Old 02-01-2012, 02:21 AM   #51
I3eXa
Member#: 30732
2002 Legacy GT, 2004
Impreza OBS
I assumed so but wanted to make sure.
Thanks. and kudos on a good thread!
I3eXa is offline   Reply With Quote
Old 02-01-2012, 09:55 AM   #52
lemayilleur
Member#: 300914
2010 WRX Hatch
Grey
I'll just dump what I found during my deep research 2 weeks ago. I'm not 100% sure, but maybe it can help I don't know.
OEM 2010 WRX (none STI if that matters)
5x100
17x7 +55
225/45 R17
OEM 2004 WRX (none STI if that matters)
5x100
16x6.5 +53
205/55 R16
lemayilleur is offline   Reply With Quote
Old 02-23-2012, 11:30 AM   #53
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
great list
Louie is offline   Reply With Quote
Old 02-24-2012, 09:43 AM   #54
Mr.Anderson
Member#: 200857
2013 FX4 EcoBeast
Can anyone find specs on the 2012 STi sport tech rims?
Mr.Anderson is offline   Reply With Quote
Old 02-24-2012, 11:15 AM   #55
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
What do they look like?
Old 02-24-2012, 11:16 AM   #56
highwayman
Member#: 100697
06 STI
CGM
Very helpful.
highwayman is offline   Reply With Quote
Old 03-06-2012, 08:37 AM   #57
Mach V Dan
Member#: 12029
You mean the standard non-BBS wheel for the 2012 STI?
I've added that. Don't know the weight yet.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 03-31-2012, 06:22 AM   #58
Treggies
Member#: 218496
2009 Impreza WRX
Mica Blue
Great Job...very informative.
Treggies is offline   Reply With Quote
Old 04-04-2012, 10:36 AM   #59
VolkFreak
Member#: 48556
2008 R32 #3528
CW
Is the center bore the same for all suby wheels ? (56.1)
VolkFreak is offline   Reply With Quote
Old 04-04-2012, 12:11 PM   #60
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Stock 2006 2.5i 5-spokes are 16x6.5. I should have checked the offset when I had one off on Saturday.
Counterfit is offline   Reply With Quote
Old 04-05-2012, 11:03 PM   #61
Mach V Dan
Member#: 12029
To date, yes. Very old models (pre 1990's?) might be an exception.
Good info, thanks.
--Dan
Mach V
FastWRX.com
Old 04-08-2012, 08:03 PM   #62
Swansey
Member#: 312683
2007 Legacy Spec. B
Diamond Grey Mattalic
Thanks for the info, planning on buying a new STI soon and I was wondering if the 07 BBS rims would fit.
Swansey is offline   Reply With Quote
Old 04-26-2012, 07:47 AM   #63
prostheticgti
Member#: 259605
2010 Impreza
white
very nice
prostheticgti is offline   Reply With Quote
Old 05-08-2012, 02:13 PM   #64
bgoulet10
Member#: 319499
2008 Impreze 2.5i
Dark Grey
With regards to this post will the 2008 WRX 17x7 inch wheels fit my 2008 2.5i Impreza? I currently have 16x6.5 inch steelies and am looking to upgrade.
2008 2.5i Impreza (Premium alloys, not steelies with hubcaps):
16x6.5 inch wheels, 55mm offset, 5 X 100 bolt pattern
Wheels with Tire pressure sensor (with no tires) weigh approximately 20.2 lbs each
2008 WRX Impreza
17x7 inch wheels, 55mm offset, 5 X 100 bolt pattern
Wheels with Tire Pressure Sensor (with no tires) weigh approximately 23.2 lbs each
bgoulet10 is offline   Reply With Quote
Old 05-08-2012, 08:41 PM   #65
sc00by4life
Member#: 97135
2008 WRX Impreza
Wrong theead, but yes.....
Old 05-09-2012, 09:46 AM   #66
bgoulet10
Member#: 319499
2008 Impreze 2.5i
Dark Grey
I pulled the info off the first page of the thread so I assumed it was the correct one. But thank you, much appreciated.
Old 05-09-2012, 11:37 AM   #67
Mach V Dan
Member#: 12029
There are other threads regarding what wheels fit on what cars. Please limit this thread to actual specifications of OEM wheels, and nothing else.
--Dan
Mach V
FastWRX.com
Old 05-10-2012, 08:27 AM   #68
SYWAGON
Member#: 144362
BBS RK 028 - hard to say when it was an option on the WRX, but clearly an option on Saabaru.
http://forums.nasioc.com/forums/show....php?t=2289992
http://saab92x.com/viewtopic.php?id=14695
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 16.2-18 lbs depending where you read.
OEM-equipped tire size: ?
They are "one piece counter pressure cast".
SYWAGON is offline   Reply With Quote
Old 05-10-2012, 12:15 PM   #69
mpb6990
Member#: 315945
Any info on the 15x6 alloys from MY98 Impreza?
mpb6990 is offline   Reply With Quote
Old 05-25-2012, 10:56 PM   #70
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Any update on the offset and weight of the 2012 non WRX/STI wheels?
jr0bb5 is offline   Reply With Quote
Old 05-25-2012, 11:10 PM   #71
sc00by4life
Member#: 97135
You talking about the impreza wheels?
Old 05-25-2012, 11:31 PM   #72
jr0bb5
Member#: 315353
5MT OBP/DGM
Yes, sorry I didn't specify
Old 05-29-2012, 02:14 AM   #73
skater4ever11
Member#: 320913
2012 Impreza WRX
Satin White Pearl
Default new to subaru!
i have a 2012 impreza wrx premium, but i cant seem to find the thread pattern for new lugnuts..is it 12x1.25? or something else? also, what are the best brands to get (without breaking my bank)? im looking for red ones, preferably closed ended, and under 100 bucks if possible. suggestions anyone??
ps ill have lots of pics of my new car up soon
skater4ever11 is offline   Reply With Quote
Old 05-29-2012, 04:22 AM   #74
mcthaniel06
Member#: 238298
1996 Impreza Outback
Navy blue/Slate gray
With the exception of the finish appearing to be a bit darker, the wheel listed as "2005 WRX" looks just like the wheel from a 2005 Legacy. If my observation is correct, can I assume that the specs will be the same, or at least similar?
mcthaniel06 is offline   Reply With Quote
Old 05-29-2012, 10:46 AM   #75
Mach V Dan
Member#: 12029
Yes.
Please discuss this in another thread. This thread is about OEM wheels specs, only.
I'm not sure which wheels you mean. Can you quote the appropriate picture(s)?
--Dan
Mach V
FastWRX.com
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
