Old 09-09-2011, 12:34 AM   #1
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Default Pushing coolant on sleeved block, dissambled and no signs of Head gasket failure
Guys
I can`t think of anything else, so all comments are very welcome
Brand new short block, sleeved by a very well known sleever in the states with dartons ductile iron sleeves
cosworth big valve cyl heads 07 sti
pe full grommet head gaskets
l19 arp 11 mm head studs
1000 miles on the engine, including break in.
Pushing coolant on 15 psi of boost, never has overheated ever (big rad, oil cooler, front sti 07 nose, hood scoop mod, big subaru fans) etc etc... on cruising I can not see any temp above 180 deg, even on traffic jams etc etc, if I boost the car up a lot, I will lose coolant, and keep losing it only on boost, i keep adding coolant. leak down test showed no air burbles at radiator setup, coolant pressure system check showed no leaks, rad caps are fine and holding pressure.
I teared down the engine, found 4 differences in torque from the L19s, but no more tha 10 percent difference
I thought I was gonna see the typical combustion path to a water jacket, on the block or head or head gasket surface.. I couldnt see anything!! nothing water jackets are clean con combustion marks have not touch the water jackets!!
Sleeves were press in and all of them has a very small step down of 0.0025 of a inches from block`s deck to sleeve surface.
If I can`t see the combustion path trough the head gaskets, and leak down test showed perfect seal and no air burbles at radiator tank, how am I suppose to diagnose the possible combustion leak/sleeved dropped??
I have a 140deg thermostat and the engines temp were always in the 180 degs...
thanks for the comments all of them are very welcome!!
I am also thinking I might have one port on the cosworth head bad machined at cosworth and got a hair crack... but now I need to clean it first, but if thats the case I would be vaccum water into intake?? I cant see signs on the parts yet
DJIMPREZA is offline   Reply With Quote
Old 09-09-2011, 01:03 AM   #2
ASF Machine
Member#: 236349
1993 Impreza
OD Green
There you go.
That's enough right there.
ASF Machine is offline   Reply With Quote
Old 09-09-2011, 01:42 AM   #3
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
^ more so, sleeving a brand new case can be worse off because it hasn't been heat cycled.
AdamBOMB_STi is offline   Reply With Quote
Old 09-09-2011, 09:22 AM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Originally Posted by ASF Machine View Post
There you go.
+1...
second on this..
Old 09-09-2011, 09:40 AM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yeah it dropped a sleeve. You can deck the block and hope for the best.
Old 09-09-2011, 09:59 AM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
not really much hoping for the best...just deck it and hope that they are as settled as they're gonig to get.
*I prefer sleeving a used block to a new block*
Old 09-09-2011, 10:02 AM   #7
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
There you go.
do you think 0.0025 stepped down might be enough for a 0.57 gasket to leak? shouldn`t I be seeing the combustion water path mark on the cyl head or the block surface? I can`t see anything.
This block was made by a known US dealer, I told him it was gonna be a new block and said its okay as he heat cycles the block while doing his stuff.
What`s better for this block a milling cutting machine, or a milling stone machine?
This is the 3th different sleeved block from another BIG ENGINE BUILDER that we are having big money issues after build up.
Or maybe I have a cosworth head cracked? i will do a pressure test today on the intake ports...
Old 09-09-2011, 10:59 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
I'd pressure test before yanking it. An over ported head can push too...though I doubt Cosworth goes that far.
Old 09-09-2011, 11:09 AM   #9
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
There was a post here where an exhaust port on a cosworth head cracked into the water jacket.. a big mess!..
Old 09-09-2011, 12:25 PM   #10
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Where are you pushing coolant? Is it overflowing into the overflow? Or is it just disappearing? I am also assuming no smoke out the exhaust when boosting and losing coolant?
Crystal_Imprezav is offline   Reply With Quote
Old 09-09-2011, 01:16 PM   #11
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Where you given any instruction about the block installation? Did he assemble the long block or just do the sleeving? Was he expecting the end user to do the final decking of the block or was it ready to be put it once you received it? If anything I would have expected the sleeves to be slightly higher than the block or preferably flush with the rest of the block. Have you talked to Dan about this yet?
Old 09-09-2011, 02:11 PM   #12
AdamBOMB_STi
Member#: 103419
04.7 STi
I don't think any engine can get properly heat cycled without it actually running off it's own power and heat. You can tear down a fresh subie engine that has been ran and heat cycled and measure the bores and decks. I'm willing to bet that the bores will be out of round and the decks not perfectly flat.
That being said, with many years experience with high performance imports, I would always advise using a good condition used engine core for a sleeve job.
Sorry to hear about the dropped sleeve.
Old 09-09-2011, 02:28 PM   #13
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Hi Guys
I am just really frustrated, the sleeves are bellow deck by 0.002 but there ARE NO SIGNS of dropping at all, nor betewen them/bottom etc etc.. I just guess a better block decking was needed at the machinist..
I was pushing coolant out while only on boost. No smoke on tailpipe, no water oil mixing nothing. 1000 miles on the engine.
I did not have any "instructions" to get this installed, just our 18 years experience building subarus and around 20 FSMs, but, we only trusted US machinists for this type of sleeving work for subarus, Benson told me to "boost away" the block, so it was ready to be ran, the sleeves are not flush, it is just 0.002 t0 0.0025 stepped down.. now I need to deck this thing down, what to use? a stone or a knife type milling machine?, in the past we send one to a local machinist, he did use a stone milling machine but needed 3 revisions and the CR went up, and i dont like this for this engine at all...
today I found a hard to see path for the air to scape, betwen the cylinders.. also notices the mark left by the head gasket is not as strong as from other engine we hace seen
Very tricky, difficult and a nigthmare sealing a sleeved subaru block that is not flushed 0 to 0, dont u guys ever expect something to be 100 perfect out of the box, even if NASA made it for you, come here to the forum ask, ask, ask and learn from otherīs experience, in this case the better/precise measuring tool with be a flat bar with a rolling dial indicator, as the feeler gauge method will not be as precise.. even a 0.002 difference would be to much for an mls gasket and I used 400 USd PE full grommet bla bla bla head gasket... now I also know that your finger nails could be used if you feel a resistance touching the portions on the deck where the sleeves are met, go to the machinist again.. you need that thing flush at least... and feel like the sleeves are just one unit with blockīs decks at least.
