North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 01-10-2014, 08:51 PM   #5926
lox
Member#: 348423
08 FXT swapped
@xrwwrx
your wife was right, that is funny
lox is offline   Reply With Quote
Old 01-10-2014, 08:52 PM   #5927
Fade2black02
Member#: 309997
2010 STI
Blick
R204 Badges, courtesy of a fellow NASIOC'er!
Fade2black02 is offline   Reply With Quote
Old 01-10-2014, 10:45 PM   #5928
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
Started installing stuff late last night...
Installed JDM headlights into the gf's bugeye wagon using JDM ballasts and lightwerkz harness.
This afternoon, the UPS guy delivered my short shifter, and shifter bushing for my Forester. And shifter bushings for my STi. The install was easier then I thought.
SuperScubi is online now   Reply With Quote
Old 01-11-2014, 12:37 AM   #5929
gmhl10
Member#: 158695
2013 GVB STi
World Rally Blue
You mean R205?
gmhl10 is offline   Reply With Quote
Old 01-11-2014, 01:53 AM   #5930
TheStepfather
Member#: 319109
2006 Forester XT
Retrofitted some projectors!
TheStepfather is offline   Reply With Quote
Old 01-11-2014, 02:13 AM   #5931
DAS97sport
Member#: 284143
1998 Impreza 2.5RS
Acadia Green
Yeah, retrofit squad!! Looks awesome
DAS97sport is offline   Reply With Quote
Old 01-11-2014, 02:43 AM   #5932
TheStepfather
Member#: 319109
2006 Forester XT
Thanks! just a little aiming and they'll be good to go
Old 01-11-2014, 07:55 AM   #5933
i5racer
Member#: 308167
1998 Impreza L
i5racer is offline   Reply With Quote
Old 01-11-2014, 09:11 AM   #5934
merlindavis
Member#: 366849
2000 OBS
Silver-ish
Originally Posted by i5racer View Post
I wish I would have done my research a bit more before I bought the current stereo, as I probably would have gone for a single din flip-out up top and random junk on the bottom. It's a pain sometime to use the screen in the oem double din position.
merlindavis is offline   Reply With Quote
Old 01-11-2014, 03:34 PM   #5935
Fade2black02
Member#: 309997
2010 STI
Blick
Originally Posted by gmhl10 View Post
You mean R205?
Yeah, sorry....R205s
Old 01-12-2014, 03:52 PM   #5936
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Fixed the ground on the hella horns from previous owner, would intermittently work at full strength or some little honk from a kids toy.
Also installed a Grimmspeed battery tie down. Had to shorten the lengths on some new J hooks due to the previous ones were already hitting the hood from the previous owner again
Amazing Asian is offline   Reply With Quote
Old 01-12-2014, 03:58 PM   #5937
SuperScubi
Member#: 233407
What did you do to fix the ground?
Old 01-12-2014, 04:15 PM   #5938
Dusten
Member#: 190891
re-installed my pac harness and sub into my wrx. ****ing dealer removed it for me.
Dusten is offline   Reply With Quote
Old 01-12-2014, 05:10 PM   #5939
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Re-sanded the section he partially sanded down. It was barely touching bare metal so it would only intermittently work.
Old 01-12-2014, 05:21 PM   #5940
Teedub21
Member#: 333099
2013 WRX STi
ISM
Gave her the first oil change. Pretty easy, besides having a hard time finding the drain plug washer to replace with the new one. Turns out it was stuck to the drain plug and had been painted over at the factory with black paint.
Teedub21 is offline   Reply With Quote
Old 01-12-2014, 07:05 PM   #5941
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Finally wired in the 3rd brake light of my STi wing, and tomorrow going to pick up some new hardware for my RA mud flaps
Bak3rSkat3r is offline   Reply With Quote
Old 01-13-2014, 03:28 PM   #5942
silverton
Member#: 331131
2001 2.5RS
STM
You shouldn't have to replace that washer every time. I've done about 8-10 changes on mine, still using the washer that was on it.
silverton is offline   Reply With Quote
Old 01-13-2014, 04:00 PM   #5943
94-1.8
Member#: 311660
98 2.5rs
It's one of those "recommended" things lol I do it too just for the benefit of knowing its been replaced
94-1.8 is offline   Reply With Quote
Old 01-13-2014, 04:56 PM   #5944
Teedub21
Member#: 333099
2013 WRX STi
ISM
The washer is cheap as "F" and the parts guy at the dealership just puts it with the filter and charges me. Its a crush washer, so supposed to be one time use.
Old 01-13-2014, 05:14 PM   #5945
i5racer
Member#: 308167
1998 Impreza L
Foreal, a crush washer can be reused if necessary but so cheap why the hell would you be like nah I can get at least a dozen changes out of this guy and probably save myself less than a dollar
Old 01-13-2014, 07:38 PM   #5946
Suffermachine
Member#: 323141
Platinum Silver Metallic
Today I put on some Torque Solutions drive-shaft carrier aluminum bushings. Easiest install I've ever had. Ever. Took longer to jack up the car than to swap these out. Maybe they're worthless but I had them laying around so wth.
Suffermachine is offline   Reply With Quote
Old 01-13-2014, 08:52 PM   #5947
SubiCutie92
Member#: 350782
2009 Wrx
Added some color
SubiCutie92 is offline   Reply With Quote
Old 01-13-2014, 11:05 PM   #5948
Bast
Member#: 329493
'99 RS
BDP
Small change, but, put my OEM pink star emblem on after work. Also found a tab broken off on my grille.. must have been the body shop.
Bast is offline   Reply With Quote
Old 01-14-2014, 05:49 AM   #5949
WRXgabeSTi
Member#: 239606
03' Bugeye Stage 2
SWP 250k+
Removed my A/C today. (hasn't worked for 4+ years)
Ran into a snag when my alternator tensioner bolt snapped! Luckily I had the spare tire tie down bolt, which fit perfectly for anyone who runs into this problem Get to show off the radiator now !
WRXgabeSTi is offline   Reply With Quote
Old 01-14-2014, 09:32 AM   #5950
i5racer
Member#: 308167
1998 Impreza L
the tie down bolt is pure genius, thanks for sharing
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 03:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 01:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 01:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-15-2009 12:42 AM
