Old 09-12-2011, 01:25 AM   #1
eliezerrosario
Member#: 141949
2004 Wrx
JBP
Soon I'll be getting my final e85 tune with this "blessed" block, but I wanted to see if there was anyone else out there who was a part of the group buy for this block and already has had their "final/race" tune
If so, can you post:
-whp/tq (what shop and dyno)
-turbo used
-head work (if any)
-boost
-fuel system
-time slips (if any or a "kill list" will do)
Thanks, I'm just curious....
Mine
-whp/tq: TBD, still completing break-in...700 more miles to go
-turbo: pte6262 w/.82 t3 hotside, journal bearing
-head work: MPS stage 2 head package w/ 272 kelford cams
-boost: TBD (maybe 32-36psi)
-fuel system: full blown dual pumper w/twin aeromotive 340l pumps, -10an feed, -6an return, russell distribution block to -8an lines to the aeromotive rails, aeromotive FPR (will be on E85)
-time slips: TBD (I'm hoping for mid 130trap speeds)
eliezerrosario is offline   Reply With Quote
Old 09-12-2011, 03:18 AM   #2
wheatpaste
Member#: 170747
2004 WRX Wagon
I was in on the group buy and I'm very curious to see results from others as well. My build is lagging a bit, but I'm looking to get everything wrapped up in the next two months. Long block is done, heads are being built as we speak.
Just a little highlight of what I'll be running:
-MPS 2.34L long rod sleeved short block
-MPS P+P Heads w/full Ferrea Valvetrain + Kelford 272s
-BW S300SX 91-79 Twinscroll
-Link G4 Plug In ECU
-E85
wheatpaste is offline   Reply With Quote
Old 09-12-2011, 03:29 AM   #3
Big_DeWeY
Member#: 37078
95 L
Blue-ish
This could be good. In for results!!!
Big_DeWeY is offline   Reply With Quote
Old 09-12-2011, 02:58 PM   #4
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
+1 for results! last thread sank for confidentiality reasons.
lil'redwagon is offline   Reply With Quote
Old 09-12-2011, 03:25 PM   #5
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
I plan on going with a long rod build as well, can't wait to see more results!
Steve.804 is offline   Reply With Quote
Old 09-12-2011, 04:59 PM   #6
WhatTurboLag?
Member#: 243992
2006 WRX TR
IN FOR RESULTS!!!
ALSO post your redline please, im trying to see how much usable powerband there is and still good street spool, AND that can still make use of the 9k+ potential redline.
WhatTurboLag? is offline   Reply With Quote
Old 09-12-2011, 05:40 PM   #7
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
^Keep in mind there is no reason to rev beyond what your turbo can support. And if you're after good street spool you dont want a turbo that gets going at 6000rpms. I think a 35R size (65lb/min) turbo should spool around the 4500-5000rpm mark and still hold power nicely to 8500+rpm. If you want 9000-10000rpms power potential you may want to consider a 40R size turbo but that will negativly effect your "good street spool." Obviously a lot of this is dependent on what headwork you have and cams you're using.
Old 09-12-2011, 09:28 PM   #8
WhatTurboLag?
Member#: 243992
2006 WRX TR
thats what im trying to find an even balance between steet drivibility and about 5-600WHP and a wide powerband for road racing.
Old 09-12-2011, 11:07 PM   #9
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
I am curious to see someone use a quick spool valve with this motor to bring the power/torque in sooner....
jdpsearcher is offline   Reply With Quote
Old 09-13-2011, 01:53 AM   #10
Big_DeWeY
Member#: 37078
95 L
Blue-ish
I've heard this discussed before. It would be interesting to see someone try it.
Old 09-13-2011, 02:42 AM   #11
WhatTurboLag?
Member#: 243992
2006 WRX TR
cough cough YOU DEWEY!!!!!
ill pull up the thread i made a while back, most shot it down but it does have results.
edit, aparently i never made a thread, just made one about the SP exhaust cutout.
Old 09-13-2011, 10:04 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
true story. I've had to tell guys that they don't want this engine in the past for what they want.
you sir, are a good candidate for this engine then but I'd still size your cams a little on the small side. That being with how NASA dictates weight via power. That or run shorter final drive to make up your torque 'loss'. It'll also help with transient response/mid-range poewr which is what you'll be aiming to have for corner control. Then you can stretch out your top end on the straights though you won't quite have as much power.
Old 09-13-2011, 02:46 PM   #13
eliezerrosario
Member#: 141949
2004 Wrx
JBP
Am I the only one who is going to be using this block just to put cocky zr1 owners in their place?
Old 09-13-2011, 03:14 PM   #14
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Dom has.
Dave D. is offline   Reply With Quote
Old 09-13-2011, 04:56 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
Nope, I know guys who've been pissing off big power guys for a while. The biggest turbo I still know of one to have been running is a customer on a 4094R.
Old 09-13-2011, 05:37 PM   #16
eliezerrosario
Member#: 141949
2004 Wrx
JBP
holy lord! and it's still daily driven?
Old 09-13-2011, 05:42 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
no, it's his street strip toy. Built 4eat and all that jazz.
Old 09-13-2011, 06:41 PM   #18
WhatTurboLag?
Member#: 243992
2006 WRX TR
what kind of spool does that thing see?
Old 09-13-2011, 06:56 PM   #19
MartinSTi05
Member#: 145145
2006 wrx STi
So, any results? Why the confidentiality?
MartinSTi05 is offline   Reply With Quote
Old 09-13-2011, 07:44 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
It's one of my first prototypes from back in 07 were I still had NDA's
/threadjacking
Old 09-14-2011, 02:18 AM   #21
WhatTurboLag?
Member#: 243992
2006 WRX TR
oO
Old 09-14-2011, 10:25 AM   #22
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Relatively new engine package that only recently picked up much steam. We're just starting to get our engines. I went with the destroke 2.34 then boring out to 102.xx to keep a 2.5l. I like my torque Next spring it'll be a monster.
EtoS is offline   Reply With Quote
Old 09-14-2011, 11:56 AM   #23
WhatTurboLag?
Member#: 243992
2006 WRX TR
whats the difference between the 2.34 and 2.35 motors again?
Old 09-14-2011, 12:47 PM   #24
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
"2.34" is a Destroked 2.5, 75mm stroke, 99.5mm bore
"2.35" is a Stroked 2.2, 79mm stroke, 97mm bore
Merp is offline   Reply With Quote
Old 09-14-2011, 12:57 PM   #25
WMCCook29
Member#: 152685
2016 Forester XT
"2.35" is a Stroked 2.0, 79mm stroke, 92mm bore
A stock bore 2.0 with 79mm crank is only 2.1XL. Even with a 96mm bore, it's only 2.29L.
WMCCook29 is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP leonbmx Proven Power Bragging 75 08-27-2015 03:59 PM
FS : Built sleeved 2.5 block and built 2.0 heads + more sleepysubie Engine/Power/Exhaust 7 06-30-2011 12:50 PM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
What were the results from the Tacoma show? Subarutex North West Impreza Club Forum -- NWIC 6 09-02-2003 01:58 PM