Also a copper ring wonīt seal at all on a subaru, been there, asked for that and results were horrible, lost a lot of money.
Roger clark motorsports sells a WRX thinck copper top sleeve Ring wich should be the strongest stuff for combustion chamber sealment used on rally cars, I wonder when or where could this be done to semi close deck ej257s.. as he implied this is done only on full close deck blocks.
This is the 4th time guys with subaru sleeved block problem..
First one, cooper oringed, trusted the builder, leaked a lot
Second one, paid a lot to have cyl to piston wall clearance done.. I end up buyind larger pistons as the sleever did a terrible job
3th one, sleeves pressed to much, cracked block on the rear section, build everything water scape from flywheel area.
4th sleeved not flush ;(
Old 09-09-2011, 02:30 PM   #14
stu
Member#: 25768
35R bugeye
Slowbaru
wow that sucks. i find that it is hard to find a coolent leak with such low miles on it. i had a similer problem on 2 builds one was a warped head and the other was the RA on the decking was to rough and both time i couldnt see any visable signs of water.
stu is offline   Reply With Quote
Old 09-09-2011, 02:37 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
Another reason for a full o-ring/headgasketless set up.
now if parker would only answer a freakin request for a batch of custom molded o-rings!!!
Old 09-09-2011, 04:27 PM   #16
bbong
Member#: 141258
2006 Evo 9 GSR
GG
Wonder if i'm having the same issue as you are, but it sounds like it.
bbong is offline   Reply With Quote
Old 09-09-2011, 06:34 PM   #17
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Honestly is the mating surface is O to O flat, I see no reason for molded o rings if you are not boosting more 28 psi or so. it would be nice to have the WRC seal though
I have yet to see a low ten second subaru that do not pushes coolant out..
Jeff send me your phone number bro
Cheers
DJ
Old 09-09-2011, 07:15 PM   #18
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
this ^^^
renosubby is offline   Reply With Quote
Old 09-09-2011, 07:29 PM   #19
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
In one of my tear down threads you will see that I could also not find any coolant tracks but I did find my sleeves had dropped. I was overheating after 1-2 laps if I remember.
That block was decked, put back together and run without issue. Since then it's been refreshed again including being decked and once again is back in the car.
Surface the block and put it back together IMO
mick_the_ginge is offline   Reply With Quote
Old 09-09-2011, 10:57 PM   #20
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Cheers
DJ
I don't push any coolant running 10.0's and going 6.3 through the 1/8th .
I will email you my number.
Old 09-12-2011, 02:31 AM   #21
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Cheers
DJ
It is easy to not push coolant if your block is good and machined right.
If you need a used block and want it sleeved PM ASF Machine, I got a block they can sleeve for you.
project_skyline is offline   Reply With Quote
Old 09-12-2011, 10:05 AM   #22
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
You always have to check the work before you build it. Even if its from Darton themselves I still always check to make sure they decked it for the head gaskets im using, retorque the torqueplate and check for round/straight. If you dont then things like this happen. Just finished cleaning up a huge mess from another vendor... had to get bigger pistons and redeck the surface as they did it for the wrong type of headgasket and it was out of round. Sorry to hear though
Bamofo is offline   Reply With Quote
Old 09-12-2011, 11:58 AM   #23
Homemade WRX
Member#: 33782
96 bastard child
Honestly is the mating surface is O to O flat, I see no reason for molded o rings...
...I have yet to see a low ten second subaru that do not pushes coolant out.
self contradiction?
although I know there are fast subies that don't push coolant. O-ringing wouldn't simply be a solution for coolant pushing but paired with Will's rings for combustion. Also, MLS gaskets can run over 28 psi.
I guess people still don't get that boost pressure does not dictate PCP, which is what really matters. Add fuel type, ignition system, dynamic CR, boost pressure, MBT, etc...
Besides, I'm not the one saying they're needed. I simply work to fill voids that come to me from the field. People request it and I work to solve the issues at hand
...on a good note, Parker finally got back to me.
Old 09-13-2011, 01:01 AM   #24
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
the thing is that it seems we have done many things to avoid pushing coolant that we are doing so on fast cars...I will do it very simple this time
Old 09-15-2011, 11:15 PM   #25
wrxG
Member#: 155087
04 WRX
my byddy had the same issue at 500 miles on his sleeved block
coolant kept going into oil
took the oil pan off pressurized the coolant system and sure enough the sleeve was leaking
wrxG is offline   Reply With Quote
Coolant is disapearing with no signs of leaks!! boostinscooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 06-19-2007 01:37 AM
WRX spitting coolant, but no sign of leaks MT_WRX Service & Maintenance 19 07-25-2005 05:35 PM
Preventing Head Gasket Failures chrispy Legacy Forum 1 04-18-2004 10:07 PM
Head gasket failure in 99 Forester oshkasmum Canada Region Forum 9 03-12-2004 04:12 PM
regarding '99-'02 2.5s: With extended warr., do we hope for head gasket failure? dingo dave Warranty Issues & SOA Problems 15 03-09-2004 03:49 PM
