Old 09-10-2011, 11:34 AM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
It had been running great using OTS stage 2 map, there was only occasional, rarely any Fine know learn, Dyn. Adv. Mult was always 1. Lots of power and smooth. But after I took it to a dyno run(though the numbers are impressive 280whp 290 ftlbs), it is not very smooth anymore especially at low rmp and medium load, and I got constant Feed back knock and <0.8 find knock learn at lower RPM, DAM is 0.9.
Could the dyno do any harm to the car? Or could the tuner make any adjustment during the dyno that could cause any problem?
Sheltonmega is offline   Reply With Quote
Old 09-12-2011, 09:40 AM   #2
Sheltonmega
Member#: 265204
### Just for the sake of it, I reflashed the map again yesterday, it is running great again, no FBK, DAM turns 1 after a couple of miles of driving. Still curious what happened on the Dyno.
Old 09-14-2011, 05:10 PM   #3
ArSoN9
Member#: 285777
2004 STi-
Ive had a very similar problem..took car in for a dyno protune and all was good at the shop. The tuner did his thing and the car put down impressive numbers. However within a week my boost was limited to wg pressure of 7psi. It also is having knock feedback and fine knock learn when accelerating at low load and low rpm. The dam also drops to .7 which is default when repeated knock is detected. The car runs good at wot and high loads so its like the tuner didnt tune the low end.
ArSoN9 is offline   Reply With Quote
Old 09-15-2011, 11:15 AM   #4
Sheltonmega
Member#: 265204
But it wasn't a protune, it was just a dyno run to test the result of my upgrades. I am all good after a reflash of the same OTS map. Thanks.
Cylinder 4 Misfire? knock on dyno... Sp00L Service & Maintenance 6 01-19-2009 10:52 PM
Knock after 1-step colder plugs? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-22-2003 03:40 AM
Knock After Shift Auto Joncas Engine Management & Tuning 0 07-17-2003 10:16 AM
Knock after flooring right away MaciekPL87 Normally Aspirated Powertrain 10 11-15-2002 08:43 PM
Engine Knocking after CAI intall? ChinkyWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-13-2002 02:43 AM
