Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 02-27-2012, 11:10 PM   #1276
turbodanny
Member#: 303877
2005 WRX
Originally Posted by gixxer7fiddy
Well you brought it on yourself. When you want to check out an autox come on down. I'll be at every Milwaukee scca event this summer. I'm running an 05 STi in ASP.
I would really like to meet up this summer, i have minor plans for my car, nothing too crazy but would not mind getting a feel for what the car is capable of. Ive always done drag racing at GLD but look forward to exploring other options.
turbodanny is offline   Reply With Quote
Old 02-27-2012, 11:14 PM   #1277
Ssrsxss
Member#: 254807
2006 WRX Limited Wgn
i read your earlier post and i'd been thinking. when you say bigger sway what size do you have?
Ssrsxss is offline   Reply With Quote
Old 02-27-2012, 11:40 PM   #1278
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Shoot me a pm when you're gonna come down. Bring a helmet and I may be able to get you a ride along.
gixxer7fiddy is offline   Reply With Quote
Old 02-28-2012, 11:11 AM   #1279
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Probably way to big for street use.
Old 02-28-2012, 11:29 AM   #1280
slinkyWRX
Member#: 280483
03 Bugeye WRX
^ now that is by opinion only.
what is too big for one person may not be for another. it depends on driving style on and off the track.
i for 1 will be autoX'ing my wrx this summer. my wrx has cobb sway bars front and rear. along with kartboy endlinks.
i but think it is not too much bar. more like just the right amount. keeps the understeer down and the tail controllable.
cant wait for spring.
slinkyWRX is offline   Reply With Quote
Old 02-28-2012, 12:23 PM   #1281
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Let me rephrase that. To big for the spring rates that he has on the car. Yes to one person a 24mm bar may seem big and to another small. But if you don't have the proper spring rates to match the sway bars that doesn't matter.
Old 02-28-2012, 12:28 PM   #1282
tsikows
Member#: 301353
2003 wrx
WR Blue Pearl
hey guys i got my catless bellmouth downpipe in today and plan to install it asap on my 03 rex. would you guys reccomend getting a tune as soon as i can or does it really not matter? can i drive it normaly without a tune?
how about a cel? will it do any harm to be catless and not get a cel fix?
tsikows is offline   Reply With Quote
Old 02-28-2012, 12:40 PM   #1283
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Have any other mods?
Old 02-28-2012, 12:49 PM   #1284
tsikows
Member#: 301353
2003 wrx
WR Blue Pearl
k&n typhoon
and
perrin intake pipe
thats it
Old 02-28-2012, 12:56 PM   #1285
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Yep you'll need a tune.
Old 02-28-2012, 12:58 PM   #1286
tsikows
Member#: 301353
2003 wrx
WR Blue Pearl
even if im already tuned for the intake?
Old 02-28-2012, 01:04 PM   #1287
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Hmmm then idk. Most times you can run a downpipe safely but throw in the intake and it's screwed. So maybe you'll be ok.
Old 02-28-2012, 01:07 PM   #1288
tsikows
Member#: 301353
2003 wrx
WR Blue Pearl
ok thanks man
Old 02-28-2012, 02:10 PM   #1289
turbodanny
Member#: 303877
2005 WRX
Rear bar is adjustable 22mm on the "softest" setting and the front is a 22mm as well on the "softest". I went with the adjustables with the intentions on running different springs that way i can compensate for spring rate and adjust bars accordingly to achieve the same feel i have now with my stock springs. I wouldnt exactly consider 22mm too large excluding the fact the 02-05 came with 17mm rear only, took some time to get used to a larger rear bar but aside from wet snow tires and excesive speeds on off ramps it was not a huge difference and controllable.
