Old 01-31-2012, 03:39 PM   #126
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Micah could always give me one of these engines and we would have some results
Md05STI is offline   Reply With Quote
Old 01-31-2012, 04:23 PM   #127
Maxwell Power
Member#: 190729
if we could afford to give an engine away, there would be a line for sure. Micah makes about three times what I make though so he could probably swing it.
Maxwell Power is offline   Reply With Quote
Old 01-31-2012, 04:25 PM   #128
vicious_fishes
Member#: 158864
2003 SOHC destroker
hey micah,
get the hint?
vicious_fishes is online now   Reply With Quote
Old 01-31-2012, 04:33 PM   #129
vicious_fishes
Member#: 158864
2003 SOHC destroker
Originally Posted by 3MI Racing View Post
Exactly the current limit on RPM. If you want to drag race, I'd honestly say the engine will gladly take a larger turbo.
so is that confirmation the heads are the "bottleneck"?
my intention is track circuit racing/time attack. looking @ the dyno graphs we have so far it's clear there is a bit of power dropoff. i was under the impression that this was simply the hotside of the turbo being not-quite-big-enough at 0.82, yet the 1.05 is simply too laggy. hence, me thinking with more RPM the 1.05 would be ideal.
are you saying that the dropoff is in fact a product of a restriction in head flow rather than the hotside of the turbo?
if so that's kind of a shame as a ton of headwork is much more difficult/expensive compared to a simple hotside swap but, if that's the case then such is life. having said all this, it appears/you guys have mentioned that the cams used simply haven't been big enough and that might be the cause of the dropoff.
keen to hear your thoughts on the matter, i'm sure there is a bit of testing to do with cams/exhaust hotsides yet.
Old 01-31-2012, 04:50 PM   #130
Maxwell Power
Member#: 190729
There are a handful of things that need to happen to push a Subaru motor that high.
1. Intake manifold. We will need the plenum volume and short fat runners to feed enough air in the engine. Also, the firing order of the engine makes proper intake manifold design a little tough.
2. Cams: Right now there isn't a cam profile made for a 10k rpm engine. Custom cams would be required as a minimum.
3. Head flow: While these heads don't flow a ton, there are big differences from port to port. 20% difference in exhaust ports from the factory. At 300hp that's a significant difference in flow, but at 900hp we're really talking about a major tuning issue. Our porting program is designed to provide less of a difference in flow between cylinders while still removing as little material as possible to provide good velocity.
4. Cooling: the STi water pump won't cut it. The 2L water pump is a good pump that experiences less cavitation at high rpm. I think it is possible to expand on that pump a little to increase flow output. Getting more cooling to cylinder 4 is also a priority for us.
As Vicious pointed out, a larger hotside is required. This is a given. As cam size goes up, so does the hotside. The challenge is getting as much air in and out of the engine will at the same time minimizing overlap. In order to do this, you need a lot of lift as these heads really flow well at almost 12mm. The issue with that is then trying to prevent valve float at such a high rpm with a big cam. Increasing spring pressure increases parasitic loss...
It's a big circle, really.
Old 01-31-2012, 05:19 PM   #131
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
... In order to do this, you need a lot of lift as these heads really flow well at almost 12mm. The issue with that is then trying to prevent valve float at such a high rpm with a big cam. Increasing spring pressure increases parasitic loss...
As you very well know I'am sure, you can 'easily' cut the circle by using stronger but lighter valve train parts. Titanium comes to mind as does DLC coating lifters to cut parasitic losses, etc etc.
Its just a matter of money, same as with any engine, whether its an evo or any other platform imo.
Beetspeed is offline   Reply With Quote
Old 01-31-2012, 05:31 PM   #132
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Formula 1 engines employ pneumatic valve springs in which pneumatic pressure closes the valves (Wikipedia).
15k easily. C'mon, Dom. if anyone can make this work, you can.
Dave D. is offline   Reply With Quote
Old 02-01-2012, 02:44 AM   #133
vicious_fishes
Member#: 158864
2003 SOHC destroker
F1 engines also need an entire team of people/equipment including a laptop computer to start
dom - i saw you've done testing with a gt3082, have you done anything with a gt35 1.06, or a big badass 280 degree cam or similiar?
any news on the 77mm crank front? i'd love to hear about what you & micah are developing with that one
if you're not under an NDA and can tell us of course
Old 02-01-2012, 10:56 AM   #134
3MI Racing
Member#: 200987
You never called me back but man you have no problem texting
We just need to meet up for a beer and talk things over already!!
