Old 08-01-2002, 06:59 PM   #1
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Default Check this intake/ set up
I dont know if this has ever been posted saw it on ebay cool intake, and also it looks like the person out there O2 sensor at the base of the intake, never seen that before any one do this?
AndyM is offline   Reply With Quote
Old 08-01-2002, 07:22 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default Re: Check this intake/ set up
O2 sensor eh?
Looks to me that, the particular intake is pictured on a MY98. How can I tell? Well, the coil pack is different than the MY99+'s. Plus the colour of the vehicle is Rally Blue Pearl. In any case, the sensor is a MAS sensor, not an O2 sensor. An O2 sensor is for the exhaust and it is used by the ECU to adjust the air-fuel ratio within the cumbustion of the engine.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-01-2002, 07:44 PM   #3
porky
Member#: 9413
2002 OBS
white sans cheesy sticker
porky is offline   Reply With Quote
Old 08-01-2002, 08:47 PM   #4
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Default Re: Re: Check this intake/ set up
Originally posted by Penphoe
Looks to me that, the particular intake is pictured on a MY98. How can I tell? Well, the coil pack is different than the MY99+'s. Plus the colour of the vehicle is Rally Blue Pearl....
Its possible the owner has relocated a few components as was did with the MAF. However that engine might not be a MY98. The coilpack and plug wire connectors are not typical of a DOHC engine, (looks more like a '99 to me). The coilpack is offset; '98's are directly behind the alternator. Also the EGR vacuum diaphram actuator that sits on #4 intake runner is missing. RBP 2.5RS was available for MY98 & 99 only.
So which one of the detroit iron's was that dual filter setup designed for?
Albert is offline   Reply With Quote
Old 08-01-2002, 09:27 PM   #5
AndyM
Member#: 3219
WR Blue Pearl
I guess I shouldnt have said that but if you look close it does look like one, I know better than that.
Old 08-01-2002, 09:47 PM   #6
Penphoe
Member#: 269
Default Re: Re: Re: Check this intake/ set up
Hmm, I could be wrong. In any case, the coil pack looks a little different than the coil pack on mine and the MY99's IMO.
As for the K&N intake, it looks like it might be for a Corvette, or an f-body LS1 engine with ram air.
LaterZ!
Darren!!
Old 08-01-2002, 09:51 PM   #7
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Seems like a bit of overkill to me. Could our 2.5L motor flow enough air to warrant the use of those two huge filters? I doubt that it would have a negative effect (maybe, maybe not) but it seems to be a bit more than needed.
Oh yeah...that thing is way old. Seen it a couple times in the past.
NC
Reciprocity is offline   Reply With Quote
Old 08-02-2002, 03:26 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That thing will suck in ALL the hot air from the engine bay...
Old 08-02-2002, 04:03 AM   #9
Scubaru
Member#: 1530
That car is a My99. You know how I know? The wires going to the drivers side turn 90 degrees down comming off the coil pack on a MY98. Also there is no EGR valve on the back-drivers side of the intake manifold as there is on a MY98. Class dismissed -Scu.
Scubaru is offline   Reply With Quote
Old 08-02-2002, 04:23 AM   #10
au112
Member#: 4412
MY01 Impreza 2.5RS
BRP
OT- What kind of strut bar is that??
Andy
au112 is offline   Reply With Quote
Old 08-02-2002, 08:06 AM   #11
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Thumbs down
Well....while it looks really good..........I agree that its going to suck HOT air and be detremental to performance. The idea is supposed to be more cold air!
lakepop is offline   Reply With Quote
Old 08-02-2002, 10:20 AM   #12
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The filters/intake will heat soak at idle but at speed the scoop will supply fresh (cool) air to them. The car is a MY99 with some bits and pieces removed. The red plug wires are Magnecors. As for the performance of the intake it is probably pretty good BUT the airflow into the hood scoop is rather turbulent, look at this design vs some of the other dual filer design I've seen the tubing should have enough bends to disrupt the turbulence. Eh, looks good regardless.
Old 08-02-2002, 12:27 PM   #13
AndyM
Member#: 3219
WR Blue Pearl
I found the car on ebay you can check it out:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1847701493
It was just sold!!!
Old 08-02-2002, 12:34 PM   #14
Penphoe
Member#: 269
DOH! Off by a year!
Oh well. 50-50 chance of picking the right year!
LaterZ!
Darren!!
Old 08-02-2002, 12:38 PM   #15
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Even with the hood scoop open I doubt it will have too much of a
cold air induction effect. Those fiters are pretty far apart from each other...and judging by the picture they would be on the extreme edges of the hood scoop opening.
It's creative...and would probably be great on a car with some serious internal N/A breathing mods (a car that wants a TON of air) but on an otherwise stock car (say full exhaust and even cams) it's overkill...I feel.
NC
FS 2007 2.5i Hybrid Intake Set-up b154wheel Engine/Power/Exhaust 6 08-30-2015 04:36 PM
K&N filter for perrin Short Ram intake set-up intpostman23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 03-03-2010 12:46 PM
wtb:stock intake set-up for 2002-2004 wrx maddbmxjumper Private 'Wanted' Classifieds 3 04-30-2006 01:23 PM
looking for oem wrx intake set-up maddbmxjumper Tri-State Area Private Classifieds 3 01-25-2006 09:27 AM
