Old 09-07-2011, 08:50 PM   #1
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
Default JDM 95 Sti RA. Brakes? Rotors? Pads?
Hello all,
it looks like my rotors and brake pads are done for.... getting this weird rubbing noise coming to a stop from the rear. The fronts have a lil bit of pad left, but not much and the rotors are pretty much done.
Before I begin, I'm not familiar with brake systems... So I have tons of questions and I'm not 100% sure what mine is... let me know what brake setup is called (I am guessing it's the 4/2 pot?):
Front:
Back:
So I did tons of research trying to find pads and went with EBC brake pads for the 91-95 Legacy 2.2 Turbo.. I think it's the same *correct me if I am wrong* I used this chart: http://www.buybrakes.com/ebc/pad-apps-Subaru.html
I also ordered the goodridge SS lines: http://www.buybrakes.com/goodridge/apps-Subaru.html (1992-2001 model)
Now, I'm looking at rotors... I am not sure which one I need to buy... I don't want to go OEM and was looking at the EBC ones to match the EBC Redstuff pads. According to the 93-96 Impreza manual, which includes the turbo model, the rotors discs are 10.91" dia (front) and 10.47" dia (rear). Following these specs, should I order these?
Front: http://www.buybrakes.com/store/EBC-GD729
Rear: http://www.buybrakes.com/store/EBC-GD728
Help this noob out!
sizzflair is offline   Reply With Quote
Old 09-07-2011, 10:33 PM   #2
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Someone please correct me if i'm wrong but this car should have came with 2 piston front and 1 piston rear. It looks like your fronts were upgraded to the later 4 pots and the rears left as the stock 1's.
Other than that i'm no help. GL
fxt05 is offline   Reply With Quote
Old 09-07-2011, 10:52 PM   #3
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
You have the 4 pot / 1 pot (sliding) configuration, which was the normal setup on early STIs (except the TypeR ones which had the 4/2 pot configuration).
That means you should also have vented front and rear discs (294 mm front and 266mm rear).
The front discs should be the same as 2002-2004 WRX and the rear ones should be the same as 1992-1993 Legacy Turbo...
Take a look at this thread:
http://forums.nasioc.com/forums/show....php?t=2102642
wrxstijdm is offline   Reply With Quote
Old 09-07-2011, 11:08 PM   #4
sizzflair
Member#: 94268
2010 Exige S240
That thread really helped me out.
Thanks for the help guys!
Old 09-07-2011, 11:28 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Order your front pads and rotors for 07 wrx and your rear pads and rotors for 93 turbo legacy. Those are the USDM equivalent.
Old 09-08-2011, 12:09 AM   #6
sizzflair
Member#: 94268
2010 Exige S240
05+ rotors are different... aren't they? At least according to EBC.
I ordered the front pads for 93 turbo legacy... I guess I'll have to change that order to 04 WRX.
I went with 04 WRX rotors (front) and 93 turbo legacy rotors (rear)
Old 09-08-2011, 10:50 AM   #7
Jarrod164
Member#: 253937
1995 WRX
From what I understood, only version 3's and up got the 4 pots in the front and only the RA's got the rear 2 pots.
Jarrod164 is offline   Reply With Quote
Old 09-08-2011, 11:04 AM   #8
sizzflair
Member#: 94268
2010 Exige S240
Alright, I got the pads changed before it got shipped.
So 04 WRX rotor coming in with WRX pads for the front (4pot)
92 Legacy turbo rotor coming in with legacy turbo pads for the rear (1pot)
Of course, they are all EBC parts.
Old 09-08-2011, 01:59 PM   #9
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Shows pics when installed and let us know the outcome!
Old 09-08-2011, 04:30 PM   #10
Aphex28
Member#: 11506
2015 WRX
You're going to need 06-07 wrx front pads. 04 wrx front calipers were only 2pot and the pads for those will absolutely not fit.
Aphex28 is offline   Reply With Quote
Old 09-08-2011, 04:47 PM   #11
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
I'm not sure if this helps, but I bought Hawk Performance ceramic pads for that same configuration (4 pots front, 1 pot sliding rear) with perfect fit, and these are the part #s for both:
HB315Z.669 Front
Application(s):
1990-1991 Toyota 4runner SR5 All
1996-1997 Toyota 4runner Limited All
1996-1997 Toyota 4runner SR5 All
1996-2001 Toyota 4runner All
1995-2008 Toyota Hilux All
1989-1991 Toyota Pickup SR5 All 4WD
1989-1992 Toyota Pickup DLX All 4WD
1991-1992 Toyota Pickup Sht Bd DLX EXC All 4WD
1993-1995 Toyota Pickup DLX All
1994-1995 Toyota Pickup SR5 All 4WD
1995-1997 Toyota Tacoma Regular Cab All 4WD
1995-1997 Toyota Tacoma SR5 All 4WD
1995-1997 Toyota Tacoma All 4WD
1998-2004 Toyota Tacoma All
2003-2004 Toyota Tacoma All 4WD
HB367Z.585 Rear
Application(s):
1995-2000 Chrysler Sebring Coupe All
2001-2005 Chrysler Sebring Coupe 6 Cyl., w/Rear Disc Brakes.
