Old 08-01-2002, 03:28 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default A cross post to another thread, regarding 2.5l engine and spark plugs
Seems NGK only offers the super platinum plugs for the 2.5l. These plugs are very expensive. Read my thread in the legacy forum about an alternative and tell me what you think..
http://forums.nasioc.com/forums/show...hreadid=223096
Old 08-01-2002, 03:43 PM   #2
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
I've got regular ole NGK plugs in my car. Cost me $7 for all four.
I don't know why you were led to believe otherwise...
tcs007 is online now   Reply With Quote
Old 08-01-2002, 04:14 PM   #3
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
You can definitely buy non-platinum NGK plugs for the 2.5l. I am running plain old copper NGK V-Power plugs, always have. I think the part number is BKR6E-11 for the plugs I use.
-Wes
RebelINS is offline   Reply With Quote
Old 08-01-2002, 04:21 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
tcs007:NGK's web site and all of the distributors do not mention an application for the standard plugs.
RebelINS: How do your plugs look? The platinum use a slightly higher heat range, do yours come out okay?
Old 08-01-2002, 05:21 PM   #5
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
I have the exact same plugs that RebelINS has.
I went out to my car and checked, just to make sure of the part number.
And I wasn't calling you a liar or anything. I just know that they exist, because they are in my car right now.( And probably due for a cleaning/checkup for anything funky.)
Old 08-01-2002, 06:47 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
No offense taken. Thats what is currently installed in my legacy 2.2l
I personally do not own an ej25 based machine. Just trying to help someone out. Are you sure they are the correct heat range though? Do they come out clean?
Old 08-01-2002, 08:00 PM   #7
RebelINS
Member#: 2953
2000 Impreza 2.5RS
The plugs are a perfect fit, and work great. They came out clean, even after I blew a couple O2 sensors, and had my car running rich.
-Wes
Old 08-02-2002, 01:38 AM   #8
tmaler13
Member#: 1992
Talk about expensive....I paid 14.00 a plug for the Denso Iridiums in temp range 7
tmaler13 is offline   Reply With Quote
Old 08-02-2002, 12:14 PM   #9
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Info
I order all of my spark plugs from here. This in turn takes me to:
http://www.ngksparkplugs.com
Looking under "1999 SUBARU Impreza RS 2.5 H4 EJ25D MPI DOHC", this is the result.
V-Power - BKR6E-11 # - Stock#2756# - Plug Gap .044
Platinum - BKR6EVX-11 - Stock#3540 - Plug Gap .044
The V-Power plugs can be found at the site I order from 1 degree colder (BKR7E-11) or one degree hotter (BKR5E-11) in V-Power. Platinum NGK's can be had one degree colder (BKR7EVX-11) or one degree colder (BKR5EVX-11). I order ALL of my spark plugs from Monarch Products because their shipping is fast and reliable. I hope this helps.
Kevin Thomas is offline   Reply With Quote
Old 08-02-2002, 12:18 PM   #10
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Oh.....
I'll add this for 'added punch'.
The V-Power plugs are $1.99 a piece and the platinums are $6.40 a piece. So for $80.00+, someone has been had.
"tcs007:NGK's web site and all of the distributors do not mention an application for the standard plugs." Ciper, look again at the V-Power plug application that I mentioned. You'll notice a pound sign (#) next to it. That means it is the Original Equipment plug for that application.
Old 08-02-2002, 01:46 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
What the hell? I just went to their site again and they DO NOT list that plug...
qoute
1997 SUBARU Legacy GT 2.5 H4 EJ25D MPI DOHC
Spark Plug Part No. Stock No. Plug Gap Photo
Platinum PFR5B-11 * 2300 .044
* Laser Platinum Plug
end qoute
That is all the plugs listed for the application.
So its a mistake in the page or subaru ONLY uses platinum in the DOHC engines or something. You are right, when I look up 99 2.5 rs it shows both of those
Old 08-02-2002, 02:04 PM   #12
Julian
Member#: 1182
MY00 RS
BRP
The P/N for the NGK coppers is in the manual. ciper, do you have a Napa store near you or your friend? Had them in stock the last time I changed them in my RS. I have a set of stock Champions with light miles on them, for sale cheap!
Julian is offline   Reply With Quote
Old 08-02-2002, 03:36 PM   #13
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
It may not be a matter of engine, but application, Ciper. There are lots of external factors which also influence the heat range of a spark plug, such as air/fuel mixture, engine speed/load, etc.. Just because Legacies, and RS's use the same base engine, doesn't necessarily mean that they require a plug in the same heat range.
gavin is offline   Reply With Quote
Old 08-02-2002, 11:28 PM   #14
Commuter
Member#: 9432
1997 Outback
Red
Default PFR5B-11...
... is what my manual says for my 97 Legacy Outback Auto with EJ25D engine.
My dealer put some new ones in recently because they broke one of my TorqueMaster plugs. Cost for NGK platinum was around $50 Canadian IIRC, or about $30 odd dollars US for 4. That's about $8 US each from a dealer.
Heck, the TorqueMaster plugs didn't cost that much... and I thought they were expensive at $14.50 US each.
Commuter is offline   Reply With Quote
Old 08-03-2002, 02:00 AM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
Julian: that may very well be, but I DONT have a 2.5l! I was helping someone else
gavin: Im the person who was saying that the heat range was incorrect, your explanation should be pointed at someone else.
WTB 2.5l engine - MD (possibly another 2.0) Kaldar142 Private 'Wanted' Classifieds 10 09-15-2008 01:55 PM
Which Engine Oil and Spark Plugs for the TRACK ??? george3 Motorsports 25 01-10-2008 08:59 AM
How to remove rusted Rear Diffy Plug? And Spark plugs SubaruImpreza_power Newbies & FAQs 12 09-06-2003 03:46 PM
Size of oil drain plug 2.5L engine goobie Normally Aspirated Powertrain 2 07-29-2003 11:16 AM
swapping out DOHC 2.5L engine for SOHC 2.5L engine 2.5GT Normally Aspirated Powertrain 2 11-14-2001 03:58 PM
