Old 09-05-2011, 11:37 PM   #1
LiveAloha
Member#: 289286
2007 Wrx Sti
Default how do you keep the underside of the car from corrosion?
Whats a good way to keep the under side maintained and corrosion free? Any good cleaning solutions that you might wanna give a tip on?
LiveAloha is offline   Reply With Quote
Old 09-06-2011, 12:35 AM   #2
sars101
Member#: 280420
2005 2.5 rs
silver ish
undercoating?
sars101 is offline   Reply With Quote
Old 09-06-2011, 08:43 PM   #3
vend
Member#: 215767
When I lived in Hawaii, we just sprayed water at the end of each day under the car to wash off the crap from the road; worked for us
vend is offline   Reply With Quote
Old 09-06-2011, 09:20 PM   #4
jxkim
Member#: 239150
2003 WRX Sedan
an issue for anyone living in snowy areas... go to self car wash and use their water gun to spray/clean the salt
jxkim is offline   Reply With Quote
Old 09-06-2011, 10:04 PM   #5
Ct Drummer
Member#: 256749
2013 XV Crosstrek
Dark Grey Metallic
I do this, and every couple of weeks I bring a set of ramps with me.
I put the fronts on ramps and I spray the underside out really well.
Mike
Ct Drummer is offline   Reply With Quote
Old 09-12-2011, 02:18 PM   #6
JJay03
Member#: 279061
98 Legacy GT
Spraying it off at the car wash helps for sure. I know Mikes car wash has some undercarriage spray that suppose to help with corrosion.
JJay03 is offline   Reply With Quote
Old 09-14-2011, 10:36 AM   #7
theSTIgdrivesanSTI
Member#: 294359
1993 MX5 Miata
Red, BCs, Hard top, C1Ms
Usually any tunnel carwash has an undercarriage spray. Its usually a wax like coasting that seals up and stops anything from rusting.
theSTIgdrivesanSTI is offline   Reply With Quote
Old 09-20-2011, 02:46 PM   #8
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
If the weather isn't freezing, I use my lawn sprinkler. Just slide it under and move it around. Winter, I have access to a wash bay with hot water. RP
drivin blind is offline   Reply With Quote
Old 09-20-2011, 02:48 PM   #9
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
when you go to a car wash make sure you get the underbody wash it helps alot
fmars62 is offline   Reply With Quote
Old 09-26-2011, 11:14 PM   #10
elow07
Member#: 131539
02 wrx
BLUE
The one thing you have to worry about if you are gonna undercoat is over spray. Any little wind and you will end up with black little dots all over your car. I have seen it happen to a lot of guys. BUT if you can pull it off, it will seal up a lof of cracks and keep it looking nice.
elow07 is offline   Reply With Quote
Old 09-27-2011, 11:59 PM   #11
thegad
Member#: 292307
2004 Impreza WRX
I wish the previouse owner of my car would have taken better car of the underside. ALL my heat shielding is rusted reallllyyy bad. in some spots the shields are only held on by like one screw because the others have rusted through!
thegad is offline   Reply With Quote
Old 09-29-2011, 08:27 PM   #12
celer
Member#: 10706
2005 STI
So I lived in Virginia and would drive my STi back and forth skiing all the time. A about 2 years ago I tried an experiment and sprayed LPS3 on some of the rusty bits underneath, specifically the frame bits that connect to the sub-frame - I only did this on one side to see what would happen, on other rusty bits of the frame I smeared anti-seize grease.
(My STi is pretty rusty for such a new car.)
So after 2 years the results are in, the LPS3 kept things on one side from rusting much at all, and so did the anti-seize grease. The stuff that was treated this way stopped rusting compared to the stuff that wasn't rusting or that was not yet rusty. On the side where I didn't treat stuff the rust had spread.
Now I'm slowly going through the car and wire wheeling the rusty stuff and painting it with Chasis-Saver.
The only regret I have about using anti-seize grease and LPS3 this way is that it is a real pain to remove later. When I pulled the sub-frame and repainted it I had a heck of a time getting it off and had to resort to brake cleaner, etc.
