Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 01-17-2014, 10:18 PM   #5976
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Originally Posted by silverton View Post
Needed to reboot a front axle. Decided to just leave it out.
I've gotta replace my left front axle boot. Difficult?
2.5L Monster is offline   Reply With Quote
Old 01-17-2014, 10:53 PM   #5977
silverton
Member#: 331131
2001 2.5RS
STM
If the '04 is anything like the '00:
Disconnect sway bar endlink.
Remove bolt from lower ball joint that goes through the hub and knock out the LCA from the hub with a hammer.
Punch spring pin out of axle stub that keeps it attached the transmission.
Remove nut from outter axle stub and knock it out of the hub with a hammer. ~137ft/lbs on this nut.
Installation is reverse. Should take about an hour to do both sides if you're swapping out the axles for already assembled units.
silverton is offline   Reply With Quote
Old 01-17-2014, 11:17 PM   #5978
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
If the '04 is anything like the '00: Disconnect sway bar endlink. Remove bolt from lower ball joint that goes through the hub and knock out the LCA from the hub with a hammer. Punch spring pin out of axle stub that keeps it attached the transmission. Remove nut from outter axle stub and knock it out of the hub with a hammer. ~137ft/lbs on this nut. Installation is reverse. Should take about an hour to do both sides if you're swapping out the axles for already assembled units.
Awesome write-up! Thank you! I appreciate it.
Old 01-17-2014, 11:22 PM   #5979
silverton
Member#: 331131
2001 2.5RS
STM
I'd have put it all back together proper but I thought RWD would be just too much fun, and it is! But knowing my luck, it's going to snow tomorrow.
Old 01-18-2014, 12:00 PM   #5980
bladebrown253
Member#: 378655
2012 WRX
Installed a Cobb ss today.....didn't take much time as I thought it would
bladebrown253 is offline   Reply With Quote
Old 01-18-2014, 12:03 PM   #5981
merlindavis
Member#: 366849
2000 OBS
Silver-ish
Finished wiring up the compass pack, installed the supertones (and shamed myself for it), and did a psuedo-permanent install of the bed in back for road trip/camping mode
merlindavis is offline   Reply With Quote
Old 01-18-2014, 05:15 PM   #5982
Konathebarbarian
Member#: 370557
'94 Legacy Touring
'98 M3/4/5
Got a nice 18% all around tint. Feels like a new car!
Konathebarbarian is offline   Reply With Quote
Old 01-18-2014, 06:16 PM   #5983
Clutch Dog
Member#: 258967
2007 Charger R/T
Real Steel
replaced the pcv valve, did a seafoam treatment to the intake, no oil though,
im having problems with my idle. two codes in both relating to the IAV and the high idle problems.. i think they both can be pointed back to the twe ported throttlebody, and extrude honed intake.
Clutch Dog is offline   Reply With Quote
Old 01-19-2014, 10:36 AM   #5984
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Drove it about 400 miles. Used a couple rest area on ramps to test out the new clutch, launch control, etc. with a couple 0-60 runs (65mph freeway ).
Found out the latest firmware on my access port isn't functioning properly for the 0-60 test.
After the test it switches to the 1/4 mile results screen (odd) and doesn't show any results for anything (double odd)..
Breezio is offline   Reply With Quote
Old 01-19-2014, 03:45 PM   #5985
RobSTI06
Member#: 240706
2006 STI
OBP Stg 2 Protune
New plugs, oil change, power steering flush, Installed SPT hear shield and picked up some all weather mats! Successful Saturday
RobSTI06 is offline   Reply With Quote
Old 01-19-2014, 04:25 PM   #5986
jdm05
Member#: 180155
05 Jdm Sti 2.0
Gave her a bath from gray to psm and cleaned wheels from bronze to bbs gold
jdm05 is offline   Reply With Quote
Old 01-19-2014, 04:25 PM   #5987
decal lap
Member#: 359737
2005 Impreza OBS
Platinum Silver Metallic
Replace two wheel studs and did an oil change
decal lap is offline   Reply With Quote
Old 01-19-2014, 08:38 PM   #5988
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Purchased a dash/window cam for her. Getting crazy out there after witnessing an insurance fraud being pulled. Driver reversed into another and claimed being rear ended.
