Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 09-05-2012, 01:49 AM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Default 16gxt Ej205 335whp 350wtq
Event: dyno tuning session
Ambient Temp: 90 degrees F
Elevation: 820
Weather: Sunny, humid
Car: 1996 Impreza L
Tuner: Ron
Dyno Info: Mustang
Transmission: 5 speed PPG, helical cut
Gear: 3rd
Peak HP at RPM: 335 @ 5600
Peak Torque at RPM: 350 @ 4400
Baseline hp/tq for a stock on same dyno:175/175 stock 2002 WRX
Target Boost: 26.4
Target AFR: 12:1 gas equivalent
Fuel: E85
Engine/Power Modifications: EJ205, Turbo inlet, Custom AWIC, PnP TGV's, 840cc injectors, Custom tubular equal length headers, ported Blouch 16GXT turbo, Stromung DP, custom exhaust.
Driveline Modifications: PPG gears, 3.9:1 FD, Cusco clutch front and rear diffs, stock center, 11.5lb flywheel, 0.75lb crank pulley.
Suspension Modifications: Solid engine and tranny mounts, Koni SA struts, stiff springs and bars
Other Modifications: 2008 lbs total car weight, Real Racing Wheels 16x12 with Hoosier slicks
I'm very happy with the results of the new turbo and tune. Driving this car on an autocross course the power difference is incredible. The small difference in spool is noticeable, but very manageable. This turbo is fantastic for a 2.0L. Run 2 on the graph is my old setup with a TD04.
Old 09-05-2012, 08:48 AM   #2
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
That looks super sweet dude
Kastley85891 is offline   Reply With Quote
Old 09-05-2012, 10:38 AM   #3
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I'm curious as to who made the custom EL Header and which oil pan are you using?
Subian is offline   Reply With Quote
Old 09-05-2012, 01:09 PM   #4
Source,LLC
Member#: 322524
3.5 WRX STI
The area under the curve looks great but I'm not to impressed with how late the torque hits (4400rpm) on a turbo that isn't all that huge. You are without a doubt putting out a decent amount of boost (26+psi), but with e85 and the upgraded headers I would really hope to see spool on this turbo hit by at least 4000 (and even lower on a 2.5L). Any idea why it is coming on so late?
Source,LLC is offline   Reply With Quote
Old 09-05-2012, 08:59 PM   #5
skatinboarding
Member#: 233960
2011 WRX HATCH
WHITE
Im going to guess it spools a bit sooner on the street. I just bought a 16g xt myself and was concerned with the spool and found a thread somewhere that had a dyno sheet and a same day road log and there was a very big difference in spool. Geez thats what i hope at least or im done with these 2.0 liters.
OP great results on that mustang dyno!!! MN represent.
skatinboarding is offline   Reply With Quote
Old 09-06-2012, 12:47 AM   #6
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I made the headers myself. I started with a set of Perrin headers and integrated an up-pipe, then improved the merge sections and the header flanges.
Oil pan is an OEM '07 WRX pan, I think.
The spool is much better when driving than on the dyno. With the TD04 there was essentially no lag on course, with the 16GTX there is just a hint of lag in very slow corners.
Old 09-06-2012, 12:49 AM   #7
ppayer38
Member#: 234407
04 Self-tooned
STi
Pictures please!!
ppayer38 is offline   Reply With Quote
Old 09-06-2012, 11:25 AM   #8
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Where do you see spool on the street? Are you a believer that the EL header helped spool in your case? Is it coated/wrapped?
Old 09-08-2012, 08:05 AM   #9
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
this thing only weights 2008 lbs???
Android287 is offline   Reply With Quote
Old 09-10-2012, 02:25 AM   #10
jhayesvw
Member#: 326502
2003 WRX Wagon
I feel my 16gxt is a bit baggy but I'm used to a straight 6 turbo.
I really like my setup. It's not nodded sti fast but its good.
Your setup looks insane. It makes me want to use my e85 tune. I just worry about gumming issues with prolonged e85. What is could do to my fuel lines and injectors.
jhayesvw is offline   Reply With Quote
Old 09-16-2012, 10:53 PM   #11
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
This is an autoX only car, so it's life is a bit different than a street car. I see boost on course around 3200 rpm, with the peak about 3500. When I installed the original header it actually hurt spool due to the larger primaries and longer overall tubing. The Perring header was designed for the 2.5L, and is pretty good for that. On a 2.0L it hurts spool but improves torque and HP across the board after the turbo spools. With the improvements I have made it spools faster than it would have with stock headers.
