Old 03-26-2013, 10:02 PM   #1
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Default 2009 WRX 371whp/377wtq @21psi/93oct
Bump, Sorry
All,
I want to take my build to the next level, so I need some help deciding what direction I should take my 09 WRX. I was wondering which options (option 1 or option 2) makes more sense or would you go with and why? Also, if you had to change this build, which part of it would you change and why? I currently have the parts below installed, which equates to 371whp & 377wtq on 93 octane on 21psi.
All help and opinions are welcomed!
CURRENTLY INSTALLED PERFORMANCE PARTS
Cobb AP
IAG up-pipe
IAG UEL headers
IAG TGV deletes
Tial 38mm EWG
1000cc ID injectors
DeatschWerks DW65c fuel pump
Invidia Q300 exhausted
Invidia catless DP
Blouch Dom 1.5xt-r 8cm
AEM CAI
Perrin turbo inlet
FMS FMIC
Grimspeed EBCS
Grimspeed lightweight pulley
Go Fast Bitz BOV
NGK spark plugs
Exedy lightweight flywheel
Act performance street spring clutch
*OPTION 1* PURPOSED PERFORMANCE PARTS
Kstech Mega MAF 83 or 73mm
Killer Bee oil pick-up
Killer Bee oil baffle
Manley pistons
Manley connecting rods
IAG crank shaft
ACL rod bearing
ACL main bearing
APR head studs
4 bar MAP sensor
*OPTION 2* PURPOSED PERFORMANCE PARTS
All of option plus
BC titanium valve spring and retainers
BC intake valves
BC exhaust valves
BC 272 cams
Grimspeed AOS
Car: 2009 WRX
Location/Tuner: MD/IAG/George
Dyno Info: Dynojet (smoothing 5)
Transmission: Stock 5 Speed
Gear: 3rd
Peak HP at RPM: 371 at 6000RPM
Peak Torque at RPM: 377 at 4550RPM
Target Boost: 21
Fuel: 93 Octane
Run Condition: 53.48F
Humidity: 27%
Engine Modifications:
IAG up-pipe, GTSPEC UEL headers & Tial 38 mm MVS EWG, IAG TGV deletes, Injector Dynamics ID 1000 top feed, DeatschWerks DW65c fuel pump, Invidia Q300 exhaust, Invidia DP, AEM CAI, Perrin turbo inlet, Blouch Dominator 1.5XT-R 8cm housing, GrimmSpeed EBCS, RrimmSpeed lightweight pulley, NGK spark plug, Exedy lightweight flywheel, ACT Performance Street Sprung Clutch Kit, FMS intercooler
http://www.flickr.com/photos/9390378...n/photostream/
Sorry, I can't seem to get a picture of my graph to show, so I posted a link to my Flickr
Last edited by ironstuner22; 10-16-2013 at 10:07 PM. Reason: Graph wasn't viewable
ironstuner22 is offline   Reply With Quote
Old 03-27-2013, 06:28 AM   #2
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Graph not viewable.
Old 03-27-2013, 06:55 PM   #3
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Sorry, having issues getting the image posted, so I posted a link to my Flickr.
Old 03-27-2013, 08:34 PM   #4
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Here you go
WagonGGA is offline   Reply With Quote
Old 03-27-2013, 09:03 PM   #5
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
nice numbers! your setup is exactly what i would like to have in the next couple years.
Dmochowski is offline   Reply With Quote
Old 03-27-2013, 09:34 PM   #6
Kunk
Member#: 269732
2015 STI
CWP
Hey could you post a video of your exhaust? I might be going with that exact setup from IAG as well but I haven't heard a clip. Thanks!
Kunk is offline   Reply With Quote
Old 03-27-2013, 09:47 PM   #7
morse9443
Member#: 325412
2012 WRX
OBP Stg 2
Wow 371 on that thing must be sick! What's your next step from here? I'm getting most of those parts installed next week before my first tune, minus the turbo which I'm undecided on which to buy. Are you totally happy with the 1.5XT-R?
morse9443 is offline   Reply With Quote
Old 03-27-2013, 10:43 PM   #8
Modfydsubi
Member#: 310974
BLK
I wouldve expected the 400 mark with this turbo. Maybe because its on 21 lbs boost? Anything past 21 would be asking for internals?? What's the injector duty cycle at with the 1000cc?
Modfydsubi is offline   Reply With Quote
Old 03-28-2013, 10:32 AM   #9
gfreed1
Member#: 272788
2011 WRX 1.5XTR
DGM 380AWHP 380TQ
Hey man nice numbers.....I think we met once at the green turtle in columbia. I see you had added a bigger turbo..... i wonder how well the tranny is going to hold up..... we have the same setting minus the turbo and tvg and fuel system..... Nice numbers!
Kunk here is a video of mine
gfreed1 is offline   Reply With Quote
Old 03-28-2013, 11:21 AM   #10
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Very similar #'s to my 10cm hta68, running about the same psi. Very similar mods, too, except that I have exhaust cams, built internals, and a jdm 6-speed. Definitely fun to have these numbers!
I've thought about the Dom 1.5, but I'd like to make a bit more hp gain over what I have. Not that I can afford a new turbo anytime soon, but at least my engine and drivetrain are prepared for when I do.
