Old 09-06-2011, 07:09 PM   #1
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Question DAM question
Just last week I reflashed to Stage 2 since I realized that I had not loaded the map as my base map, just a realtime map. Everything was fine previously, but now a week later I notice that my DAM is still at 15. This was at 16 before the reload, so my question is, how long SHOULD it take to reach 16? I checked after the flash and it moved from 12 to 15 within 5-10 minutes. Now it has been a week and it is not there yet. Everything runs fine. Just looking for some knowledge here. Thanks in advance.
WRXSD is offline   Reply With Quote
Old 09-08-2011, 04:42 PM   #2
Cobb Tuning
Member#: 4803
It shouldn't take too long depending on the type of driving. However, these maps generally have an initial value for the DAM of 12 (factory map is 8). If you are showing 15, this means that the ECU attempted to ramp up to 16, but saw some knock and settled on 15. The initial step for the DAM is 4 and then it is reduced by half for each direction change. So, DAM = 12, 16 (knock), 14 (no knock), 15 (done).
Do you have an AccessPORT version 2 (color screen) or version 1?
Bill
Old 09-09-2011, 11:26 AM   #3
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Bill-
Thanks for the reply. I have the latest version of the AP with the color screen. I did pull the battery terminal on wed evening to reset the parameters and the DAM was at 16 within 15 miles, which was the first time I checked it. I have seen some knock at low rpm city driving which I have seen you post as normal, and remember sitting in some morning traffic after that map load that I had mentioned in my op. I will try to post a few 3rd gear pulls when I get a chance to do some logging for verification.
Thanks again.
Too fatty or not too fatty: That is the question The Motel Fella Off-Topic 17 09-06-2011 02:53 PM
differential question LoneDubR Transmission (AT/MT) & Driveline 4 09-06-2011 02:26 PM
question about exhaust matthewsmithwp Newbies & FAQs 6 09-06-2011 01:56 PM
Dynamic Advance / DAM Question Mystery Machine AccessPort 2 10-07-2009 09:13 AM
dam newbie bov question URABUSx714 Newbies & FAQs 2 11-04-2002 02:55 AM
