Old 07-14-2013, 05:46 PM   #26
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Originally Posted by APM Tuned View Post
Check the purge canister and the relief valves in the tank...if you ever filled up and the pump clicked, then you held it again, and again...you can ruin that canister and the valves can get damaged.
Had that happen once with a client and manoman was that a pain to go through. Tank was dropped and almost everything was replaced THEN the car was great...but he also had an issue with his brothers car (he did the same thing) where the fuel pump sending unit was getting faulted anytime the leveler would move UP (and only up)...there is absolutely no reason for that but hey, a new carrier fixed it.
-Mark
I am having this problem... when I go to get gas it shuts off after like 5-10seconds.... idk wtf to do...I have to full my gas up?
I'm going to order a new gas cap first but I checked/cleaned the sensor by the evap canister but can't take it off to check the canisters because the bolts are rusted -_-
I will just have to keep checking and hoping after I replace part after part it will be fixed... help please
Fir3Fighter is offline   Reply With Quote
Old 07-15-2013, 02:05 PM   #27
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Sometimes, that's how it works, you need to go piece by piece...however...in your case it's probably the canister. There are purge valves and relief valves, vents and a moderate amount of hoses under there, you can either call up the used parts specialists (PMP, Millenium, Oak Leaf or whomever) and have them send you a used, complete unit...or go about doing the way you have been.
It sounds like a venting issue, too much pressure is being built up before it's properly dispersed into the system. Once again, this can be a cause from overfilling if the canister is damaged, time to dig a bit deeper.
-Mark
APM Tuned is offline   Reply With Quote
Old 07-15-2013, 02:05 PM   #28
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
OR! things just happen....not necessarily something that you had prompted for the failure...parts just go bad at times.
-Mark
Old 07-15-2013, 02:30 PM   #29
Fir3Fighter
Member#: 316780
2003 Impreza WRX
-Mark
Thank you for your help brother, I was curious and when I went to fill my gas up it did it so I reached down and pulled off the hose that leads into the canister and it vented and worked fine so it is the canister. I will contact someone about getting a used one. Once again thank you.
Old 07-15-2013, 05:54 PM   #30
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
No problem, glad I can help, hopefully more people find resolution with these types of threads too. I too was once on that side of the counter, hell, google is still sometimes my bestestfwend.
-Mark
Old 10-05-2013, 06:02 PM   #31
origin503
Member#: 370161
Originally Posted by JRizzy24 View Post
Finally got this issue fixed. I reset the code but it kept coming back ~100 miles into a new tank of gas. So I tried the new fuel cap fix but it still came back. I got a smoke test done on the evap system and found a hose not connected.
If you follow the hose (on the bottom of the circular object in the 1st pic) you will find it connects to a blue nipple (2nd pic)- this was not attached. We reattached it and the code has not come back since.
I have been browsing the forums for some time now and just wanted to say thank you. I've had the same evap code for some time. We put the car up and found the control system had a hose disconnected, the filter was filled with dirt. So we cleaned it out, re attached and still had the code. Then I saw your pics of the blue nipple, mine is broken off, completely. I'm getting a new one and think I should be good to go from there. Thanks again!
origin503 is offline   Reply With Quote
Old 04-15-2014, 07:43 PM   #32
Ssj
Member#: 335088
2010 Forester
white
Had this CEL (P0442) on my 2002 Forester. I tried resetting it, but it would come back the same day after less than 10 miles of driving. On the weekend I got under the car and had a good look around the evap canister. Pulled a few lines, blew into some others. Under the hood I found the vacuum line from the intake manifold to the fuel pressure regulator was loose and looking a bit dried, so I replaced it. Anyway the code hasn't come back for a whole day.
Ssj is offline   Reply With Quote
Old 07-14-2014, 08:42 AM   #33
gsk3rd
Member#: 155825
07 WRX TR
WR Blue
This code is a pain in the ass. When cleared it doesnt come back on for a week too two weeks sometimes. Every time I have cleared I tried something new. Nothing seems to be working. I guess a trip to the dealer is in order.
gsk3rd is offline   Reply With Quote
Old 07-26-2014, 09:39 PM   #34
slomo222
Member#: 363394
2003 WRX
Mine also snapped off, where did you purchase the required nipple? is their a part # to it?