Old 02-28-2012, 02:14 PM   #1290
turbodanny
Member#: 303877
2005 WRX
by intake do you mean short ram or "turbo inlet" if you stayed with the stock size inlet you wont have any issues, but if its the larger 3inch i believe it will cause issues and if you got a shortram as long as the maf is in the factory location and its a reputable company then you shouldnt have an issue but you will obviously want to get a tune with your new downpipe regardless. Do a quick search on here im sure people have asked the same question, i thought i heard its bad to drive around with a catless downpipe with no tune, well atleast under boost.
Old 02-28-2012, 02:25 PM   #1291
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I think you will be ok on that end of the tune "Maf Scale". However now that you just made your exhaust more efficient you may run into some boost control issues. It is always a good idea to get your tune brushed up after doing anything to the engine.
I have heard that the 02-03's were ok to run a full exhaust without a tune. But I've never owned a bugeye and have never researched beyond just hearing about it.
2gnt2wrx is offline   Reply With Quote
Old 02-28-2012, 02:32 PM   #1292
TAJR02WRX
Member#: 260936
2002 98sti 5spd VF48
Wagon 01G PSM
If it were me, I would want a tune. Since honestly I couldnt afford anything to go majorly wrong with, not saying something would! But it would always bother me
TAJR02WRX is offline   Reply With Quote
Old 02-28-2012, 02:36 PM   #1293
gixxer7fiddy
Member#: 203474
2005 STU STi #46
What are your spring rates?
Old 02-28-2012, 02:40 PM   #1294
Ssrsxss
Member#: 254807
catless will throw a CEL. you'd need a tune or Cobb AP to eliminate that unless you had a physical fix. i believe that CEL would throw your car into limp mode? maybe not. if it did run I wouldn't want to run it to long and like people said. stay out of boost.
my 2 cents.
Talk to arson9 (Geoff) I'm sure he'd be able to help you out.
Old 02-28-2012, 02:52 PM   #1295
turbodanny
Member#: 303877
2005 WRX
They are stock 2005 wrx springs, so from ive seen..
Fronts:163 Rears:119
Old 02-28-2012, 02:53 PM   #1296
tsikows
Member#: 301353
2003 wrx
WR Blue Pearl
i have the k&n typhoon short ram and a perrin tube. its the silicone one
Old 02-28-2012, 02:58 PM   #1297
Bio248
Member#: 223032
2006 Impreza 2.5i
CGM
so now that i dont even have to worry about putting racelands back on my car, but im sick of the DF210s not being low/level enough for my taste...im looking back into coils again...
anyone want to cruise me around in their car for 10-15 minutes so i can get a feel for their coils? i really wish one of you guys went for the feal 441s, but i doubt you have. where are the BC guys at? don't want tein anything or anything that isn't double adjustable because ill blow the struts from running the car too low.
if i could find a way to drop the front another 1/2" on the springs i have now i dont think i would want to change anything. the reverse rake of lowering springs kills me.
Bio248 is offline   Reply With Quote
Old 02-28-2012, 03:00 PM   #1298
turbodanny
Member#: 303877
2005 WRX
regardless you have already been tuned for your intake and its not causing any drivability issues im assuming, But your concern is your downpipe and if you plan to put it on i would get it tuned as soon as possible, perhaps the same day or before you even drive it. Someone will chime in with first hand knowledge on why its truely needed that or search on the forum. do your research before you put it on.
Old 02-28-2012, 03:02 PM   #1299
gixxer7fiddy
Member#: 203474
2005 STU STi #46
yea that's alot of bar for those springs. I'm running 672 lb fronts with 504 lb rears on my STi with a stock front bar and a 22mm rear bar.
Old 02-28-2012, 03:14 PM   #1300
turbodanny
Member#: 303877
2005 WRX
Yeah, i agree. Should work out decent when i go to different springs i would hope. Time will tell. Are you running coilovers?
The Official Hunting thread and Official Dog thread are right next to each other. camshaftprelube Off-Topic 17 10-22-2008 01:26 PM
The official every thread doesn't need to be official thread... CandyO Off-Topic 21 12-27-2007 01:14 PM
