Tire & Wheel Forum sponsored by The Tire Rack |
09-09-2011, 02:02 PM | #1 |
Member#: 12029
Master thread of OEM Subaru Wheel Specs
I intend for this thread to be a comprehensive database of Subaru OEM (original equipment manufacturer) wheels. I'll give as much info as I can about each wheel, and a picture of each.
There is an older thread like this, but it looks like it's no longer maintained, and it never did have any images. Please keep this thread to wheel specifications ONLY. Please do NOT ask or answer questions here about what wheels fit on what cars, or what's the best wheel for your car. Ask those in another thread, or start your own thread. If you have solid information about any of these wheels, please post and I'll update the entries as needed. Ideally, I'd like to see wheel weights derived from an actual wheel sitting on a calibrated scale. (That means something like a shipping scale, not a home bathroom scale.) In the absence of that, we'll take what we can get. All wheels are CAST aluminum unless otherwise noted. All are 56.1mm centerbore. (I don't plan to list Subaru SVX wheels here, but they are 57.1mm centerbore.) Also, all 18" STI wheels will fit both four-piston and six-piston STI Brembo brakes, but the 2018 19" STI wheels will not fit over four-piston STI Brembos. If not otherwise noted, wheels do NOT clear Brembos. Model years shown are my best attempt at showing the FIRST model year the wheel appeared, not EVERY year they appeared. Please feel free to post additional information here. I'll list everything back to the GC-chassis wheels if we can get all the info together. View the new CVS weekly ad for BOGOs, coupons, and pharmacy deals. In rough chronological order: 98-99 Impreza 2.5RS Size: 16x7" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 16.5 lbs OEM-equipped tire size: 205/55R16 Notes: Clears FHI (red) four-pots 2000-01 Impreza 2.5RS Size: 16x7" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 16 lbs OEM-equipped tire size: 205/55R16 Notes: Clears FHI (red) four-pots 2002-04 Impreza Size: 16x6.5" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 16.5 lbs OEM-equipped tire size: 205/55R16 2002-04 WRX Size: 16x6.5" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 16.5 lbs OEM-equipped tire size: 205/55R16 Saab 9-2X Aero 16" wheel Size: 16x6.5" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 16.5 pounds (verify) OEM-equipped tire size: 205/55R16 Saab 9-2X Aero 17" wheel Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: ? pounds (need weight) OEM-equipped tire size: 215/45R17 2002-04 WRX BBS option Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 15 lbs. (forged) OEM-equipped tire size: 215/45R17 JDM/EDM 2004 WRX Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 19 lbs OEM-equipped tire size: 225/45R17? Notes: Clears FHI (red) four-pots 2005 WRX Size: 16x6.5" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 16.5 lbs OEM-equipped tire size: 205/55R16 2005-06 Impreza Size: 16x6.5" Offset: +55 Bolt pattern: 5x100 Wheel Weight: ? OEM-equipped tire size: 205/55R16
09-09-2011, 02:02 PM | #2 |
Member#: 12029
BBS RK (Optional for Saab 9-2X, WRX) Size: 17x7" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 18.08 lbs (weighed by Amakirr) OEM-equipped tire size: 215/45R17 JDM/EDM STi version 7 Size: 17x7.5" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 17.5 lbs OEM-equipped tire size: 225/45R17? 