North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 01-05-2013, 04:05 AM   #3351
WhiteGirl
Member#: 311153
2006 Legacy GT
Satin White
Nice job wonder what my LGT would look like wit the roof blacked out?
WhiteGirl is offline   Reply With Quote
Old 01-05-2013, 03:14 PM   #3352
AnointedDrummer
Member#: 165617
2007 sold:(STAGE2WRX
Blur of UrbanGreyMetallic
I Got My Car back!!!
After weeks in the shop (nasty pics here) I can drive a real car again.
Got it back on NewYears Eve.... and almost got several hundred dollars worth of tickets... long, but funny, story....
AnointedDrummer is offline   Reply With Quote
Old 01-05-2013, 04:02 PM   #3353
guilty_619
Member#: 244075
2015 Honda Fit 6MT
'54 WILLYS CJ3B
Finally replaced my stock 5 1/2 year old battery. Didn't drive my car for two weeks and it stopped holding a charge. Went to Batteries+plus and got myself a 550 cca Rayovac (re-branded Deka) on sale for $79 with 2 year warranty. Much better than the stock 360 cca Panasonic.
guilty_619 is offline   Reply With Quote
Old 01-05-2013, 06:43 PM   #3354
02silverbugeye
Member#: 269220
BLAZE YELLOW
installed my new hid morette headlights
02silverbugeye is offline   Reply With Quote
Old 01-05-2013, 10:50 PM   #3355
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Subie_Noob_Brian is offline   Reply With Quote
Old 01-06-2013, 12:38 AM   #3356
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Got the motor in the wifes legacy torn down to get ready to pull it tomorrow and replace head gaskets among other things, not a ton a fun by yourself
imac6471 is offline   Reply With Quote
Old 01-06-2013, 04:21 PM   #3357
swatspyder
Member#: 302054
2008 WRX
Replaced a set of auxiliary lights that the previous owner had on the car, with a set of Hella FF50 driving lights that were installed on my '98 Maxima.
I pulled out all of the wiring from the Maxima for the lights. I reused the 12awg wires, but installed a set of quick disconnects for the two lights.
The relay is hooked up to the connection running to the high beam on the driver side, so all four turn on at the same time. One problem with this, is that the relay will engage only some of the time when the DRL are lit, due to a lower voltage running to the lights. I am probably going to pull the connection for them so I don't have to worry about it.
Here is one of the old ones the previous owner installed...
And the set of Hella FF50 driving lights...
swatspyder is offline   Reply With Quote
Old 01-07-2013, 12:35 AM   #3358
mspurpl_turtle
Member#: 321341
2003 WRX Wagon
Sonic Yellow
installed my recaro pole position and did my 90k
mspurpl_turtle is offline   Reply With Quote
Old 01-07-2013, 12:50 AM   #3359
kuneefay
Member#: 266477
1996 F-250 7.3L
Damn. Looks pissed with the fmic exposed like that.
kuneefay is offline   Reply With Quote
Old 01-08-2013, 07:28 PM   #3360
NWsoobie
Member#: 289516
2012 WRX
ISM
Just picked my baby up from Outback! Got my 15k done. Thanks guys! See y'all soon for my tune.
NWsoobie is offline   Reply With Quote
Old 01-08-2013, 07:44 PM   #3361
FloppyDisk
Member#: 338908
Said screw warranty on my 2012 WRB sti, went stage one... Car is 6 months old...
FloppyDisk is offline   Reply With Quote
Old 01-09-2013, 03:03 AM   #3362
buzznickle45
Member#: 331206
12 Impreza WRX
Well hit an animal on the freeway and pretty much messed up my FMIC, so that's where I am atm
buzznickle45 is offline   Reply With Quote
Old 01-09-2013, 03:13 AM   #3363
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
There's a guy selling a fmic for like $300
SuperScubi is offline   Reply With Quote
Old 01-09-2013, 03:17 AM   #3364
gmhl10
Member#: 158695
2013 GVB STi
World Rally Blue
Lol... I said the same thing when I got my car. Went stage 1 w/in 2 months on my 2013. I heard a lot of things about ringland issues on both stock and modified and I just figured that if it blows... it'll just give me an excuse to upgrade the internals. lol.
gmhl10 is offline   Reply With Quote
Old 01-09-2013, 05:10 AM   #3365
swatspyder
Member#: 302054
2008 WRX
Originally Posted by jcwrx View Post
Did a full front light conversion on my 2009 WRX.
