Old 09-14-2011, 01:07 PM   #26
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Originally Posted by EtoS View Post
Relatively new engine package that only recently picked up much steam. We're just starting to get our engines. I went with the destroke 2.34 then boring out to 102.xx to keep a 2.5l. I like my torque Next spring it'll be a monster.
You better sleeve it lol. Realize also that you still won't make quite the torque you would with a normal 2.5 due to the smaller stroke. My personal opinion is it wouldn't be worth it.
Big_DeWeY is offline   Reply With Quote
Old 09-14-2011, 01:08 PM   #27
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Originally Posted by WMCCook29 View Post
A stock bore 2.0 with 79mm crank is only 2.1XL. Even with a 96mm bore, it's only 2.29L.
Doh. It's a stroked EJ22, ~97mm bore iirc.
Merp is offline   Reply With Quote
Old 09-14-2011, 01:09 PM   #28
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Originally Posted by WhatTurboLag? View Post
whats the difference between the 2.34 and 2.35 motors again?
The 2.34 is a 2.5 with a 2.0 crank.
The 2.35 I'm pretty sure is a 2.2 with a 2.5l crank.
Drastically different types of motors.
Old 09-14-2011, 01:28 PM   #29
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah, if you're chasing big torque values, a stroker is the road to take, not a destroked engine.
Old 09-14-2011, 02:11 PM   #30
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Would you say that 2.2 with the 2.5 crank is the way to do that?
Sorry if that's off topic!
Zee Biker is offline   Reply With Quote
Old 09-14-2011, 02:15 PM   #31
Homemade WRX
Member#: 33782
96 bastard child
No, I'd do an EJ257 with a stroker crank and/or big bore if chasing national level SM auto-x tq...or a torquey pump gas car.
Old 09-14-2011, 02:24 PM   #32
WhatTurboLag?
Member#: 243992
2006 WRX TR
id never do pistons bigger than 99mm, just based on what i gathered from my research....i think. at least when going for max relibility and power capability.
WhatTurboLag? is online now   Reply With Quote
Old 09-14-2011, 04:35 PM   #33
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
That'd be tough when stock size is 99.5...
Torque sounds fun, but so do revs. Still limited by a wallet, and a stroker crank on top of getting a '2.5' running in my car sounds like a bit more than I'd like to take on. Touche. I should have asked a more direct question. Not a realistic option; personally likely to do a 2.1 in my car from what I've read, minus the spark issues.
Back on topic; get those results in here!
Old 09-14-2011, 04:53 PM   #34
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Torque breaks stuff. Just saying.
Old 09-14-2011, 07:22 PM   #35
Homemade WRX
Member#: 33782
96 bastard child
you mean 99.5mm?
and sleeves are a given on big bore with FI.
Old 09-14-2011, 07:34 PM   #36
WhatTurboLag?
Member#: 243992
2006 WRX TR
YES THATS WHAT I MEAN, lol i was in class so i do not have a lot of time to type ****....not to mention i hate how my ipod keyboard is.
even with sleeves i dont like it
Old 09-14-2011, 07:43 PM   #37
Homemade WRX
Member#: 33782
96 bastard child
Well you know what they say about opinions
facts are something else
Old 09-14-2011, 07:56 PM   #38
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
IMO engine specs is all preference. How much am I willing to give up for another. I am willing to lose a pinch of top end for a pinch of low end.
And yes it is sleeved along a whole array of other things. The only thing factory is the intake manifold, case halves and head blocks.
EtoS is offline   Reply With Quote
Old 09-14-2011, 08:26 PM   #39
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
GT4094 0.95 T4 Exhaust Housing with:
Stock ECU running Speed Density
2mm Longer Rods
Kelford R-199-C AVCS cams (272/272 with 11.5mm Lift intake and 11.2 Exh)
Benson Sleeved Case
Manley Billet 75mm Crank
JE Pistons 99.5mm
Chapman Racing CNC Ported Cylinder Heads
1mm oversized stainless intake and inconel exhaust valves
Full Race Header and Uppipe
Cosworth Intake Manifold
BC Adjustable exhaust cam gears
AVCS Intake gears (Not running any avcs currently due to wrong neutral sw)
Comparison Graph between the spool of a 2.5 and a 2.34 with a GT4094 wth a 0.95exh housing:
The Graph that runs to 7,000 rpms is a 2.5L with custom kelford cams (276 Intake 272 Exh)
Aem Series 1 EMS
2mm Longer Rods
Benson Sleeved Case
JE Pistons 99.5mm
Graph that runs to 7500 rpms is the same graph that's posted by itself above 2.34 with R-199-C Cams (272 Int and Exh 11.5mm lift intake and 11.2 exh)
wrx_driver_2002 is offline   Reply With Quote
Old 09-17-2011, 12:49 AM   #40
WhatTurboLag?
