Old 03-18-2014, 02:28 PM   #251
silverf0x
Member#: 147664
2015 WRX Limited
Anything for the 2015 WRX yet?
silverf0x is offline   Reply With Quote
Old 03-19-2014, 11:49 AM   #252
Frankie Vanhooken
Member#: 385054
Originally Posted by haven View Post
So will the
BBS RK (Optional for Saab 9-2X, WRX)
Offset: +48
Fit an '06 wrx without problems?
If you mean "Will it clear FHI 4 pots?" Nope!
I have that set up on my 02 wrx, and needed a 3 mm spacer.
Can someone counter verify this on an actual 06 wrx?
And Mach V Dan, just a thought to keep this thread the way you meant it to be, perhaps a link to a new thread called something like " Will it fit my car?" next to each wheels would filter.... some FAQ!
But what do I know... I'm the newbie!!!
Great initiative from your part, lots of usefull info. Keep on the good work!
Frankie Vanhooken is offline   Reply With Quote
Old 03-25-2014, 01:00 PM   #253
Mach V Dan
Member#: 12029
Originally Posted by subaroket View Post
Mach V Dan : Although this thread is focused on alloy wheels I would like if you added the new 17 inch steel specifications. Base model 2014 and up Forester got these new 17 inch wheels.
Okay. Got specs for them?
Originally Posted by Garbels90 View Post
Mach V,
the 2004 wrx jdm/edm rims. is there a color code as to that rim?
I do not know the answer to that and I don't want to go into that in this thread.
Also, PLEASE do not quote entire columns of pictures from my original posts! It's not necessary and makes it very hard to read through.
We know the wheel size and bolt pattern, but nothing else yet.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 03-25-2014, 01:51 PM   #254
lakeguy1344
Member#: 385690
My wife drives a 2013 Impreza, I'd like to get a new set of rims and tires for summer. Car came with 17 205 tires. I am wondering if I get 18 225 wider tires make the steering wheel heavier. I'd appreciate it if someone with some experiment can answer.
thanks,
lakeguy1344 is offline   Reply With Quote
Old 03-25-2014, 04:14 PM   #255
Mach V Dan
Member#: 12029
thanks,
I'm going to repeat myself, but PLEASE ask these questions elsewhere. I intended this to be a database of specifications ONLY. There's an entire Wheel and Tire forum for fitment questions, and other questions about modifying the car.
--Dan
Mach V
FastWRX.com
Old 03-25-2014, 04:21 PM   #256
iRomey
Member#: 254547
Don't forget to add these to the list!
Originally Posted by iRomey View Post
I don't think this has been added to the list-
STi Rays TE07
16x7 +53
6.3kg/13.88lbs
Only found on certain model trim v6 STi's
iRomey is offline   Reply With Quote
Old 03-25-2014, 04:40 PM   #257
YouRock22
Member#: 373897
07 Impreza
newport blue
thanks,
The steering wheel will be as heavy (or light) as before, as long as you don't change the steering wheel.
Most 18 inch wheels will be heavier than same model 17 inch wheels. However, I'm sure it should be possible to find lighter 18s than some 17s. Will lighter wheels make steering feel lighter? I don't know...
If you are going up a size (17 to 18) keep in mind that you need to keep the overall wheel+tire diameter as close to stock as possible to avoid speedometer reading errors, etc.
YouRock22 is offline   Reply With Quote
Old 03-26-2014, 03:17 PM   #258
bagelswrx
Member#: 366626
Where can i find aftermarket replacement lugs , ive done the reading an know the taper from oem to custom is different. I would like a nice set of open end style lugs for my car. Can you please point me in the right direction.
Thank you
Bagel
bagelswrx is offline   Reply With Quote
Old 03-26-2014, 03:36 PM   #259
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
^^^^ PM'd you. Not a relevant thread question.
