Old 05-16-2001, 06:17 PM   #1
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post Does an ECU reset change the way an auto tranny shifts?
I am not sure if your tranny "learns" your driving style or if it's only the fuel mixture that is affected.
subymamma is offline   Reply With Quote
Old 05-16-2001, 06:19 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
no, the shifting of an automatic transmission is all mechanical.
JGard is offline   Reply With Quote
Old 05-16-2001, 06:21 PM   #3
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post
Thanks! Wasn't sure if the little computer thingys were liked to the transmission!!
Old 05-16-2001, 06:25 PM   #4
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Modern automatics are not purely mechanical. They are almost all governed by a computer. This allows them to provide services such as engine braking, and downshifting on throttle-off.
Resetting the ECU probably woudn't have any effect on the TCU, but if you did it by disconnecting the battery, then you would also have reset the TCU.
gavin is offline   Reply With Quote
Old 05-16-2001, 08:21 PM   #5
credit xtc
Member#: 5221
m3 540it, xt-6 sc
black,white,gray pearl
Post
I beg to differ, I recently took my car to the dealer, the auto mirror needed to be changed, and for some reason they took it upon themselvs to reset the ecu by disconecting the battery. I did have a cel because of mods I put on the car. now I 'm waiting for the computer to readjust to the mods. damm
credit xtc is offline   Reply With Quote
Old 05-16-2001, 08:48 PM   #6
RS4DR
Member#: 2795
Post
I'm definitly not an expert, but I will swear that when I reset the ECU my shift point change on my 00 2.5RS. Isn't the 4EAT a "learning" transmission?
RS4DR is offline   Reply With Quote
Old 05-17-2001, 11:42 AM   #7
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
I don't understand your point, xtc.
Old 05-17-2001, 11:50 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Exclamation
hey all...
i did several resets on mine and it does have an affect on your shift points...
the ECU learns how you drive.. and adapts to YOUR driving style...
when someone else would drive my car... it didnt know what the hell was going on cuz i am a red liner and i red lined it a lot...
when you reset the ecu... it has to start over so to speak... now...
i am talkin about a my99 GT... perhaps things have changed since then.. but this is my experience...
j. www.subiegal.com
Old 05-17-2001, 11:55 AM   #9
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Post
I'm also pretty sure that a ECU/TCU reset will change the way your car shifts. After all, why would it be called an "electronic" auto transmission if it were purely mechanical? Any model year with Subaru's "4EAT" will adapt to your driving style.
A few months ago my car wasn't shifting smoothly from 1st to 2nd (jolting sensation). Simply disconnecting the battery for an hour then letting the car idle for 20 minutes fixed the problem instantly.
BJamerican is offline   Reply With Quote
Old 05-17-2001, 09:10 PM   #10
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post
What exactly does ECU and TCU (was that it?) stand for? Let me guess... Electronic Control Unit or something and Transmission Control Unit (or something?).....
Old 05-17-2001, 09:14 PM   #11
credit xtc
Member#: 5221
m3 540it, xt-6 sc
Post
my point is it changes the shift points.
Old 05-17-2001, 11:00 PM   #12
tygab
Member#: 5791
02 wrx wagon
shiny silver
Post
Ok, but does the 4EAT come "preprogrammed" in grandma-mode or do you HAVE to reset the ECU to gain the benefits of this?
i.e. is it always learning, or does it learn "enough" and then stops there? let's say I flog it as much as possible in a week's time - or I get stuck driving in city traffic for whatever amount of time. Does it then adapt and stick with sort of the most recent pattern?
-T
tygab is offline   Reply With Quote
Old 05-18-2001, 12:12 PM   #13
bluesubie
Member#: 767
04 FXT
Post
ECU = Engine Control Unit (although the proper Subaru term is ECModule)
TCU = I think you got that one right.
There was an article in a past Drive magazine about our learning ECU's. You might be able to find it through Subaru.com or if you have back issues from a year or so ago.
Dennis
Old 05-18-2001, 12:21 PM   #14
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
I agree with subiegal. The ECU learns your driving habits and seems to adjust shift points and fuel/air mixture.
After an ECU reset I notice a huge difference in how/where the car shifts gears.
remarcable is offline   Reply With Quote
Old 05-18-2001, 12:44 PM   #15
inpreza kid
Member#: 3334
Post
according to my driving habits my car usually shifts around 4500rpm. after a ecu reset i noticed that it shifted really quick for a short time. i would say the ECU has alot to do with the TCU. just wondering but where is the TCU located ? i know the ECU is under the carpet in front of the passenger side.
inpreza kid is offline   Reply With Quote
When is an ECU reset no longer needed? Thunder Lungs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 01:43 PM
Can you do an ecu reset with the utec still plugged in? waitandbleed92 Engine Management & Tuning 4 03-31-2003 04:49 PM
Easy way to do an ECU reset. omahasubaru Normally Aspirated Powertrain 2 08-31-2001 08:49 PM
('93-'01) If I do an ECU reset will it erase the datalogging? aarneson Impreza Forum 7 06-26-2001 11:47 PM
ecu reset after the mid pipe? jacktam1 Normally Aspirated Powertrain 1 03-13-2001 04:44 AM
