Old 04-23-2001, 02:43 PM   #1
Green Machine
Member#: 2758
2006 Impreza 2.5i
Regal Blue
Question Hood Scoop from subaruparts.com
If I buy a hood scoop from subaruparts.com, is it absolutely necessary that I buy the "attachment hardware" as well? I'll just end up taking the restrictor plate off anyway, do I really need to spend the extra money for it?
Jonathan
Green Machine is offline   Reply With Quote
Old 04-23-2001, 02:46 PM   #2
Frank
Member#: 3791
Post
it depends if you have hardware you can re-use from your old scoop. I'm not sure if they're pop rivets or screws or bolts. I guess it really depends which type of hardware it uses.
Frank is offline   Reply With Quote
Old 04-23-2001, 02:47 PM   #3
Gummy Bear
Member#: 5953
2000 "You know... li
Post
Unless you want it to fly off the hood, yes. If you dont' care about losing it the first time you top 25mph, save the $10
Gummy Bear is offline   Reply With Quote
Old 04-23-2001, 03:09 PM   #4
Green Machine
Member#: 2758
2006 Impreza 2.5i
Regal Blue
Post
I wish it were only $10. Unfortunatly, it's nearly as much as the scoop itself.
Old 04-23-2001, 03:41 PM   #5
Gummy Bear
Member#: 5953
Post
Is that for the blocking plates though? They are expensive, yes, but you dont' HAVE to have them. The hardware for the scoop (nuts, bolts, and the plastic clip) is about $10.
Old 04-23-2001, 06:36 PM   #6
Caron
Member#: 2292
2000 Impreza Wagon &
2007 Legacy Wagon 2.5i
Question
What's this again?
I got the unpainted scoop and the complete vents (how does air flow through them ?) and a hood will soon be mine.
What's this extra piece again? It's true that something must go underneath the scoop, I just hadn't thought of it.
You wouldn't have a part number, would you?
Caron is offline   Reply With Quote
Old 04-23-2001, 06:40 PM   #7
ImprezaL
Member#: 1393
Lightbulb
Caron- Just responding to your air flow comment, air doesn't go in the vents, but out... they let some heat escape from the engine.
-Josh
[This message has been edited by ImprezaL (edited April 23, 2001).]
ImprezaL is offline   Reply With Quote
Old 04-24-2001, 09:54 AM   #8
Caron
Member#: 2292
Post
Yes, air does flow through the vents. If you look at the vents and their underpart, only 2 or 3 small holes are there for the heat to escape. I thought they would be bigger!
Has anyone bought from subaruparts.com? datpnoy2nv Southern California Impreza Club Forum -- SCIC 5 05-27-2001 10:04 PM
Anyone tried to order from subaruparts.com? raptor Canada Region Forum 15 05-16-2001 03:43 PM
Anyone order the version5 struts from Subaruparts.com? Dolphin Overton General Forum Archive 3 09-30-2000 02:26 PM
Questions FROM Subaruparts.com snubber General Forum Archive 13 08-12-2000 12:15 AM