Old 03-29-2014, 05:45 AM   #260
Kamakakoi
Member#: 386091
Kamakakoi is offline   Reply With Quote
Old 03-29-2014, 09:21 PM   #261
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
^^^those are tight.. What year?
kantthinkofasn77 is offline   Reply With Quote
Old 03-31-2014, 09:20 AM   #262
AFP520
Member#: 102932
2014 STI Sedan
Looks like they are from a '15 STI. Here is another side shot (not me or my car)
AFP520 is offline   Reply With Quote
Old 04-04-2014, 10:27 AM   #263
fredzy
Member#: 317270
15 WRX, WRB 6MT
14 CX-5
Originally Posted by Kamakakoi View Post
I ordered a set of these for my '15 WRX, and should have a weight for them soon.
2015 WRX STI Base Model
18X8.5 ET55, 5X114.3
Tire size 245/40R18
Weight: probably not going to be light
fredzy is offline   Reply With Quote
Old 04-04-2014, 04:25 PM   #264
AFP520
Member#: 102932
2014 STI Sedan
Can I ask what they set you back?
Old 04-05-2014, 02:27 AM   #265
blum3416
Member#: 375035
2015 WRX
If you go to eBay under heurberger motors, they have them posted. They are about $1300 shipped, but if you type the order number into google you can get a set of 4 for about $1200 shipped. I inquired about them earlier and they weighed them and stated it weighed 24#'s. It's accurate since they placed it on their scale to weigh.
blum3416 is offline   Reply With Quote
Old 04-08-2014, 12:17 AM   #266
Mach V Dan
Member#: 12029
STi Rays TE07
Offset: +53
Bolt Pattern: 5x100
Wheel weight: 13.88 lbs
OEM-equipped tire size: 205/50R16
Old 04-08-2014, 01:05 AM   #267
iRomey
Member#: 254547
Originally Posted by Mach V Dan View Post
STi Rays TE07 Size: 16x7" Offset: +53 Bolt Pattern: 5x100 Wheel weight: 13.88 lbs OEM-equipped tire size: 205/55R16 (?)
205/50/R16. Everything else is correct!
Old 04-10-2014, 09:46 AM   #268
fredzy
Member#: 317270
15 WRX, WRB 6MT
14 CX-5
$1300 shipped, with center caps included. I did find some random parts places showing them for a bit less. I inquired, but no center caps. Which can be expensive.
Enkei MAT technology wheel, average weight of the 4 wheels 24.25 lbs.
Old 04-10-2014, 10:38 AM   #269
AFP520
Member#: 102932
2014 STI Sedan
They look pretty damn nice man. Not sure I would drop $1,300 for them. Probably find them much cheaper as more are sold and guys look to swap them.
Old 04-10-2014, 01:06 PM   #270
Sublimejoe
Member#: 74722
06 RHD Legacy BF
Question for you guys, these wheels came on my 93 rhd Legacy, anyone know if they are OEM or aftermarket?
Edit: Found some info and these are them:
Sublimejoe is offline   Reply With Quote
Old 04-10-2014, 03:24 PM   #271
mrz415
Member#: 334988
2015 Subaru WRX(CVT)
Ice Silver Metallic (ISM)
17x8 on 235/17R45
5x114
wheel weight is like 24 lbs
I did not check ET tho . . .
but the set-up is needs to be
1 inch further out/lowered to be FLUSHed.
mrz415 is offline   Reply With Quote
Old 04-13-2014, 08:58 PM   #272
jonoc4
Member#: 387455
2015 WRX Limited
Crystal White Pearl
Default 2015 wrx rims
2015 WRX
Offset: 55
Bolt Pattern: 5x114
Wheel Weight: 24lbs
OEM-equipped tire size: 235/45-17
jonoc4 is offline   Reply With Quote
Old 04-18-2014, 01:33 PM   #273
Aaron W
Member#: 387016
2015 WRX
Lightning Red
Has anyone been able to find any info on the 2015 WRX black sport package 17x8s? I'm specifically looking for the weight, but can't seem to locate it on Subaru's site anywhere.
Aaron W is offline   Reply With Quote
Old 04-29-2014, 01:16 PM   #274
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
2015 WRX
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 22.2lbs
04jaxwrex is offline   Reply With Quote
Old 04-29-2014, 05:28 PM   #275
Mach V Dan
Member#: 12029
Originally Posted by jonoc4 View Post
Wheel Weight: 24lbs
Okay. Sources, you two?
--Dan
Mach V
FastWRX.com
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