Member#: 243992
2006 WRX TR
how would one of these do sleeved and bored back out to equal 2.5? any decrease in potential relibilty or rev limit?
Old 09-17-2011, 08:12 AM   #41
Homemade WRX
Member#: 33782
96 bastard child
They do really well. Pending turbo and cam/cylinder head matching; spool can be great but in trade for top end to some.
4" bore, so a 2.43L and that's a 1.06 AR GT4094. He realized that he had a bad sleeve job and was pushing coolant during this session (and this plot), hence the early stop (low boost and low RPM). This is actually one of my oldest customers, who like me has had MANY things get in the way of the build, so no NDA with him.
I simply supplied parts, specs and helped source some OTS parts as he's across the world, literally.
Oh it has lumpy Kelfords; 272 11.2mm lift, non-AVCS.
Old 09-17-2011, 02:06 PM   #42
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
That is essentially what I'm doing. I have a crazy build, surprising extremely similar to Barigas right down to turbo/exhaust/heads and engine.
Old 09-29-2011, 12:42 AM   #43
WhatTurboLag?
Member#: 243992
2006 WRX TR
so im thinking about a different route now (no more rotated gt3076), but with the same motor (in the future)
basically do a trans swap, then get a moore performance TS semi rotated evo 9 turbo kit with a stock evo turbo till my motor goes, then a built motor on a evo FP red or FP black. hmmmmmmmmmmmmmmm
Old 09-29-2011, 03:06 PM   #44
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
I am curious why a build like this with a smaller AR housing on the turbo using a quick spool valve wouldn't work as a daily driver. Assuming a good sleeve job so the motor holds.
I would love to have the potential to spin to 9k rpm's and have torque start to come in about 3500rpm.
Say 550whp on 92 octane and 750-850 on e85, and be reliable. What I mean by reliable is not beating the piss out of it all the time, but have some weekend fun and a few track days, no real drag strip action.
jdpsearcher is offline   Reply With Quote
Old 09-29-2011, 04:12 PM   #45
Homemade WRX
Member#: 33782
96 bastard child
I actually had a phone call earlier this week where a 4094 and a spool valve (of sorts) would be used for a DD. However, you'll note that engine is hitting 18 psi at like 3600 RPM just starting to tune
The bigger issue comes with setting the tolerances for a DD application that like. For te power, you'd want 2618 (for what's available now), which requires more PTW when cold because it has greater thermal expansion. Now with the wide spread of power via fuel and then also the ethanol's cooling of the piston, you have two different PTW clearances to be concerned with. Be it if the pump gas tune was that low in comparison to the e85, I don't think there would be much issue.
Add meth/water to the gasoline tune and you draw targeted PTW closer together.
The one saving grace is that it would just be used for quick bursts of fun, the PTW isn't that huge of a difference form cruising to 'in use'.
Old 09-29-2011, 11:28 PM   #46
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
I've seen a couple post by you now "hinting" at possibly a new piston material coming out. Care to share more ?
morrocco88 is offline   Reply With Quote
Old 09-30-2011, 08:48 AM   #47
Homemade WRX
Member#: 33782
96 bastard child
eh....don't want to thread jack here. Basically lighter, stronger, better thermal conductivity, better wear resistance, better fatigue resistance...all that good jazz but $$
Old 10-01-2011, 02:00 PM   #48
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
You aren't talking about Del West are ya?
AKSubieDubie is offline   Reply With Quote
Old 10-01-2011, 08:25 PM   #49
Homemade WRX
Member#: 33782
96 bastard child
nope but a decent guess
Old 12-03-2011, 05:32 PM   #50
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Up because it should be high time to see more results!
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 608 Yesterday 06:54 PM
Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP leonbmx Proven Power Bragging 75 08-27-2015 03:59 PM
FS : Built sleeved 2.5 block and built 2.0 heads + more sleepysubie Engine/Power/Exhaust 7 06-30-2011 12:50 PM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
What were the results from the Tacoma show? Subarutex North West Impreza Club Forum -- NWIC 6 09-02-2003 01:58 PM
