Old 09-10-2011, 02:37 AM   #1
oucheewawa
Member#: 293173
Default can a compression test tell you about a spun bearing
I recently purchased a v7 swap and on the first road test it started knocking heavy, fresh gas and right away? Why when I asked the jdm importer they just said it must have been installed improper, any thoughts
oucheewawa is offline   Reply With Quote
Old 09-10-2011, 02:44 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you mean as soon as it was fired???
did you pre-lube it by turning it over with the plugs out first???
Old 09-10-2011, 09:47 AM   #3
oucheewawa
Member#: 293173
Ya the shop did pre lube but the knock ia very faint until the car starts to warm up
Old 09-10-2011, 10:11 AM   #4
jam007
Member#: 174706
2008 LGT-B
Did you check the timing belt tensioner? Cause when I got mine it did the same right away and it was the tensioner and it can mimick a knock....just some food for thought.
jam007 is offline   Reply With Quote
Old 09-10-2011, 10:14 AM   #5
oucheewawa
Member#: 293173
Fresh timing belt seems fine, mechanic says it sounds like a rod bearing
Old 09-10-2011, 10:32 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
return engine
if they won't
start credit card charge back
Old 09-10-2011, 04:38 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Dumb question.....what's the oil look like? I'd be checking that first and foremost.....
Jay
Old 09-10-2011, 05:19 PM   #8
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
You need to tune that thing. US gas is nothing like what that motor needs from the factory.
Kris.is.awesome is offline   Reply With Quote
Old 09-11-2011, 02:26 AM   #9
oucheewawa
Member#: 293173
im canadian it had a tank of 94
Old 09-11-2011, 02:39 AM   #10
oucheewawa
Member#: 293173
took it out today, oil is fine its the crank bearing all i have to say is to hell with total jdm, everything i bought off of them was garbage, which led to delays on the project thus passing my 30 day warranty, brembos were chewed needing new wheel bearings and and pads and rotors, as well as they shipped them studs to calipers scratched to ****. then there was the matter of the 5 speed drive shaft they sent me for my version 7 swap, and finally today after surveying damages a litre of oil in the turbo. conclusion= total jdm totalled my summer project that i have yet to drive. and cost me $4000 dollars im sure others have had better experiences with them but as for me im a 25 year old nurse not some punk kid which is what they treated me like when i called them. i did not apreciate there arogance nor their assumption im a hard core rally racer i even tried to explain to him that i had a reciept from the day before for my drive shaft shop drive shaft, and when i asked him how i drove it with out it he told me to go eff my self. worst jdm experience ever
Bouncing my recent compression test off you guys. Amazake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-21-2006 10:26 PM
Attn: SureGrip, what did yourmom tell you about our meeting? Asinine Off-Topic 4 08-31-2005 01:14 PM
Let me tell you about a porcupines balls... GooseMan Off-Topic 15 07-14-2005 03:42 PM
What They’re Not Telling You About the “Election” RRinDC Political Playground 17 02-02-2005 05:25 PM
Let me tell you about a porcupine's balls! eurojax Off-Topic 18 08-11-2004 08:21 AM