Old 03-28-2013, 12:21 PM   #11
2011boostdwrx
Member#: 263470
Really nice numbers, I was @ 360/380 with the Kamak 20GTX STS, just switch to the 6 star speed BB SS-20GXR Garett/MHI hybrid TD06SL2. Be on soon.
2011boostdwrx is offline   Reply With Quote
Old 03-28-2013, 10:18 PM   #12
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Yea sure, I will record something over the weekend.
Old 03-28-2013, 10:19 PM   #13
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Thanks a lot! It's pretty fun...
Old 03-28-2013, 10:19 PM   #14
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Originally Posted by WagonGGA View Post
Here you go
Thank you! What exactly did you do?
Old 03-28-2013, 10:27 PM   #15
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Yea it's pretty fun... But to be honest you will always want more power. My tune is conservative, with only 21 psi with stock MAF and MAP, but I should be able to crank it up a couple to around 24psi which should put me around 390s-low 400s, but I am pretty sure something will break or blow. so to answer your question, my next step is to rebuild next winter so I can fully utilize the Dom 1.5 xtr I want to MAXXXX it to the point where it's on the borderline of just blowing hot air lol... Oh may run E85, undecided still.
Old 03-28-2013, 10:29 PM   #16
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
You are correct, the tune is conservative with 21psi, if I had cranked it up to around 24psi+ I would have made 400 easy, but as you mention that would require internals, which I don't have yet ;-) I think it's around 34 not sure exactly, but I will post am update.
Old 03-28-2013, 10:33 PM   #17
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Kunk here is a video of mine Video Link: http://youtu.be/aEUo12DbPPM
Thanks a lot! Hopefully the trans hold out... I don't like thinking about it lol. I am already saving for a new trans and rebuild motor :-)
Old 03-29-2013, 03:34 AM   #18
Dammed
Member#: 351727
Kunk here is a video of mine http://youtu.be/aEUo12DbPPM
What a great sound, thanks for the vid mate!
Dammed is offline   Reply With Quote
Old 07-14-2013, 01:05 PM   #19
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
bump
Old 07-14-2013, 07:46 PM   #20
mtarr07
Member#: 246990
2010 Wrx
Originally Posted by ironstuner22 View Post
bump
Sick setup; I saw this when you first posted it...
Have you run into any issues since then? Still running well? How many miles since the bigger turbo? Whats your opinion on this turbo vs. the stock vf52 for daily driving, etc?
mtarr07 is offline   Reply With Quote
Old 07-14-2013, 08:42 PM   #21
08sedanwrx
Member#: 247611
2011 Built Motor STI
SSM--410whp 475tq-MS109
Ironstuner- Where in Maryland are you from? I go to IAG as well. I just recently blew my motor and IAG built me a new one. We have pretty much the same setup, minus headers, EWG. I have the Dom 1.5 too, but 10cm housing, not 8 like yours. I am setup with a protune by Jorge, same guy who tuned you. (He tuned my wrx a few years ago, I was very happy with it) Anyways, it will be interesting to see how our #s compare. I also plan to get a race gas tune. The 10cm housing is supposed to be a little bit better top end, so hopefully ill break the 400s whp with race gas.
I also saw you were considering e85? How come? The closest place for me is 30 mins from my house. For that reason alone, I wouldn't even consider it.
08sedanwrx is offline   Reply With Quote
Old 07-14-2013, 09:27 PM   #22
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
You should be able to break 400whp on race gas as long as you aren't scaried to turn boost up. I did 390 whp @ 21 psi with meth/water injection on Dom 1.5 2.4" 10cm. I ran out of injector and the motor had broken ring landing also. I've since rebuild the motor myself and tuning it should continue tomorrow if my tactrix arrives. I'm gonna do 20 psi pump and around 24 psi meth tunes. Maybe E85 once I get it dialed in.
bswilmington is offline   Reply With Quote
Old 08-13-2013, 08:44 AM   #23
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Hey 08sedanwrx, sorry I took so long to reply. I am from Laurel MD. I was considering E85 because my buddy who is tuned on it gets it at a gas station off of route 198. I will verify and get back to you. Also, how did you tune go, do you have any dyno pics for reference?
Old 08-13-2013, 08:46 AM   #24
ironstuner22
Member#: 310709
2009 Subaru WRX
Gray
Hey what's your current setup and what kind of power are you seeing with a rebuilt engine with water/methanol and Dom1.5? Very interested since I am considering rebuilding early next year.
Old 08-13-2013, 10:55 AM   #25
bswilmington
Member#: 217563
Current setup is
Built motor by me with
Stock crank, rods, and bearings.
Mahle pistons
Tomei cams
PnP intake, tgv, exhaust manifold with GS crossover pipe
Perrin short ram big maf
Gimmick inlet tube
Blouch 1.5 2.4" 10cm
GS 38mm ewg
Full exhaust no cat
ID 1000
Car made 380 whp 380 wtq on virtual dyno weather corrected @ 23 psi then the brand new stage 2 competition clutch slipped. Couldn't handle torque as it let go when I hit full boost in 3rd gear. There is some more left in it as I only ran into knock once at 6500 rpm, the rest of timing map needs to be worked but until I get a new clutch it will have to wait. I haven't turned the meth on yet but when I do it's a CM 7 (10gl/hr) jet @ 225psi with 67 meth/33water.
