Old 11-25-2013, 03:43 PM   #201
vladsti11
Member#: 365312
2011 STI
Sweet write up thanks!
vladsti11 is offline   Reply With Quote
Old 11-26-2013, 01:29 PM   #202
RSTI-FTW
Member#: 242077
1999 2.5RS
post deleted!
RSTI-FTW is offline   Reply With Quote
Old 11-26-2013, 04:45 PM   #203
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
^^^This thread is designed more as a database for rim specifications not so much as a thread for will this fit on my car.. Just letting you know if no one gives you an answer or decides its prick day and chews you out for your question. I also do not know the answer to your question. Im sure you can search it though. Nasioc is loaded w/ info
kantthinkofasn77 is offline   Reply With Quote
Old 12-02-2013, 12:06 PM   #204
RSTI-FTW
Member#: 242077
1999 2.5RS
^Thanks! I'll delete the post. I searched through the aggressive wheel fitment thread but its mostly wheel set ups designed to maximize traction.
Old 12-07-2013, 03:31 PM   #205
elGordo
Member#: 26316
2014 WRX
Default Offset for 2014 WRX rims?
This thread is a great resource! Not terribly surprised that the 2014 WRX isn't listed because the model year is pretty new.
I have a set of Black Racing Pro N1 17x7.5 with +48 offset from my former 2002 WRX, and I am thinking of using them to mount winter tires for my 2014.
Does anyone have the offset for the original equipment 17x8 rims on the 2014? I need to figure out whether my rims will work on the '14.
Thanks!
elGordo is offline   Reply With Quote
Old 12-07-2013, 04:14 PM   #206
sc00by4life
Member#: 97135
Originally Posted by elGordo View Post
This thread is a great resource! Not terribly surprised that the 2014 WRX isn't listed because the model year is pretty new. I have a set of Black Racing Pro N1 17x7.5 with +48 offset from my former 2002 WRX, and I am thinking of using them to mount winter tires for my 2014. Does anyone have the offset for the original equipment 17x8 rims on the 2014? I need to figure out whether my rims will work on the '14. Thanks!
2014 is identical to the 2011-2013 wrx.
Old 12-13-2013, 02:59 AM   #207
shaowQ
Member#: 225500
2013 WRB WRX Sedan
11 Mazda 2
If anyone is wondering, 2011+ WRX wheels i took one without the tire to work today and put it on the shipping scale.
Confirmed at 21 pounds
shaowQ is offline   Reply With Quote
Old 12-13-2013, 11:56 AM   #208
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
ugh, why Subaru?
EVL RS-T is offline   Reply With Quote
Old 12-18-2013, 12:05 AM   #209
Sticman
Member#: 317244
12 Impreza
2012 Impreza Premium
Offset: +48
Bolt pattern: 5x100
Weight: 18.6 (estimate)
OEM-equipped tire size: 205/55R16
Just weighed a rim today and my scale came back at 15 lbs even with wheel weights, tpms and valve stem. I'm going to verify this on a different scale thought.
Edited: weighed on a postal scale at 16lbs oz.
Sticman is online now   Reply With Quote
Old 12-21-2013, 02:30 PM   #210
TBolt1003
Member#: 302874
1995 Impreza L wagon
I am looking at a set of the 2002-2005 Impreza and WRX wheels that are on page-1 of this thread. Both are identical dimension-wise, except for the offset. The Impreza has a +55, while the WRX has a +53.
The stock steel wheels on my 95 Impreza wagon are +55 and I've chosen to use these now solely as my winter tire wheels. I will not swapping tires anymore, so looking at the wheels I mentioned above for my spring-fall tires.
Will the +53 wheels fit fine on my Impreza or should I stick with the +55? I can't see it being an issue, but wanted to check before I go after either wheel choice. Thanks!
TBolt1003 is offline   Reply With Quote
Old 12-21-2013, 02:47 PM   #211
sc00by4life
Member#: 97135
think about how big 2mm actually is then you'll have your answer .