At Spring Nationals it weighed in at 2008 lbs after my last lap. It still had 3/4 of a gallon in the tank, which is just about enough for another run. I have done some weight reduction since then, but have not had it weighed recently.
I have been using E85 for 4 years now without any adverse affects. On any subaru 1996 and newer it will not harm anything in the fuel system. If you have it readily available get a tune for it and enjoy. E85 is poor mans race gas.
Now for the sad news. After 100K miles + 4 years abuse (after the odometer was not needed it was unplugged) and pushing almost double stock Hp this motor has died. . I'm not sure what went on it but during my second run at nationals it stopped making any power and once I got off course it stopped completely. The motor can not be turned over, even with a breaker bar. More than likely a piston failed, I've seen that done enough times to know that this was eventually going to happen. I'll post pictures in my build thread in the autoX forum when I get the motor torn down.
The silver lining is that now I get to build a real engine for this car to see what it can really do. It will probably be a high compression, high revving, 2.0L due to minimum weights in my class, but only time will tell.
Old 09-17-2012, 01:28 AM   #12
Nuke209
Member#: 108089
2003 WRX
NF Performance
Sounds like motor seized, spun a bearing
Nuke209 is offline   Reply With Quote
Old 09-17-2012, 02:56 PM   #13
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
I love that power band....
Dirty_WRX is offline   Reply With Quote
Old 09-18-2012, 12:39 AM   #14
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I was thinking maybe that was it, but the oil does not have the usual shimmer of a spun bearing. We will see when I tear it down.
Old 09-18-2012, 09:28 AM   #15
Nuke209
Member#: 108089
2003 WRX
NF Performance
oil off dipstick or did you drain it? j/w
Old 09-18-2012, 03:26 PM   #16
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
What happened to the graph?
Boosted Tuning is offline   Reply With Quote
Old 09-19-2012, 10:54 PM   #17
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I drained it.
I still see it? What is your question?
Old 09-20-2012, 12:55 AM   #18
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
I see it now. For some reason it didnt load earlier. Anyways, good work. Great numbers. Thats on stock block correct?
Old 09-20-2012, 11:02 PM   #19
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Stock block, internals, and heads. Heck- it still had the original timing belt (was on the 2-do list for this winter).
Old 09-21-2012, 12:07 AM   #20
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
Yep, when you get close to 350, it's usually bye bye stock EJ205. Wonder if it broke a rod? That seems to be what happens on well tuned cars that don't break pistons or hammer the rod bearing out from detonation.
69subaru360 is online now   Reply With Quote
Old 09-21-2012, 02:25 AM   #21
eg33GC
Member#: 206851
99 V4
EJ20K RS
rod bolt probably sheared or at least lost integrity
Old 09-24-2012, 02:46 PM   #22
Mister Tanker
Member#: 237759
2003 WRX Wagon
Built ej205 478whp 417wtq
Did somebody say broken ej205 rod?
Mister Tanker is offline   Reply With Quote
Old 10-06-2012, 11:08 PM   #23
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Well, I didn't break a rod, I just bent a few of them, broke a cam, extruded some bearings, and surprisingly enough- didn't damage any pistons.
http://i252.photobucket.com/albums/h...d/DSC05840.jpg
More pics in my build thread-
http://forums.nasioc.com/forums/show....php?t=1495137
Old 10-06-2012, 11:54 PM   #24
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
yourself is not a good sample size to be making claims like that. plenty of people on here and evom have had gunked up injectors on e85
https://www.google.com/search?hl=en&...JO_oiwKTt4HYDg
Phatron is online now   Reply With Quote
Old 10-07-2012, 12:02 AM   #25
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Gunking up injectors would be a result of a poor tune, bad E85 (this is a lot more common than you would think), or the E85 dissolving sediment in the fuel tank from previous bad gas and transporting it to the injectors.
On a '96 or newer subaru there are not any parts in the fuel system that are dissolved or adversely affected by E85.
Anyway- that discussion is completely off topic for this thread and if you would like to discuss it either PM me or start a different thread.
