Old 09-17-2012, 01:59 PM   #226
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Originally Posted by saintluciascooby
Thanks if I can round out the year with a couple of 8.5 and below runs I will be happy
Yes!! .. imagine 2nd worked?
If we can't get 2nd though, boost needs to be added immediately. A nice round 40psi
Junior2JZ is offline   Reply With Quote
Old 09-18-2012, 02:01 AM   #227
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Have you guy's herd of FTW purple?
spoolinsti05 is offline   Reply With Quote
Old 09-18-2012, 03:17 AM   #228
subbi7
Member#: 241967
02 wrx
what is your final drive on the transmission?
subbi7 is offline   Reply With Quote
Old 09-18-2012, 04:08 AM   #229
baacke
Member#: 212923
2004 [email protected]&L FXT
384whp/361wtq
41 psi or you're a p***y.
baacke is offline   Reply With Quote
Old 09-18-2012, 12:44 PM   #230
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Have you seen what 5 gallons cost????
Md05STI is offline   Reply With Quote
Old 09-18-2012, 12:57 PM   #231
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
$165?
RexRexRex is offline   Reply With Quote
Old 09-18-2012, 04:20 PM   #232
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
LOL oh yea have you seen the power gain's?
I've been talking abut mixing pure ethanol with race gas to cut it to e85.
doing very little research on honda-tech miller said that the id2000's will swell with this fuel. But some have been running it regardless.
I wonder if he did just that ethanol cut with what though? vp import? q16? who know's it's still a secret. A friend had told me miller said it's something put together you wouldn't expect to burn?
I'm holding off on my e85 tune till next year
Miller also did a video with other stuff that makes a little less power then this stuff for $33 a gallon.
Obviously the hard part will be getting pure ethanol (Moon Shine)
Old 09-23-2012, 07:29 PM   #233
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
License passes and 4 more 8 second passes today. Best 8.7 and 158mph.
Reliable 8 second subaru? I think so!!!! Car has about 25 passes on this motor all in the 9.2-8.7 range.. with 8 8 second passes total this year
Old 09-23-2012, 09:59 PM   #234
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Would be one hell of a DD..
Old 09-24-2012, 02:17 PM   #235
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I tuned a car on that fuel Saturday AM. It is very nasty stuff
Old 09-24-2012, 05:02 PM   #236
Nuke209
Member#: 108089
2003 WRX
NF Performance
More details? What were the gains over e85, if any? And afr?
Nuke209 is offline   Reply With Quote
Old 09-25-2012, 02:08 PM   #237
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
The setup would take 30psi to make 720-740whp, I was able to make it with 26psi. You will need more head room over e85 in the injector or so it seemed from my test car.
I didn't really play with the AFR I targeted e85ish AFRs. No fine line between knock/det/cylinder pressure to high, it has no line. It does like to run more timing, and if you have access to variable cam timing/gears you will def make the most of it by adjusting for cylinder pressure. If you are one of the many that throw millions of degrees of timing at it because it is on e85, you will def blow **** up on this fuel.
It is almost like tuning alcohol.
The goal is 900whp and 165mph traps, so we are trying to utilize the best stuff available. IMO 800whp is the safe street-able limit for the setup on e85, so the owner opted to run this gas so we can play in the 850-900whp range on a more reliable level. Car has trapped 143mph with 660 already.
Back to St.Lucias car, I hear this weekend we may be attempting to run some more boost
Old 09-25-2012, 02:25 PM   #238
Source,LLC
Member#: 322524
3.5 WRX STI
If it's going to be in the 40psi range I'm coming out to this thing run. What track will you guys be at?
Source,LLC is offline   Reply With Quote
Old 09-25-2012, 03:41 PM   #239
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
Great Lakes
saintluciascooby is offline   Reply With Quote
Old 09-25-2012, 05:48 PM   #240
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
A quick video from last weekend! First couple are from NHRA Licensing passes, rest are all 8sec a total of 4 or 5 8 second 150+mph passes. Same engine now has (9) 8 second passes within a 3 week period. Best pass was 8.7xx at 158mph!
Thx
P&L Motorsports Inc. is offline   Reply With Quote
Old 09-25-2012, 09:34 PM   #241
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
sorry for the OT but what kind of car? and links?
Old 09-26-2012, 01:08 AM   #242
saintluciascooby
Member#: 109527
blue
Really?just Pm him for details
Old 09-26-2012, 01:07 PM   #243
Paul
Member#: 56203
00 RSTI Coupe
Jr reply to pms...
Old 09-26-2012, 01:57 PM   #244
saintluciascooby
Member#: 109527
blue
Old 09-27-2012, 04:20 AM   #245
Cosie Convert
Member#: 13627
96 Type RA
[email protected] Street Legal!
Looking good Jon
Cosie Convert is offline   Reply With Quote
Old 09-27-2012, 08:27 PM   #246
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Great job guys! She's getting closer
waynoSTI is offline   Reply With Quote
Old 09-28-2012, 04:59 PM   #247
Cosie Convert
Member#: 13627
96 Type RA
Yea, too close lol
Old 09-28-2012, 07:42 PM   #248
saintluciascooby
Member#: 109527
blue
photo by watsonj0, on Flickr
Old 09-28-2012, 08:27 PM   #249
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Nice!
Actually Rigoli only used the RWD for the burn out they found the RWD launch was slower than the AWD, they also sprayed all the way, I have had many conversations with Rigoli on this subject
Did they use the factory center diff for that, or did they replace the diff with something that just engages and disengages?
Old 09-28-2012, 11:15 PM   #250
karlknaupp
Member#: 60871
2004 WRB WRX
man it sure does like to drift to the right huh... nice save on that one pass. weight shifted and made them rears spin and next thing ya looking at the wall...
karlknaupp is offline   Reply With Quote
AMS R35 GTR in the 8s BLACK02WAGON Proven Power Bragging 2 08-02-2011 10:23 AM
WRX wagon in the 8s. Adrian128 Proven Power Bragging 1 01-17-2004 01:55 AM
The 300's clutch says bye bye, who will help me put another one in? Aspen_2.5RS South East Region Forum 22 09-17-2002 08:00 PM
any one here in the 925 area race there impreza? or any one in the bay area? ASZRAEL Bay Area Impreza Club Forum -- BAIC 3 09-15-2000 01:06 AM
why do we get the urge to report sightings? well uh a er... heres another one.. in IR Dynobyte Southern California Impreza Club Forum -- SCIC 7 07-16-2000 04:23 AM