2006-07 WRX Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 21.0 lbs (Mach V shipping scale) OEM-equipped tire size: 215/45R17 2004 WRX STi BBS Size: 17x7.5" Offset: +53 Bolt pattern: 5x100 Wheel Weight: 15.7 lbs (forged) OEM-equipped tire size: 225/45R17 2005-07 WRX STI BBS Size: 17x8" Offset: +53 Bolt pattern: 5x114.3 Wheel Weight: 19.55 lbs (forged) OEM-equipped tire size: 225/45R17 2007 WRX STI Limited Enkei Size: 17x8" Offset: +53 Bolt pattern: 5x114.3 Wheel Weight: 21.2 lbs OEM-equipped tire size: 235/45R17 2008 Outback Sport Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 22.6 lbs OEM-equipped tire size: 205/50R17 2008 2.5i Impreza Size: 16x6.5 inch Offset: +55 Bolt pattern: 5X100 Wheel Weight: 20.2 lbs OEM-equipped tire size: 205/55R16 2008-2010 WRX Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 23.2 lbs OEM-equipped tire size: 205/50R17 (2008), 225/45R17 (2009-10) Notes: Clears four-pots 2008 STi five-spoke Size: 18x8.5" Offset: +55 Bolt pattern: 5x114.3 Wheel Weight: 27.5 lbs (thanks to NASIOC user Kostasdh for the weight) OEM-equipped tire size: 245/40R18 Last edited by Mach V Dan; 09-01-2020 at 12:53 PM. |
09-09-2011, 02:02 PM | #3 |
Member#: 12029
2008-2014 STi BBS Size: 18x8.5" Offset: +55 Bolt pattern: 5x114.3 Wheel Weight: 20.5 lbs (forged) OEM-equipped tire size: 245/40R18 2011-2014 WRX Size: 17x8" Offset: +53 Bolt pattern: 5x100 Weight: 21 lbs (by shipping scale -- see post #206) OEM-equipped tire size: 235/45R17 Notes: Clears four-pots 2011 STi Enkei Size: 18x8.5" Offset: +55 Bolt pattern: 5x114.3 Wheel Weight: 23.55 lbs (thanks to NASIOC member nashelton) OEM-equipped tire size: 245/40R18 Notes: This wheel was also offered on the 2010 STI Special Edition, in a darker color. 2012 Impreza Sport Size: 17x7" Offset: +48 Bolt pattern: 5x100 Weight: 24.x lbs (Postal scale - post #381) OEM-equipped tire size: 205/50R17 2012 Impreza Premium Size: 16x6.5" Offset: +48 Bolt pattern: 5x100 Weight: 16 lbs (postal scale - post #208) OEM-equipped tire size: 205/55R16 2012 Impreza Limited Size: 17x7" Offset: +48 Bolt pattern: 5x100 Weight: ? OEM-equipped tire size: 205/50R17 2012-2014 STI, 2016-2017 Premium/Limited WRX, made by Enkei Size: 18x8.5" Offset: +55 Bolt pattern: 5x114 Wheel Weight: 26.6 pounds OEM-equipped tire size: 245/40R18 2018 STI (non-BBS) Size: 19x8.5" Offset: +55 Bolt pattern: 5x114 Wheel Weight: 28.4 lbs (Myles at Racecomp Engineering, HERE) OEM-equipped tire size: 245/35R19 Does NOT clear pre-2018 Brembos. 1998 22B BBS Size: 17x8.5" Offset: +48 Bolt pattern: 5x100 Wheel Weight: ? (forged) OEM-equipped tire size: 235/40R17 2018 STI Type RA BBS Size: 19x8.5" Offset: +55 Bolt pattern: 5x114 Wheel Weight: 24.1 lbs (Mach V shipping scale) (forged) OEM-equipped tire size: 245/35R19 There's also a bronze version from the 2020 Series.White STI. Note: The S209 gets a 9" wide version of this wheel, available in gold and gunmetal gray. 2019 STI S209 BBS Size: 19x9.0" Offset: +48 Bolt pattern: 5x114 Wheel Weight: 25 lbs (bathroom scale estimate) (forged) OEM-equipped tire size: 265/35R19 Last edited by Mach V Dan; 02-14-2021 at 01:55 PM. |
09-09-2011, 02:03 PM | #4 |
Member#: 12029
1997-2004 Legacy GT Size: 16x6.5" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 20 pounds OEM-equipped tire size: 205/55R16 2005-06 Legacy GT Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 20.5 pounds (need verification) OEM-equipped tire size: 215/45R17 2006-07 Legacy Spec B Size: 18x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 21 pounds (estimated) OEM-equipped tire size: 215/45R18 2006-07 Outback Size: 17x7" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 20 pounds OEM-equipped tire size: 225/55R17 2007-09 Legacy GT Size: 17x7 Offset: +55 Bolt Pattern: 5x100 Weight: 23.4 pounds (mrwillig) OEM tire size: 215/45R17 2008 Outback XT/LL Bean Size: 17x7" Offset: +48 Bolt pattern: 5x100 Wheel Weight: ? OEM-equipped tire size: 225/55R17 2008-09 Legacy GT Spec B Size: 18x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 25.5 pounds OEM-equipped tire size: 215/45R18 JDM Legacy B4 Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 18 pounds OEM-equipped tire size: 215/45R17? 2010 Legacy GT Size: 18x7.5" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 25.4 pounds OEM-equipped tire size: 225/45R18 2016 Outback Size: 18x7.0" Offset: +55 Bolt pattern: 5x114 Wheel Weight: 23.9 pounds (Mach V shipping scale) OEM-equipped tire size: 225/60R18 Notes: Enkei MAT construction Last edited by Mach V Dan; 07-24-2019 at 03:22 PM. |