Low beams: H11 ---> H9
DRL/High beams: 9005 ----> 9011
OEM fogs: 9006 ---> 9012
Turn Signals: 1157NA ----> Sliver Star 1157A (look clear/flash amber)
Rear:
Revers lights: PIAA Xtreme White Bulb H.I.D.
With some leveling adjustment this conversion has made a night and day difference.
Following your post...
Today, I swapped the following for ($53.20 inc. tax):
Low Beams: H11 -->> H9
DRL/High Beams: 9005 -->> 9011 HIR1
2 of Philips HIR1 9011 Standard Headlight Bulb, Pack of 12 of Philips HIR1 9011 Standard Headlight Bulb, Pack of 1
2 of Philips H9 Standard Headlight Bulb, Pack of 12 of Philips H9 Standard Headlight Bulb, Pack of 1
No before/after photos, but take my word for it... The lows are definitely better, and the highs are awesome!
Modifying the 9011's was easy. Just use toenail clippers (the larger ones) and you can clip the exact area needed off of the top tab.
Modifying the H9's wasn't as easy. I had to heat up a sharp screwdriver/blade to melt out the correct tab in the connector. You can use an x-acto knife if you have one.
I am contemplating whether or not to do the fog light DRL mod... http://forums.nasioc.com/forums/show....php?t=2383843
Since my auxiliary driving lights come on with the DRL/high beam setup, it would be better than just disabling the DRL.
Old 01-09-2013, 12:04 PM   #3366
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
What's different about those bulbs that make them better?
Breezio is offline   Reply With Quote
Old 01-09-2013, 12:34 PM   #3367
12sechatch
Member#: 132458
Okie Dokie Fine
http://hirheadlights.com/
some technical info linked there
12sechatch is offline   Reply With Quote
Old 01-09-2013, 07:28 PM   #3368
swatspyder
Member#: 302054
2008 WRX
H11 - 55watts ~1300lm / H9 - 65watts ~2000lm
9005 - 65watts ~1700lm / 9011 HIR1 - 65watts ~2400lm
Old 01-09-2013, 10:59 PM   #3369
WaWagon
Member#: 303202
2003 WRX Wagon
Ripped off my both rear mudflaps backing out of the driveway in the slush Damn you global warming
WaWagon is offline   Reply With Quote
Old 01-10-2013, 12:37 AM   #3370
Blindman29
Member#: 325328
2010 WRX Hatch
Satin White Pearl
New Mishimoto Radiator & Grimmspeed radiator shroud.
Blindman29 is offline   Reply With Quote
Old 01-10-2013, 08:23 PM   #3371
subarutah
Member#: 248428
2006 STI
FROZEN GREY
Warning bad pics incoming.
Test fit the wheels
Test fit front bumper
Test fit sideskirts
Installed new steering wheel
Installed chargespeed roof vane
Test fit voltex rear diffuser
Removed old bride seats
subarutah is offline   Reply With Quote
Old 01-10-2013, 08:54 PM   #3372
WaWagon
Member#: 303202
2003 WRX Wagon
^^^^ I have seen your car multiple times while at the shop . Car is clean man. I really like it a lot
Old 01-10-2013, 09:01 PM   #3373
cameredi
Member#: 302950
2012 Impreza STI
Pearl White
Default Replaced my exhaust
Got tired of the Noise from the SPT cat-back so I swapped it out for a Perrin Cat Back. Went from a Quad staggered to Dual slash cut
Comparison of the size difference
it has a bassier sound that the Sedan has, at idle (after it has warmed up) it is extremely quiet. No Drone and it installed in about 45 minutes. I dont understand why some people pay to have others install their cat-backs
cameredi is offline   Reply With Quote
Old 01-10-2013, 09:30 PM   #3374
rexwagon02
Member#: 226312
2007 WRX Wagon
OBP swirled to perfection
Just got my car back from Outback after a tune. I'm now in the 400 whp club. Wicked tune guys!
rexwagon02 is offline   Reply With Quote
Old 01-10-2013, 09:41 PM   #3375
jdm05
Member#: 180155
e85 05 wrx
^^^ nice mods please
jdm05 is offline   Reply With Quote
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 03:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 01:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 01:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-15-2009 12:42 AM