1995-1998 Dodge Avenger ES All
1997-2000 Dodge Avenger All
1991-1993 Dodge Stealth All 2WD
1994-1994 Dodge Stealth All 2WD
1995-1996 Dodge Stealth All 2WD
2001-2005 Dodge Stratus Coupe 6 Cyl. Only
1993-1994 Eagle Summit ES All
1994-1995 Eagle Summit LX All
1994-1996 Eagle Summit ESi All
1995-1999 Eagle Talon TSi All 2WD
1997-1997 Eagle Talon TSi All AWD
1998-1999 Eagle Talon TSi All AWD
1991-1999 Mitsubishi 3000GT SL All
1991-1999 Mitsubishi 3000GT All
1995-1996 Mitsubishi 3000GT Spyder SL All
1993-1995 Mitsubishi Diamante LS All
1993-1996 Mitsubishi Diamante ES All
1994-1994 Mitsubishi Eclipse Non-turbo All w/Rear Disc Brakes.
1995-1999 Mitsubishi Eclipse Non-turbo All
1995-1999 Mitsubishi Eclipse Turbo All 2WD
1995-1999 Mitsubishi Eclipse Turbo All 4WD
2000-2000 Mitsubishi Eclipse Non-turbo 6 Cyl. Only
2001-2005 Mitsubishi Eclipse Non-turbo 6 Cyl. Only
2006-2008 Mitsubishi Eclipse Non-turbo GS 4 Cyl. Only
2006-2009 Mitsubishi Eclipse GS All V6 Only
2007-2008 Mitsubishi Eclipse Spyder GS All
2008-2008 Mitsubishi Eclipse SE All
1992-1993 Mitsubishi Expo SP All
1992-1994 Mitsubishi Expo LRV Sport All
1994-1998 Mitsubishi Galant All To 1/1998
1998-2000 Mitsubishi Galant 6 Cyl. Only. To 5/2000
2000-2003 Mitsubishi Galant 6 Cyl. Only. From 6/2000
2004-2007 Mitsubishi Galant 3.8 6 Cyl. Only
1993-1994 Subaru Impreza LS All
1995-1996 Subaru Impreza LX All
1995-1996 Subaru Impreza Outback All
1998-1999 Subaru Impreza RS All
1990-1990 Subaru Legacy All
1990-1994 Subaru Legacy Non-turbo All
1991-1993 Subaru Legacy All
1991-1994 Subaru Legacy All
1991-1996 Subaru Legacy All
1994-1994 Subaru Legacy All
1994-1996 Subaru Legacy All
1995-1996 Subaru Legacy Outback All
1996-1996 Subaru Legacy GT All
1997-1997 Subaru Legacy LSi All 14 in. Wheel
1997-1997 Subaru Legacy LSi All 15 or 16 in. Wheels
1997-1998 Subaru Legacy GT All
1997-1998 Subaru Legacy L All 14 in. Wheel
1997-1998 Subaru Legacy L All 15 or 16 in. Wheels
1997-1998 Subaru Legacy Limited All
1997-1998 Subaru Legacy Outback All 14 in. Wheel
1997-1998 Subaru Legacy Outback All 15 or 16 in. Wheels
1999-1999 Subaru Legacy Outback All
1999-1999 Subaru Legacy All
Old 09-08-2011, 08:59 PM   #12
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Does anybody know if when upgrading from 1 pot (sliding) calipers on the rear, to a 2 pot setup, you need to necesarilly replace the rotor?
I know the 1 pot setup uses a 266mm rotor, while the 2 pot setup uses 290mm, but I was wondering if you can you install the 2 pot caliper on the existing 1 pot rotor, and just buy the mounting bracket?
Old 09-08-2011, 10:52 PM   #13
sizzflair
Member#: 94268
2010 Exige S240
damn... i guess I have to exchange it again
Edit: Just checked that the pads I ordered were the same for 06-07 wrx front pads even though I ordered the 04wrx ones... I guess I'll find out when it gets here. This was from the EBC catalog http://www.buybrakes.com/ebc/pad-apps-Subaru.html.
I ordered the DP31661C
Old 09-08-2011, 10:56 PM   #14
sizzflair
Member#: 94268
2010 Exige S240
now that I think about it, I should have probably upgraded to the 2pot rear too while I'm at it... oh well haha.