09-09-2011, 02:03 PM | #5 |
Member#: 12029
2013 BRZ (and FR-S) Size: 17x7.0" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 20.1 pounds (need verification) OEM-equipped tire size: 215/45R17 Notes: Does not clear FHI four-pot front brakes Need photo. 2013 Legacy steelie Size: 16x6.5" Offset: ? Bolt pattern: 5x100 Wheel Weight: 22 pounds (estimated) OEM-equipped tire size: 205/60R16 Notes: Does not clear FHI four-pot front brakes 2013 Crosstrek XV alloy Size: 17x7.0" Offset: +48 Bolt pattern: 5x100 Wheel Weight: Unknown, but looks heavy OEM-equipped tire size: 225/55R17 JDM Legacy B4 Blitzen 17x7 5x100 55mm offset 21.5 lbs (bathroom scale) 2002-2004 Forester XT Size: 16x6.5" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 19 lb (bathroom scale) OEM-equipped tire size: 215/60-16 2005-06 Forester XS Size: 16 x 6.5" Offset: +48 Bolt pattern: 5x100 Weight: 20 pounds OEM-equipped tire size: 215/60 R16 94H all-season tires 2007 Forester XT Size: 17"x7" Offset: +48 Bolt pattern: 5x100 Wheel Weight: ? OEM-equipped tire size: 215/55R17 2008 Forester Sports XT Size: 17"x7 Offset: +48 Bolt pattern: 5x100 Wheel Weight: 20.8 lbs OEM-equipped tire size: 215/55R17 SG Forester STI Size: 18.7.5" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 26.2 lbs OEM-equipped tire size: 225/45R18 Clears 4-pot Brembos 2009 Forester XT 17x7" Offset: +48 Bolt Pattern: 5x100 weight: 22.9 lbs with TPMS sensor and some wheel weights. 2014 Forester XT Size: 18 x 7" Offset: +48 Bolt pattern: 5x100 OEM Tires: 225/55 R18 97H all-season tires Weight: Unknown OEM-equipped tire size: 225/55 R18 97H all-season Last edited by Mach V Dan; 10-13-2017 at 03:09 PM. |
09-09-2011, 02:03 PM | #6 |
Member#: 12029
95 Impreza factory option Size: 15x6 Offset: +55 Bolt pattern: 5x100 Weight: 14.5 - 15 lbs. each. OEM-equipped tire size: 205/55R15 2006-07 Impreza 2.5i Size: 16.6.5 Offset: +55 Bolt pattern: 5x100 Weight: 17.7 lbs. (estimated - see post #212) OEM-equipped tire size: 205/55R16 1996-1998 JDM Legacy Twin Turbo GT-B Wagon (BG chassis) and TS-R Sedan (BD chassis) Size: 17x7" Offset: +53 Bolt Pattern: 5x100 Wheel Weight: 17.8 lbs OEM-equipped tire size: 215/45R17 2013 Legacy Size: 17x7.5" Offset: +48 Bolt Pattern: 5x100 Wheel Weight: ? OEM-equipped tire size: 215/50-17 2015-2021 WRX (base model only in later years) Size: 17x8" Offset: +55 Bolt Pattern: 5x114 Wheel Weight: 23.2 lbs (Post 428) OEM-equipped tire size: 235/45-17 2018-2021 WRX Size: 18x8.5" Offset: +55 Bolt Pattern: 5x114 Wheel Weight: 24.46 lbs (Post 489) OEM-equipped tire size: 245/40-18 Clears 6-pot Brembos. There are two versions of this wheel style. The 2018-2019 version does NOT clear 4-pot Brembos; the 2020+ version DOES. They are NOT identical, although the appearance is very similar between the two versions. 2015 STI BBS Size: 18x8.5" Offset: +55 Bolt Pattern: 5x114 Wheel Weight: 22.1 lbs (forged) OEM-equipped tire size: 245/40-18 Available in silver, gold, and gloss black. 2015 STI Non-BBS (Enkei) Size: 18x8.5" Offset: +55 Bolt Pattern: 5x114 Wheel Weight: 23.72 lbs (post 628) OEM-equipped tire size: 245/40-18 2016+ Factory-option Sport Package STI Wheel (Enkei) Size: 18x8.5" Offset: +55 Bolt Pattern: 5x114 Wheel Weight: 22.2 lbs OEM-equipped tire size: 245/40-18 The wheel above is also available in a 17" size for BRZ (7.5" width) and Forester (7" width) Size: 17x7" (Forester fitment) Offset: +48 Bolt Pattern: 5x100 Wheel Weight: 18.2 lbs (post 465) OEM-equipped tire size: 225/55R17 Last edited by Mach V Dan; 04-19-2021 at 12:33 PM. |
09-09-2011, 07:43 PM | #7 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
i like it, thanks dan!
