Old 09-11-2011, 07:30 PM   #1
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
Default RSP 2.5L Hybrid WRX 1/4 Mile 10.97 @ 125 - 10 second street car
Took the Subaru to the track today for some fun. The car had gone 10.9 with a best mph of 131 before with the owner but today I wanted to have some fun with it.
Event: Quarter Mile
Location: Orlando Speed World, in Beautiful Orlando, Florida.
Ambient Temp: 94* Felt like 104*
Elevation: not a lot
Weather: Humid
Track and Conditions: Concrete
Tires: 10 year old BFG Drag Radials
Car: 2002 Subaru WRX
Tuner: Jay Meagher of Real Street Performance
Dyno Info: DynoJet
Transmission: 05 STI 6 speed with Rallispec Close Ratio 5th gear
Peak HP at RPM: ~550whp
Peak Torque at RPM: n/a
Baseline hp/tq for a stock on same dyno: n/a
Target Boost: 32psi moving to 28psi in 5th
Target AFR: n/a
Fuel: C16 Leaded
Engine/Power Modifications: 2.5 Hybrid with 2.0 heads, JE Pistons/Eagle Rods, Crower 272 Cams, Custom RSP Turbo Kit utilizing a Turbonetics 6462 Ball Bearing Turbo, AEM EMS Tuned by Jay Meagher ( Stock intake manifold, stock Exhaust Manifold )
Driveline Modifications: 05 STI 6 speed with Rallispec short 5th gear, DSS Stage 5 axles, ACT 6 puck clutch
Suspension Modifications: Eibach Lowering Springs
Other Modifications: Car is full weight + cage. Weighed 3380lb with me in it. If it seems high is because I'm a big boy (330)
Was pretty happy with how the day went. The clutch went out but it has lasted over 4 years so it is time to change it anyway.
Car has made 600whp but ran it at about 550.
Enjoy the video
RealStreet is offline   Reply With Quote
Old 09-11-2011, 07:58 PM   #2
BONFIRE074
Member#: 166936
04 2.0 18g-11.8@11
5.7..Hybrid t60r 435whp
nice runs, any pics of the engine bay?
BONFIRE074 is offline   Reply With Quote
Old 09-11-2011, 07:58 PM   #3
yut_to_that
Member#: 124753
very impressive time. props!
yut_to_that is offline   Reply With Quote
Old 09-11-2011, 08:13 PM   #4
Visconti
Member#: 156247
05 STI-10.6 @ 134
GTR - 9.31 @ 151.78
Anymore details on this setup?
Fuel, boost etc
Visconti is offline   Reply With Quote
Old 09-11-2011, 08:18 PM   #5
sackytar
Member#: 149262
2003 03WRXw6sp/05FXT
Wow. Gtr where were you at!
sackytar is offline   Reply With Quote
Old 09-11-2011, 08:42 PM   #6
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
What did it run?
The pole was in the way on the first and what I assumed was the best pass
Junior2JZ is offline   Reply With Quote
Old 09-11-2011, 08:43 PM   #7
RealStreet
Member#: 205916
2003 Subaru WRX
10.97 @ 125
DA was like 2500 today, super hot out but JC managed to drive it well enough to get it in the 10's
If that car leaves like it should, it will go very quick.
Old 09-11-2011, 08:46 PM   #8
RealStreet
Member#: 205916
2003 Subaru WRX
Fuel, boost etc
C16, Walbro with a KB Boost a Pump, 1000cc injectors. 28psi 1st, 2nd 3rd and 4th 32psi, 28psi in 5th.
Old 09-11-2011, 08:54 PM   #9
Visconti
Member#: 156247
05 STI-10.6 @ 134
GTR - 9.31 @ 151.78
KB Boost a Pump
Did you guys ever put it on the dyno?
Old 09-11-2011, 08:56 PM   #10
RealStreet
Member#: 205916
2003 Subaru WRX
KB Boost a Pump
It made 587whp SAE maxed out on fuel. It was run at around 550whp today
Old 09-11-2011, 09:04 PM   #11
Visconti
Member#: 156247
05 STI-10.6 @ 134
GTR - 9.31 @ 151.78
Which KB Boost a pump do you have 20Amp?
Was it turned all the way up?
-John
Old 09-11-2011, 09:28 PM   #12
twistymaster
Member#: 279743
2002 WaGonWrx Hybrid
Snazzy man, Good flipping job on that weight
twistymaster is offline   Reply With Quote
Old 09-12-2011, 03:11 AM   #13
bestfromnw
Member#: 281835
2008 STI
1990 mk2 GLi vdub
great runs man! i love how commentator quoted the price of the gtr
bestfromnw is offline   Reply With Quote
Old 09-12-2011, 07:58 AM   #14
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
Please update your 1st post with the required format found here. Thanks. http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 09-12-2011, 08:15 AM   #15
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
nice..spank that gtr...100k..and the 24k subaru..
oh yeah another 10k in parts..but still..
Old 09-12-2011, 09:42 AM   #16
RealStreet
Member#: 205916
2003 Subaru WRX
-John
I'm using the 20 amp as it's just a single pump, and yes it's turned all the way up. It only has one set of 1000cc injectors so much over 34psi it's outta injector also. I need to get off my ass and do the fuel system. I haven't figured out what path I want to take with it as I enjoy driving it around on the street. In a perfect world I'd add a second fuel system running good gas under boost and pump driving around. The other thing is it makes 530ish (SAE)dynojet on 31-32psi but wicks up to 580ish (SAE)/600STD at 34-34.5 psi. I just don't have to fuel to support it safely. It's also got the "wrong" gearing, I'm pondering putting 07 gearing in it.
I've just got other hotrods that need time, my stickshift/small tire low 9's Mustang is close to being able to race again and I just put a 3.4 in my Supra so the Subi isn't as big as a priority as it should be. Hell, I didn't even go to the track with the guys yesterday. I just hate to see the Subi sitting...
Thanks
Jay Meagher
Old 09-14-2011, 04:15 PM   #17
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
I always wondered how much power it would take to tip 10's or 9's. Great job guys
My best was an 11.2 @ 127, 30r - 485whp/497tq
Exec809657 is offline   Reply With Quote
VF34 2.5L WRX 1/4 Mile Absolut_Boost Proven Power Bragging 28 09-01-2008 10:15 PM
2.5 wrx 1/4 mile registry bobbymorgan425 Proven Power Bragging 3 02-08-2007 12:57 PM
18g or 20g WRX 257 Hybrid Owners, 1/4 mile times? NITROS Proven Power Bragging 10 11-19-2006 02:08 PM
stg4 wrx 1/4 mile slip - I can't launch Rick Hunter Proven Power Bragging 15 06-10-2004 07:47 AM
12.583 @ 107.45 - - WRX 1/4 mile alfriedesq Factory 2.0L Turbo Powertrain 278 11-13-2001 07:50 PM
Message Board Statistics All times are GMT -4. The time now is 08:14 AM.