Thanks.
slomo222 is offline   Reply With Quote
Old 08-06-2014, 03:11 PM   #35
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
This is an old, but relavent thread. 162k mile 2004 sti. P0442 code came up, and it wasn't the gas cap (replaced with oem just in case).
The blue "T" connector that led up to the sensor, had a broken plastic hose adapter piece (as seen on second photo).
Put in a small vacuum hose adapter, with some new fuel hose line, cleared the ecu codes, and that should fix it.
You'll see smoke out of the leaking blue part because we have a special machine that pumps smoke into the EVAP line to check for leaks.
sensor on right with the broken plastic piece.
paulmofyourhand is offline   Reply With Quote
Old 08-18-2014, 11:07 PM   #36
kimo in sd
Member#: 202000
2002 wrx
sliver
Yeah mine was snapped at the blue tip, I went to Subaru and had the item replaced less than 30. It includes a upgraded version of the part including the 3 main vacuum lines.
I still have the cel code and have drove my car about 120 miles. I think I'm going to get a new gas cap and see if it clears it. FYI the Subaru tech said it should take 60 miles to clear your code 30/30 road and fwy. If you don't want to reset everything back to default. My case I'm trying to pass ca smog, so simply resetting will set me back.
If you reset your ecu to clear the cel, it take about 200 miles with various speeds, I.e. 5 min @ 60 mph, 0-60 in x amount of time, etc. For it to consider itself ready to test.
kimo in sd is offline   Reply With Quote
Old 08-19-2014, 01:48 PM   #37
Badler
Member#: 133597
It doesn't always take that long. There is no "set" amount of miles/time. It depends on what kind of driving you are doing.
Badler is online now   Reply With Quote
Old 08-21-2014, 11:25 AM   #38
ShortBus
Member#: 38607
04 FXT
I use my access port to reset the code and it does take over 100 miles for it to be ready to test.
I also need to fix the problem as it always happens on a road trip and cuts off my cruise control.
Sent from my SM-N900P using NASIOC mobile app
ShortBus is offline   Reply With Quote
Old 05-28-2015, 05:30 PM   #39
pooster.online
Member#: 120461
2004 WRX STi JBP
Would you happen to have the part # handy? Would love to replace this.
pooster.online is offline   Reply With Quote
Old 08-25-2015, 01:31 AM   #40
akwa907
Member#: 418418
2007 STI
My CEL clears itself and comes back on a regular basis. Going to get a new gas cap. How long and what driving conditions will cause a code to clear itself. The code read as pending when scanned.
akwa907 is offline   Reply With Quote
Old 08-25-2015, 09:38 PM   #41
Bush57
Member#: 258710
Somebody said this earlier but after changing my fuel filter in my gas tank I have both the P0442 and P0455. I know I have a gas leak at the gasket around the drop in fuel pump assembly. Maybe it's something to look at for those of you who have tried everything else. I am replacing it with a new one just to be safe. Nothing like gas sloshing around in your back seat while your driving.
Bush57 is offline   Reply With Quote
Old 01-14-2016, 07:03 PM   #42
ScoobyDoobie707
Member#: 390900
2002 Impreza WRX SW
WRB Stage 2 /w STI Uppipe
Thanks for this thread.
I have had this issue for several months
The hoses that connected to my blue tip thing were old and hard. one had fallen off. They were all loose and I replaced them myself
Thanks again
ScoobyDoobie707 is offline   Reply With Quote
Old 01-16-2016, 04:58 AM   #43
dabman
Member#: 438220
2005 Legacy Gt
Same thing happened to me. ended up being purge valve being seized
dabman is offline   Reply With Quote
Is there a tool that can "smell" a fuel evap leak? Agkelos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-05-2010 11:45 AM
P0457 EVAP LEAK DETECTED - help! 05wrx09 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-12-2009 03:54 AM
PO457 evap leak wrxsubiemod Newbies & FAQs 4 04-18-2009 12:17 PM
P0442 - Evaporative Leak - Where to look? cwepruk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-11-2009 07:56 PM
small evap leak and gas smell in wheel well stratos Subaru Conversions 1 04-13-2006 11:32 PM
