 09:37 PM   #128
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
70psi sounds a little low at that rpm range. I would be shooting for at least 80-90 as when things get really hot the pressure can drop 10-20psi easily
alcoolaid is offline   Reply With Quote
Old 02-08-2014, 10:17 PM   #129
AdamBOMB_STi
Member#: 103419
04.7 STi
What oil are you guys running?
Old 02-09-2014, 12:57 AM   #130
alcoolaid
Member#: 134949
'07 SWP STi
M1 15w50
Old 02-09-2014, 01:11 AM   #131
AdamBOMB_STi
Member#: 103419
04.7 STi
Sweet. I usually run valvoline vr1 20w50
Old 02-12-2014, 08:51 AM   #132
rexworx
Member#: 103232
I agree. I see no change when the oil is "really hot" though. I also admit that I havent had the car on the tract for 20-30 minutes either. just some autox etc. not near the same...
Old 03-16-2014, 03:48 PM   #133
Scargod
Member#: 260314
2008 STI hatch
Default My take on pump shimming
Originally Posted by Crystal_Imprezav View Post
Also, you should NOT be just throwing shims in based on your "gut" feeling and "design". You need to measure the spring pressure and adjust shims as necessary to meet the spec. The exact same way you would test a valve spring... There IS a reason some OEM factory pumps come with no shims, one shim, two shims, and etc.
I agree. Even when you get a new pump there are different manufacturers, different castings, different tolerances and human error that comes into play.
Spring pressure should be measured. I haven't heard a single person mention compressed, installed length and/or a spring pressure. Nor have I heard anything but "stock shim" mentioned. I'm guessing they have a number of combinations of shims to choose from when doing assembly and that someone is doing QC to maintain consistent results. I'm hearing people say that it does matter whether you add one or two shims. This means that +/- a half-thickness shim might be best.
Since this thread is titled oil galley porting I'd like to ask a question related to oil galleries. Is there an alternate place I could take oil out of the engine? Also, where could I return it? I'm trying to get away from oil lines around the headers. I already use an external filter, cooler and Accusump. Is it possible to block off the oil filter ports and route it somewhere else? I'm up for drilling and tapping, machining or welding to accomplish this.
Scargod is offline   Reply With Quote
Old 01-02-2016, 09:49 AM   #134
rexworx
Member#: 103232
Another update. I have about 65,000 miles on the engine. I DDd it for a few years but I have a 11 hatch for DD use now. I have done oil tests with Blackstone labs. All wear metals seem great. I will admit I have beaten the snot out of this engine. Im rather happy with the results so far.
Mains .0015", Rods .0018" "Edited as I missed a zero"
Old 03-11-2016, 09:52 PM   #135
AdamBOMB_STi
Member#: 103419
04.7 STi
Awesome!
Old 03-15-2016, 06:23 PM   #136
wrx1392
Member#: 342331
2003 wrx
blue
Originally Posted by fastblueufo View Post
Another oil mod is on the main bearing journals. I know with acl bearings the oil feed hole on #2 and #4 mains don't line up with the feed hole in the bearing. You can reshape the feed hole in the main to match the hole in the bearing. #1, #3, and #5 oil feed holes in the mains are slightly larger and line up pretty good. Plus there is the oil valley that carries oil to the other side of the bearing. The #2 and #4 bearings don't have this valley. On my ej22t block the hole in the main and the hole in the bearing were offset by as much as 1/3 the size of the hole in the bearing. I will post pics later today when I get home from work.
I noticed this too when I built my last motor (#3) I thought the new King Bearing were wrong ...I looked at my old bearings (ACL) and you could see the impression on the back of the bearing shell .So I "ported " the back of the bearing shell a bit so it lined up better . the two previous motor failed from bearing issues . I also am using a 11mm STI pump with one shim added . runs down the freeway at 82 psi using Rotella T-6 oil.
wrx1392 is offline   Reply With Quote
Old 03-15-2016, 08:59 PM   #137
Scargod
Member#: 260314
2008 STI hatch
Originally Posted by wrx1392 View Post
I noticed this too when I built my last motor (#3) I thought the new King Bearing were wrong ...I looked at my old bearings (ALC) and you could see the impression on the back of the bearing shell .So I "ported " the back of the bearing shell a bit so it lined up better . the two previous motor failed from bearing issues . I also am using a 11mm STI pump with one shim added . runs down the freeway at 82 psi using Rotella T-6 oil.
Is this specific to EJ22 cases or which ones? A range of cases to be concerned about? I've had two EJ25* cases prepped recently, which means they sized the bearings to the cranks, and they never said anything about any mismatch or modding.
Old 03-15-2016, 10:39 PM   #138
wrx1392
Member#: 342331
2003 wrx
blue
mine is a 2003 2.0 EJ20 .I mean there is enough hole match to feed the bearings for a stock motor, but after having 2 motor go out ,one spun a bearing after 450 miles and the other went 30,000 before #2 & #4 fatigued bearings ...both times it was my fault ,but this time I just did not want to take any chances. maybe the factory does it that way to restrict the flow or a better word to meter the flow, in my bear package from King they had a picture of a "new" bearing that had way different shaped holes/slots for getting the oil up from the case. ill see if I can post a pic.
FS : STL: Stock Oil Cooler, Exhaust Hanger, Oil Galley Plug, GBOD, etc. misc. ThreeEleven Engine/Power/Exhaust 5 03-31-2011 03:17 PM
Oil galley plug leak? Or crush gaskets on oil sending line? eodtech Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-04-2008 11:26 AM
For sale Gc8 tapped oil pan, for turbo kit, with SS lines and oil galley tap felixwankel88 Engine/Power/Exhaust 4 01-29-2007 05:31 PM
WTB: Oil galley plug for oil sensor. 04RCSTI Private 'Wanted' Classifieds 4 07-19-2006 03:37 PM
Subaru OEM Oil Galley Adapter for oil pressure gauge 02BlueSuperRoo Private 'For Sale' Classifieds 4 12-14-2005 12:34 AM