Let me know if you find out the answer to your question.
Old 09-09-2011, 12:43 AM   #15
wagonryan
Member#: 163756
1996 R/RA
edited....didn't see that post. no you can't use that rotor.....your pad would be hanging off the end.
wagonryan is offline   Reply With Quote
Old 09-09-2011, 11:33 AM   #16
Aphex28
Member#: 11506
2015 WRX
Weird. Their system is screwed up in that case then.
02-05, 08+ WRX all have 2 pot calipers up front.
Old 09-09-2011, 03:32 PM   #17
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Ok got it... now, is there a real improvement in moving from a 1 pot rear caliper into a 2 pot rear caliper?
I'm asking since the braking bias of Imprezas are 70% front / 30% rear, so just wondering if there's a REAL improvement (from a functional standpoint, as clearly from a "exterior look" standpoint it does).
Old 09-09-2011, 04:28 PM   #18
sizzflair
Member#: 94268
2010 Exige S240
Probably better off getting better pads/rotors?
Old 09-09-2011, 04:29 PM   #19
sizzflair
Member#: 94268
2010 Exige S240
I see... I'll have to talk to them
EDIT: I think I understand their error. Unfortunately the part was shipped so I would have to return it (which I assume I have to pay for shipping)
for the 2pot calipers (02-05, 08+ WRX): Part #DP31661C
for the 4pot calipers (JDM STi, 06-07 WRX): Part #DP31200C
Gahhh
EDIT #2: I was able to smooth talk to them and waive the restocking fee (20%). Unfortunately I'm off to training for a month so my car will be in the garage for a while and even more after I get back. Oh well, I guess I can work on other things.
Old 09-11-2011, 09:37 PM   #20
blessthekellen
Member#: 273859
MY98
WRX
So Version 2 STI (both RA and non RA types) comes with 4 pot fronts and 1 pot rears?
I am going to be going through the same thing this week and want to ensure I purchase the correct parts for my 95 V2 STi.
So what do I get for front rotors, front brake pads, rear rotors, rear brake pads?
blessthekellen is offline   Reply With Quote
Old 09-12-2011, 01:35 AM   #21
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Well, if it comes with 4 pots front and 1 pot rear, you will need:
2004 WRX front discs
1993 Legacy Turbo rear discs
2006 WRX front pads
1993 Legacy Turbo rear pads
Old 09-12-2011, 11:07 AM   #22
Jarrod164
Member#: 253937
1995 WRX
Version 2's do not come with 4 or 2 pots. They just get the 2/1 setup.
There are quite a few threads about brakes on WSC and jdmvip if you're on there. I can't remember off the top of my head the ones you'll need. Best bet is to bring them in and start comparing them to a 91-96 legacy.
Old 09-12-2011, 02:32 PM   #23
Poppie
Member#: 262422
1998 V4 Type R
Feather White
not really as the V3 type R got 4/1 and then the V4 got 4/2 and having driven both cannot find any difference in braking ability (standard pads/discs).
I'm surprised that Buybrakes doesn't stock the Bluestuff NDX which have been getting plenty of good reviews in the UK
Poppie is offline   Reply With Quote
Old 09-12-2011, 02:45 PM   #24
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
The blue stuff were 'worst in group' in GRM's test.
KNS Brakes is offline   Reply With Quote
Old 09-12-2011, 05:48 PM   #25
HiTempguy
Member#: 189427
I own a 1995 STi and recently did my brakes.
You have turbo legacy (1991 to 1994) brakes all around (the 1995 STi and STi Type RA ARE THE SAME). You MUST make sure you get the ventilated rear discs, the solids are incorrect.
To reiterate, you need turbo legacy front pads, turbo legacy front rotors, turbo legacy rear pads, and turbo legacy rear rotors. Some of the info you've been given in this thread is beyond terrible
HiTempguy is offline   Reply With Quote
FS : 2004 STI Struts, Brake Rotors, Brake Pads, All Weather Mats, Spark Plugs subiedrewbie SCIC Private Classifieds 4 04-12-2011 10:19 PM
'04 Sti Racing brake rotors and pads subysnck Suspension/Brakes/Handling 25 05-22-2008 09:10 PM
FS: 2004 STI Brake Rotors + Pads PICS!!! STIckySTIfee Suspension/Brakes/Handling 9 01-20-2008 07:37 PM
$50: 95 STi RA front brake calipers with STi lines supermoose Private 'For Sale' Classifieds 5 08-19-2005 09:05 AM
$60 95 STi RA front brake calipers with STi lines supermoose Private 'For Sale' Classifieds 2 07-21-2005 11:48 AM