The other lesson I learned with this car is to be VERY careful about how I clean the engine bay. Sadly my usual method was to use some engine-cleaner in a can and spray down the engine, let it sit, use a gentle brush and then hose it off with water and let it dry - Well I believe that I should have followed this with some sort of engine dressing or something else - as all the fasteners on the motor are pretty rusty now, and anything that was a bright yellow zinc is now oxidised and a dull grey.
celer is offline   Reply With Quote
Old 11-18-2011, 09:56 AM   #13
04wrxcarl
Member#: 300489
I live in michigan and this is always an issue to think about. Im planing on using a rubberised undercoating. And also cleaning every 2 weeks or so. I wouldnt want to do it but ive heard of an old school tecnique of spraying old engine oil all over the underside of your car. after winter spray it off real well. LOL but i cant bring my self to do it and it would suck if you had to work on it at all. LOL
04wrxcarl is offline   Reply With Quote
Old 11-18-2011, 10:19 AM   #14
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
Dorothy from OZ, the XT
I see you're location is Ft Drum. I hate to be the bearer of bad news, but your seasons of 4 months of non-winter and the rest of the year winter really does suck for our cars. Mine spent one winter up there and I drove it through touchless car washes all the time but it didn't do that much to really help. There is no corrosion on the body, but all of the suspension components paid the price. From now on, removing anything can be a pain, also I had a caliper freeze/ stick from corrosion on the sliding pins. With that said, undercoating won't really help prevent the suspension from rusting out. Also, what unit at Drum?
340Duster is offline   Reply With Quote
Old 11-18-2011, 10:33 AM   #15
phate1229
Member#: 173615
2015 WRX Limited
In addition to what everyone else says about spraying it down I take a couple extra minutes every time I have the car up on jackstands to look for anything that may be starting to rust. Anything that's relatively easy to remove I pull it off wire wheel the rust and repaint it. Bigger things (such as my front subframe which I need to do before it snows) I just make a note of.
phate1229 is offline   Reply With Quote
Old 11-18-2011, 10:37 AM   #16
KJohnston
Member#: 301046
2010 Legacy
Definitely need to spray the underside at the car wash if you live in an area that uses salt!
KJohnston is offline   Reply With Quote
Old 11-18-2011, 11:44 AM   #17
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
oil undercoat. use a good bar-chain lube/oil. don't cheap out (not all that expensive in the first place) and read the label for it's composition. i would recommend husqvarna w/high adhesiveness, high oiliness, high film strength, and of course, anti-rust.
doylfish is offline   Reply With Quote
Old 11-23-2011, 12:29 PM   #18
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
Good thread. I'm definitely planning on regular spray downs, but I was wondering if anyone had any opinions on places like Ziebart and the like as far as undercoating is concerned?
I just finished a with a fresh coat of Collinite 885 on all of the body panels so I think I'll be good for a bit there.
bigmaninjapan is offline   Reply With Quote
Old 11-23-2011, 09:45 PM   #19
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
good ole wd-40.
scby rex is offline   Reply With Quote
Old 11-24-2011, 12:52 AM   #20
BraveSTi
Member#: 262030
I never drive it when its wet outside..I'll walk
BraveSTi is offline   Reply With Quote
Old 11-28-2011, 04:06 PM   #21
zmi
Member#: 237221
2003 Hybrid VF39 E85
PDX WRX PSM Wagon
Default Wurth underbody seal
Get the car safely up in the air after you spray it down and with good light inspect the undercarriage. Then use a wire brush and scratch the loose rust off. Apply some Wurth underbody seal. http://www.wurthusa.com/project/en/l.../chemical.html I reapply as needed. 150k in Midwest IL. and no major rot.
PS. be sure not to plug the drain holes!
zmi is offline   Reply With Quote
Old 11-28-2011, 06:10 PM   #22
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Self-serve carwash during the winter months to get the undercarriage of the car relatively clean.
I use Boeshield T-9 on everything except for the bushings two to three times a year. It has a wax in it that dries and provides a limited protective coating - limited because it must be reapplied after a few months, but it does work.
http://boeshield.com/
Old 11-28-2011, 11:58 PM   #23
The Wind
Member#: 195722
2005 Saab 92X Aero
Arctic Silver
Take a look at a product called fluid film. I just applied some of it on my 92X and it seems to be holding up pretty well with all of the weather we have been having here in Ohio.
The Wind is offline   Reply With Quote
Old 11-29-2011, 12:20 PM   #24
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
Holy hell. I love me some T-9 as my goto chain lube on my bikes (their 200 mile claim is dubious imho), but at $120 per gallon I'd be looking elsewhere.
Old 11-29-2011, 01:05 PM   #25
blue-sun
Member#: 15934
Where are you buying it at? My in laws live in LaSalle County (Marseilles) so I'd be interested in picking some up for my car.
blue-sun is offline   Reply With Quote
How badly is the underside of your car rusted? aod Off-Topic 48 05-13-2008 05:19 PM
how do you keep cats out of houseplants? incorporeal Off-Topic 39 02-02-2006 07:34 AM
How do you clean puke out of the seat? EddieC168 Newbies & FAQs 10 03-26-2002 01:18 PM
Advise needed - How do you keep from speeding? 8Complex General Forum Archive 34 07-04-2000 10:37 PM