Old 12-21-2013, 02:57 PM   #212
TBolt1003
Member#: 302874
I know, and I was actually hesitant about asking, but I'd rather be safe than sorry. Didn't know if there was a reason for the difference between the wheel for the Impreza and the one for the WRX. Thanks for helping me answer my own question.
Old 12-21-2013, 08:11 PM   #213
amcn831
Member#: 235777
2000 RS BuRP
2007 2.5i CGM
Not sure of it's been posted but I didn't see it on the original lineup. 06-07 Impreza 2.5i OEM wheels by Enkei 16x6.5 et55 Don't have them measured separately but the OEM Potenza RE92A weighs 21 lbs per the Bridgestone site and the combined weight is 38.7 lbs. So I'd say the wheel weight is around 17.7 lbs. References:
amcn831 is offline   Reply With Quote
Old 12-21-2013, 08:25 PM   #214
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Originally Posted by amcn831 View Post
Not sure of it's been posted but I didn't see it on the original lineup. 06-07 Impreza 2.5i OEM wheels by Enkei 16x6.5 et55 Don't have them measured separately but the OEM Potenza RE92A weighs 21 lbs per the Bridgestone site and the combined weight is 38.7 lbs. So I'd say the wheel weight is around 16.7 lbs. References:
It has, but you did a much better job.
Originally Posted by Counterfit View Post
Those are not the wheels that came with my car. Mine look like this: gtcarlot.com/data/Subaru/Impreza/2006/573171/Wheel.html
Originally Posted by Mach V Dan View Post
Okay. I assume the specs are all the same? Any chance you can get us a weight?
--Dan
Mach V
FastWRX.com
I may be able to weigh them when I changed for winter. It'll be approximate as the Ecsta SPTs on there aren't at 100% tread.
But otherwise, yes. 16x6.5, I believe it's +53 (probably the same offset as the 16" WRX wheels)
Counterfit is offline   Reply With Quote
Old 12-21-2013, 08:28 PM   #215
amcn831
Member#: 235777
2000 RS BuRP
2007 2.5i CGM
Haha, I read the first and last page and didn't see it so I figured it couldn't hurt! I was swapping wheels so I thought I'd mess around with them...
Old 01-01-2014, 10:36 PM   #216
camroncamera
Member#: 308649
Originally Posted by Panda205 View Post
Hey I came across these wheels in a CL ad. the dude says there JDM... Iv never seen them before and I cant find much on them in a general search. Does anyone know what they came off of and what there specs are???
sorry i couldnt upload the full image.. cant access my photobucket account at the moment.
http:[email protected]/9461983946/#
Hey everyone, I usually hang out on the Legacy forums, but I came across this thread in my "detective work" on a set of JDM rims that I recently bought. I was surprised that I didn't see any photos of this style that I now have in possession. The vehicles that they come from are both the JDM '96-'98 BG-chassis Legacy GT-B twin turbo wagon and the JDM '96-'98 BD-chassis Legacy TS-R twin turbo sedan. I read through this thread twice looking for this wheel style before I realized that this is the same rim as Panda205 quotes above.
Photo of GT-B Limited, on which they were original equipment:
(Photo credit: Reuben)
The photo that Panda205 linked above (but had trouble posting) is shown here:
JDM wheels by stisik89, on Flickr
As it turns out, this is the EXACT SET that I bought, and yes, was in the craigslist ad that was mentioned by Panda205 above. (Minds = Blown, I know, lol).
Here is my own snapshot and confirmed specs:
1996-1998 JDM Legacy Twin Turbo GT-B Wagon (BG chassis) and TS-R Sedan (BD chassis)
Offset: +53
Bolt Pattern: 5x100
Wheel Weight: 17.8 lbs/8.1kg
OEM-equipped tire size: 215/45R17
EDIT: Color: confirmed as the powdercoat version of 89N Titanium Pearl
Additional info:
Made In Japan by Fuji Heavy Industries (Subaru parent)
Outer Rim Max Diameter: 18.5"/470mm
Outer Rim Max Width: 8"/205mm
Rim Flange Type: JJ
Center Cap part number: 28811 Ac020
Edited for brevity and clarity by OP's request. Some pertinent additional info left intact for the sake of completeness.