Not bad review for only $65. It has the option to auto records over from the start once the card is full, unlike cell phones/go pros.
Amazing Asian is offline   Reply With Quote
Old 01-19-2014, 09:07 PM   #5989
mnav152
Member#: 364301
1996 WRX Swap
Aegean Blue
I have that same one, but the sensor is going out so everything has a purple tint now. Don't know if that's a major problem with them, but do make sure to use a class 10 sd card. They don't like anything lower for very long and will start freezing up and whatnot.
The Hero 3 gopros do have the option of acting as a dashcam while plugged in(overwriting, starting when 12v socket gets power, turning off, etc) with one of the newer firmwares.
mnav152 is offline   Reply With Quote
Old 01-19-2014, 09:22 PM   #5990
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Oh wow didn't know that about the GP hero 3's, that's great to know in case I want to upgrade. For the price though, this was a great one for <$100. I've read up on the class 10 cards, picked up a 32gb sandisk also on Amazon too.
Old 01-21-2014, 05:12 PM   #5991
Oblivion
Member#: 208588
2005 WRX STi
Replaced the A/C idler pulley...heard an odd whining that started two days ago and decided that it was the most likely culprit. I was correct; after I pulled it out I spun it a bit by hand and it sounded like it was full of freakin gravel. $40 metal replacement from the local Oreilly's and I was back in business in about 20 minutes.
After that, finally flashed the ECU to Cobb Stage 1
Oblivion is offline   Reply With Quote
Old 01-21-2014, 05:25 PM   #5992
Web Foot STi
Member#: 39086
2004 STi
I had my timing belt replaced last summer and one if the idler's had that same graunchy feel. Scooby Bucks paid for all but $8.34. No noticeable noise from under the timing cover though. ~10 and did a little PM...
Web Foot STi is offline   Reply With Quote
Old 01-21-2014, 09:21 PM   #5993
usmc030621
Member#: 378080
New tranny, new legal taillights aka stock..now to put the bumper back on and lift the dang coil overs UP.
usmc030621 is offline   Reply With Quote
Old 01-21-2014, 10:33 PM   #5994
decal lap
Member#: 359737
2005 Impreza OBS
Went to the Stealership today to get an alignment and came out with a suggested repair and labor invoice. They say I need a new rear passenger side Abs tone ring and sensor and a rear drivers side axel, wheel bearing and seals. Bad news all around.
Old 01-21-2014, 11:24 PM   #5995
jtoler3
Member#: 327408
2013 WRX
finally got some stuff done. did my tails, put on new rain guards, and baked my headlights. finished late sunday night and was too lazy to put my bumper back on, then had to go out of town for work all week. still haven't seen the headlights in person during the day had my roomie send me this pic
jtoler3 is offline   Reply With Quote
Old 01-22-2014, 01:10 AM   #5996
BullShift
Member#: 377416
2011 Impreza 2.5i
Marine Blue Pearl
Did Tints all around and blacked out the tail lights - I'm in love even more ^.^ there as dark as i can go legally but in the light at the shop you cant really see them >.>
BullShift is offline   Reply With Quote
Old 01-22-2014, 01:44 AM   #5997
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Swapped my VF39 for a new one and put the heatshield on after I cut it to fit the external waste-gate.
DSC_0363 by HawthorneEF, on Flickr
ehawthorne521 is offline   Reply With Quote
Old 01-23-2014, 07:41 PM   #5998
DAS97sport
Member#: 284143
1998 Impreza 2.5RS
Acadia Green
Uncovered my rs to put my kartboy shifter bushings in to discover mold everywhere. Sweet.
DAS97sport is offline   Reply With Quote
Old 01-23-2014, 08:33 PM   #5999
decal lap
Member#: 359737
2005 Impreza OBS
Got my fenders Rolled today and put on my new Rally Armor Urethane Mudflaps.
Old 01-23-2014, 11:28 PM   #6000
Teedub21
Member#: 333099
2013 WRX STi
ISM
Looks sweet! Good luck getting that bumper back on. I had a hell of a time with the tabs at the fender on the driver's side. One bent a bit and isn't perfectly flush. Apparently it is pretty common. Just pissed me off since my car was two weeks old and I'd just pulled the bumper to install my Hellas.
Teedub21 is offline   Reply With Quote
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 02:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 12:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 12:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
