Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 08-01-2002, 12:05 PM   #1
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Default My car passed Ontario’s ‘Drive Clean’ emissions testing.
No-load 2500-RPM Test –
HC (ppm) Limit 150: 10
CO (%) Limit 0.70: 0.00
Tested RPM: 2414
Idle Test –
HC (ppm) Limit 150: 86
Tested RPM: 735
That’s with all my mods left alone including the Cobb hi-flo catalytic converter and the supercharger belt driven, as normal. But I had to reset my ECU prior to testing; the test fails if that pesky CE light stays on. After three days or so, that CE light will come back on, but that’s of as long as it’s off during testing. The ECU must be more nitpicky.
Whew!
Is it possible to run with no detectable carbon monoxide (CO) emissions?
Regards,
Ed.
edekker is offline   Reply With Quote
Old 08-01-2002, 12:11 PM   #2
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
That's hilarious...... you have a full modified car (supercharged) and it easily passed it.....
No wonder the failure grade is about 3% of cars......
I'd laugh if my 1992 Mazda 323 with 261kms passes..... but it only needs to be tested next August 2003.....
Robin
Robin2 is offline   Reply With Quote
Old 08-01-2002, 12:43 PM   #3
Skeandhu
Member#: 1056
Ed:
How did they test the car? I know they can't really dyno it, so do they just rev the engine or what?? If you're coming to the meet tonight, I'll find out then...
My car is due next year (me thinks), but if Ed's passed, then I doubt I will have a problem.
Skeandhu is offline   Reply With Quote
Old 08-01-2002, 01:02 PM   #4
edekker
Member#: 143
1999 Impreza 2.5RS
AWD cars are tested under two-speed no-load (free-reving, no dyno) runs; one at idle and one at 2500 RPM.
Odd-yeared cars are tested on even-years. A '99, for example, gets tested this, an even-numbered year.
Ed.
Old 08-01-2002, 02:25 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Ed.
Not my 99RS.... I squeeked in before the E-testing starts.... so I ended up getting the 2 years of stickers, so I won't be e-tested till May 2004.....
Robin
Will my car pass air emission test in upstate NY? txl146 Tri-State Area Forum 0 02-26-2005 11:01 PM
Hell yeah...my car passed emissions Impreza Rider Mid Atlantic Impreza Club -- MAIC 14 07-24-2004 02:57 AM
My car passed emissions with flying colors!!!! VSM EXtasy Mid Atlantic Impreza Club -- MAIC 3 03-29-2003 03:51 AM
Will my car pass emissions? WRXnFX Alaskan Impreza Club Forum -- AKIC 45 10-06-2002 06:41 PM
My car passed Ontario’s ‘Drive Clean’ emissions testing. edekker Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-04-2002 09:31 PM