Thanks.
Wait, stop! Please just limit your posts in this thread to wheel specs like above. Please use other threads to discuss more information about the wheels, color codes, where to get, stuff like that.
--Dan
Mach V
FastWRX.com
Last edited by camroncamera; 02-20-2014 at 04:27 PM. Reason: Edited for clarity by OP's request
camroncamera is offline   Reply With Quote
Old 01-02-2014, 10:21 PM   #217
LostWind
Member#: 375618
2014 WRX Hatch
how much would a 4th gen stock wheel go for you think and how hard is it to get those/price? I shaved mine and want to replace it.
LostWind is offline   Reply With Quote
Old 01-08-2014, 01:50 PM   #218
Mach V Dan
Member#: 12029
Offset: +53
Bolt Pattern: 5x100
Thanks.
Additional info:
Rim Flange Type: JJ
Photo of Reuben's GT-B Limited:
See above. Please ask this question in another thread. Please do not answer this question in this thread. This thread is for OEM wheel specs only.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-22-2014, 11:48 AM   #219
Rhythmeister
Member#: 379466
Question
So has anyone got a photo of those BG5 wheels on a classic, i.e. GC8, Impreza at all? I'm considering a set for my 406 silver Impreza turbo
Rhythmeister is offline   Reply With Quote
Old 01-22-2014, 05:23 PM   #220
royalty_sti
Member#: 379498
very useful
royalty_sti is offline   Reply With Quote
Old 01-26-2014, 09:35 AM   #221
zeitgeist
Member#: 378358
2014 WRX hatch
In looking through this thread, I've determined that the 2011 OEM wheel for the WRX is 17x8 +53.
Is it safe to assume this carried throughout the subsequent years? I know the 2013 and 2014 are identical, but I cannot seem to find any post in this thread that specifically mentions those years (or if there was a change after 2011). The latest I could find was the 2011 post.
Thanks!
BC
zeitgeist is offline   Reply With Quote
Old 01-26-2014, 10:11 AM   #222
sc00by4life
Member#: 97135
Originally Posted by zeitgeist View Post
In looking through this thread, I've determined that the 2011 OEM wheel for the WRX is 17x8 +53. Is it safe to assume this carried throughout the subsequent years? I know the 2013 and 2014 are identical, but I cannot seem to find any post in this thread that specifically mentions those years (or if there was a change after 2011). The latest I could find was the 2011 post. Thanks! BC
Look at the cars.....wheels look the same?
Yep. Wheels are the same.
Old 01-26-2014, 05:09 PM   #223
zeitgeist
Member#: 378358
2014 WRX hatch
OK. Sorry if I am just too dense to understand this, but according to the "Offset Nirvana" post, a 8" wide rim should have an offset between +43 and +47.
If that's the case, why does the OEM rim have an offset of +53?
I'm not trying to be difficult, I'm just trying to understand.
Thanks in advance!
BC
Old 01-26-2014, 06:27 PM   #224
sc00by4life
Member#: 97135
OK. Sorry if I am just too dense to understand this, but according to the "Offset Nirvana" post, a 8" wide rim should have an offset between +43 and +47. If that's the case, why does the OEM rim have an offset of +53? I'm not trying to be difficult, I'm just trying to understand. Thanks in advance! BC
Many reasons.
But OEM isn't always (usually not) optimal.
Old 01-27-2014, 11:15 AM   #225
rdiorio
Member#: 373084
2008 WRX Hatch
just subscribed, this is an awesome thread and just wanted to thank the OP and everyone who has contributed. this has been very helpful so....thanks!
rdiorio is offline   Reply With Quote
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 10:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 04:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 01:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 01:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 10:20 PM
