Old 09-09-2011, 08:58 PM   #1
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Event: Dyno Tune !
Ambient Temp: 85 degrees F
Elevation: sea level
Weather: Just a mild day
Car: 2005 STi
Tuner: Junior2jz
Dyno Info: DynoJet
Peak HP at RPM: 645 @ 7000
Peak Torque at RPM: 508 @ 5750
Baseline hp/tq for a stock on same dyno: 230-240
Target Boost: 29-30PSI
Target AFR: 11.7
Fuel: Straight e85
Engine/Power Modifications:
P&L PS5 Block
P&L CNC Heads
Kelford 199c
P&L FWD Face IC
P&L 1600cc Fuel kit w twin Aero340s
P&L Vband 6265 TurboKit .82 PTE Vband hotside
AEM v2 / Cobb AP for emissions
Cosworth Intake
DSS ProLevel
DSS DS
P&L/Exedy Triple Disk
This thing was built to mirror FastEddie's beast. Fast(slow)Eddie worked on the build from start to finish and it came out flawless! The P&L crew did it again!!
The blue run went [email protected]
The Green run was at 29-30psi and has another 500rpm to pull. Motor is pretty fresh so we didnt want to lean on it to hard on the first session. I think we will have some track numbers for it tomorrow.
Junior2JZ is offline   Reply With Quote
Old 09-09-2011, 09:02 PM   #2
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
Tad's car ? great numbers!
xdrian is offline   Reply With Quote
Old 09-09-2011, 09:10 PM   #3
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
YEA MAN!!! Finally got it all dialed in, we are going to turn her loose tomorrow at the track.
Old 09-09-2011, 09:49 PM   #4
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Wow! Is the 6265 really spooling faster than the 6262 Eddie had on? Must be the E85
Crystal_Imprezav is offline   Reply With Quote
Old 09-09-2011, 09:56 PM   #5
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I always said optimizing the exhaust wheel (EGBP) vs inlet pressure will result in faster spool, even with a bigger turbine wheel, turbine housing. Its all about matching everything up properly.
Old 09-09-2011, 10:06 PM   #6
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Great work again guys...
waynoSTI is offline   Reply With Quote
Old 09-09-2011, 11:28 PM   #7
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
You would never expect the whoop ass!
Old 09-10-2011, 04:59 AM   #8
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Looks stock. Makes monstrous power. Love it.
VladiWrX is offline   Reply With Quote
Old 09-10-2011, 10:07 AM   #9
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Looks good
How many pounds of boost was the 10.1 car on?
Visconti is offline   Reply With Quote
Old 09-10-2011, 11:48 AM   #10
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Mr.V I should have the logs, but I think it was around 28-29psi as well. Im going to try and turn this one up at the track and see if we can get some low 140s out of it. It is still on the old style gear box.
This car reminds me of your car, looks stock until you mash the throttle.
Old 09-10-2011, 02:46 PM   #11
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Indeed it does !
Looks like a beast
Good luck
Old 09-10-2011, 03:02 PM   #12
Nuke209
Member#: 108089
2003 WRX
NF Performance
any timeslips? that'd be bad ass
dynograph looks amazing
Nuke209 is offline   Reply With Quote
Old 09-10-2011, 07:33 PM   #13
CatfaceType-R
Member#: 81102
Very nice, fatttttttt powerband
CatfaceType-R is offline   Reply With Quote
Old 09-10-2011, 07:39 PM   #14
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
[email protected] shifting 5th
[email protected] 1/8th
27psi
Just turned the boost back up to 29-30psi
Old 09-10-2011, 08:20 PM   #15
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Bunch of missed gears.. the 05 sti trans is not liking life anymore. P&L long ratio on the way
It did make a bunch of [email protected] 1/8ths though
Old 09-10-2011, 08:35 PM   #16
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I assume he is running the hoosier dr's jr.
john 1badSTI is offline   Reply With Quote
Old 09-11-2011, 12:31 AM   #17
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Yes they are
Old 09-11-2011, 01:05 AM   #18
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
27psi
Videos?
60ft?
Old 09-11-2011, 01:48 PM   #19
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Vids will be up soon.
Wait til you see this guy hit gears. The car sounded like an auto going down the track. Well until the missed gears .. lol
Best 60ft was a 1.54
Old 09-11-2011, 04:44 PM   #20
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Why no avcs?
Old 09-11-2011, 05:16 PM   #21
reid-o
Member#: 103631
2004 STI
If you had kept the AC in that car, it almost looks as though you could drive it daily (sorry I'm from Hawaii, so no A/C means not driven daily).
I'm going to guess that your times would improve with the longer gear set. After driving a z06, I realized how short the 257 powerband is compared to the gearing.
reid-o is offline   Reply With Quote
Old 09-11-2011, 08:21 PM   #22
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Yea its tough keeping the ac with the cosworth intake rotated. It is his daily though.
The trans is happening, it will pick up some big mph. Im estimating we lost 4-5mph with the shifting of 5th. I say once the car gets the gearbox and Tad makes a full boost pass we will see some 9.80s at 140-142mph
Old 09-11-2011, 09:33 PM   #23
Nuke209
Member#: 108089
2003 WRX
NF Performance
that's what's hurting us ...next gear, high speed gears y0
Old 09-11-2011, 10:01 PM   #24
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
I'm impressed... Especially since this is the turbo I'm going to be running. not sure I can bust out those ETs though. I have a PPG 5 speed.
5lipstream is offline   Reply With Quote
Old 09-11-2011, 10:25 PM   #25
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Originally Posted by [email protected] Shop CT View Post
Why no avcs?
so no possible valve failures???
DJIMPREZA is offline   Reply With Quote
Cleared 05 sti headlights FOR stock 05 sti headlights GallardoKing NWIC Private Classifieds 4 11-07-2011 12:13 PM
FS : 05 sti Project Mu. Rear brake pads FO FREE!!!! sundayWRX Suspension/Brakes/Handling 10 01-04-2011 03:13 PM
05 sti project, soon on 18x9.5 rota grids stilv Member's Car Gallery 88 09-25-2009 04:04 PM
05 sti project car.. only 25k miles! michsti Private Vehicle 'For Sale' Classifieds 1 07-13-2009 03:06 PM
05 STi stage 2 dynotuned... at AMS? EarlQHan Proven Power Bragging 76 08-17-2007 02:57 AM