09-28-2011, 12:24 PM | #8 |
Member#: 232409
Vehicle:2005 9-2x Brilliant Red |
Sticky!!!
09-29-2011, 02:16 PM | #9 |
Member#: 263667
SCIC
Vehicle:2002 WRX Sedan Wrb |
Any info on the 06-07 impreza 2.5i wheels? My wrx came with those when I bought it
09-30-2011, 11:36 PM | #10 |
Member#: 50586
BAIC
Vehicle:64 Impala |
can we get jdm subaru wheel specs in here too???
10-02-2011, 03:43 PM | #11 |
Member#: 258761
How about OBS wheels?
10-04-2011, 10:11 AM | #12 | |
Member#: 12029
Sure. Post 'em up, and I'll update the top post(s). Sure. Got a source for wheel info? --Dan Mach V |
10-08-2011, 07:27 AM | #13 |
Member#: 174080
Looking for JDM specs
10-08-2011, 12:15 PM | #14 |
Member#: 296764
TXIC
Vehicle:2008 WRX STI Charcoal Gray |
do not circumvent the classifieds.
10-12-2011, 08:02 PM | #15 |
Member#: 240772
Vehicle:2011 Impreza 2.5i Spark Silver Metallic |
Can you add the 2011 2.5i wheel specs?
10-17-2011, 08:11 PM | #16 |
Member#: 94542
RMIC
Vehicle:2002 WRX wagon WRB |
04 forester xt wheels?
10-19-2011, 12:16 PM | #17 |
Member#: 12029
Okay. I've done a lot of research for the information shown here, but I'm not some kind of all-seeing, all-knowing wise man. Most of the information above, I FOUND ON THE INTERNET. Got a wheel that is not listed here, that you want to know the weight and other information? Use Google, and track down the answers to your question. Report back here, and tell us what you found. I'll update the thread accordingly.
Or, you can call me and pay me to do research for you. I'd be okay with that. --Dan Mach V FastWRX.com |
10-21-2011, 07:50 PM | #18 |
Member#: 197937
E. Canada
Vehicle:2016 Golf R Under the radar silver |
This may help to fill in some blanks, from 3GWRX.com:
2008 2.5i Impreza (Premium alloys, not steelies with hubcaps): 16x6.5 inch wheels, 55mm offset, 5 X 100 bolt pattern Wheels with Tire pressure sensor (with no tires) weigh approximately 20.2 lbs each ------------------------------------ 2008 WRX Impreza 17x7 inch wheels, 55mm offset, 5 X 100 bolt pattern Wheels with Tire Pressure Sensor (with no tires) weigh approximately 23.2 lbs each ---------------------- 2008 WRX STI 18x8.5 inch alloys, 5 X 114.3 bolt pattern Standard wheel: 55mm offset, 25 lbs Optional BBS wheel: 55mm offset, 20.5 lbs |
10-24-2011, 09:35 AM | #19 |
Member#: 12029
Thanks. Updated. I think the 2008 STI five-spoke weight estimate is too low, though. I saw another listing at 27.5 pounds, which I think is closer to correct.
11-01-2011, 06:45 PM | #20 |
Member#: 237756
Vehicle:2011 2.5i Sedan DGM |
More OEM wheel info that can be added... http://www.subaruforester.org/vbulle...orester-19106/
11-28-2011, 08:33 PM | #21 |
Member#: 302236
Vehicle:2005 STi WRB - sold :( |
any idea what color the 2005 wrx 16x6.5 is? bronze, off-gold...
11-28-2011, 09:35 PM | #22 |
Member#: 97135
NWIC
11-29-2011, 02:45 AM | #23 |
Member#: 292537
Vehicle:2004 STi WRB |
11-29-2011, 04:00 AM | #24 |
Member#: 97135
NWIC
Nope.
11-29-2011, 07:43 AM | #25 |
Member#: 298119
What....no UK wrx 17's?
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels | MR2fanatic | Tri-State Area Private Classifieds | 7 | 04-03-2011 09:24 PM |
WTT: OEM subaru wheels/tires for Gold 17" wheels | veselik3 | NWIC Private Classifieds | 2 | 05-16-2006 03:24 PM |
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels | anthonyrb98 | Private 'For Sale' Classifieds | 53 | 04-27-2006 12:43 PM |
Anyone have a set of OEM WRX wheels they want to get rid of? | Skibum4444 | North West Impreza Club Forum -- NWIC | 2 | 01-31-2003 12:48 AM |
Subaru Wheel Specs | Snowrider | Brakes, Steering & Suspension | 3 | 10-07-2001 09:20 PM |
