Old 09-07-2011, 05:41 AM   #1
NJ_wrx
Member#: 268855
2009 WRX
red
Default Adjustable or non-adjustable sway bars. What's the skinny?
I have an 09 WRX and I'm going to upgrade the suspension and was curious if there's a preference. A friend of mine is telling me to go with non-adjustable because according to him they're more sturdier than the adjustable offerings. My car is a DD and will never see any kind of rallying, fwiw.
Thanks,
Izzy
NJ_wrx is offline   Reply With Quote
Old 09-07-2011, 06:15 AM   #2
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
I don't think they are sturdier by any measureable amount. Adjustable swaybars are more expensive, but allow for more "fine tuning". If you don't think you will ever want to mess around with the swaybar's settings, then go for the non-adjustable. If you can't say for certain, get the adjustable just in case.
T WRX rawr is offline   Reply With Quote
Old 09-07-2011, 09:43 AM   #3
bako
Member#: 226211
2002 impreza WRX JDM
blue
get adjustable for sure
bako is offline   Reply With Quote
Old 09-07-2011, 02:05 PM   #4
NJ_wrx
Member#: 268855
2009 WRX
red
Thanks for tips. I think I'll go with the PERRIN adjustable sway bars.
respectfully,
Izzy
Old 09-07-2011, 05:58 PM   #5
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Keep in mind that for adjustables that have 2 holes (like the front bars), then you will either be a little stiffer or softer than the non-adjustable version.
IE, a front 22mm not adjustable has one setting: 22mm. The front 22mm adjustable has two settings: 21.5mm and 22.5mm (estimations). That means you can't ever get 22mm out of this bar, but you can get a little stiffer and a little softer.
The rear adjustables tend to have 3 holes, which equate to 21/22/23mm with the middle hole being equivalent to the nonadjustable version.
chimchimm5 is offline   Reply With Quote
Home Refiancing - What's the skinny? Sharkbait Off-Topic 68 03-30-2009 02:46 PM
adjustable or non-adjustable kevpotts Brakes, Steering & Suspension 7 06-04-2008 07:46 PM
What's the Skinny on the Crowbarn<sp>???? The_Triton Off-Topic 24 07-02-2004 05:52 PM
Any reviews of 22mm front and 22mm adjustable rear Cusco sway bars for the Sti whiteguyblacksti Brakes, Steering & Suspension 1 04-23-2004 02:48 AM
What's the skinny on water injection in a turbo engine? Digital_Boy Technical Forum Archive 5 08-26-2000 12:08 AM