I did just place an order for 3 extra sets of 300 M I-beams with 625 bolts
I don't know about all that but I am putting a few freebies out this year...it's out of my wallet.
3MI Racing is saving to have parts in stock and then to build equity for a 5-axis mill.
Dom hit you with the basis of what's needed to make it run happily at speed and the water pump is something that needs to be addressed for an engine living at the RPM (see road course work). I do have my 'suspicion' that the cast impeller is much better than the stamped steel...but I'm never happy without hard evidence.
The valve springs are actually proving to be the limitation of ONE setup that I've had were the springs relaxed. May be a fluke but the valvespring company sent me a new set to replace and retest...Don't ask names as I won't say as I'm working with them and they're working with me to resolve/see if it is an actual issue.
-Micah
3MI Racing is offline   Reply With Quote
Old 02-01-2012, 11:47 AM   #135
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I called and you didn't answer, should have called me back!! Even though the chances of me answering are slim. Texting is easier for me, I get easily sidetracked and don't pay attention when on the phone...get ahold of me and we can figure out a time to meet up and talk things over.
Old 02-01-2012, 11:56 AM   #136
vicious_fishes
Member#: 158864
2003 SOHC destroker
iirc i remember seeing somewhere someone had popped open the water/oil pumps from both turbo and NA models and found the NA pumps to have much, much smoother impellers.
food for thought.
Old 02-01-2012, 12:06 PM   #137
Spike_916
Member#: 170007
2006 STi
Obsidian Black Pearl
Originally Posted by sumfoo1 View Post
what is the rod length on it?
and jesus someone carve us out a block... if proline can do it for their own custom v8s our simple block halves should be easy.
OMG when I saw this I think I got an erection... then I went limp when I saw the price tag.
Spike_916 is offline   Reply With Quote
Old 02-01-2012, 01:02 PM   #138
vicious_fishes
Member#: 158864
2003 SOHC destroker
this is the sort of money you start talking to run 6 second passes
Old 02-01-2012, 03:16 PM   #139
ddejaege
Member#: 291612
'02 Bugeye
I just built a bunch of these with 102.3mm bores that brings them out to 2.5L. I'm excited to see these results as well.
To possibly satisfy people's curiosity a wee bit.. I have just over 3k miles on my 102.3mm bore 2.5L. I'm not going to divulge much at the moment (mostly since the car has more big plans in the near future), but in its current form (with a mid-sized turbo) it's an absolute riot on the street and the power would likely satisfy a majority of individuals.
The big plans should unfold in the next few months and then i'll likely have results that I'd be willing to share... maybe.
ddejaege is offline   Reply With Quote
Old 02-01-2012, 05:47 PM   #140
Loubaru
Member#: 155489
07 STi
If you guys need some help figuring out a water pump solution let me know. I'm an engineer for a VERY large pump company, we have products in multiple markets including automotive. I mainly deal with oil/gas but I'm local to Dom and know a good amount about pumps, re-rating them, head (pressure)/flow limitations, etc...
Oh yeah, hurry up and get your RSTi finished Dom! Can't wait to read about it and geek out.
Loubaru is offline   Reply With Quote
Old 02-01-2012, 07:48 PM   #141
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
finished?
it drives right now. were just changin the heads to add avcs to the engine.
NW2TONE is offline   Reply With Quote
Old 02-05-2012, 09:55 PM   #142
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
wrx_driver_2002 is online now   Reply With Quote
Old 02-05-2012, 10:05 PM   #143
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Well my big bore version of this engine is alive, damn that moroso pan and it still leaking GRRRRRRR! But hopefully some results. FP GT3586 Big HTA with 2.5" uppipe and 2" primary header with big lift kelford 199C cams, dual 044's and E85. Oh ya a bunch of other stuff too..
BTW Congrates Mike the ole GC8 is going to be a demon..
Sinister redlines is offline   Reply With Quote
Old 02-05-2012, 11:53 PM   #144
QksilverRS
Member#: 16826
01 STi DOMINATOR 3
444 WHP 431 WTQ
Congrats mike! I can't wait to see this thing go down the track.
QksilverRS is offline   Reply With Quote
Old 02-06-2012, 01:21 AM   #145
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Love the seats
aboothman is offline   Reply With Quote
Old 02-06-2012, 11:33 PM   #146
eliezerrosario
Member#: 141949
2004 Wrx
JBP
Originally Posted by wrx_driver_2002 View Post
GT4094, 2.35L Engine, 8200 Rpms and 28 PSI... Just dyno tuned saturday.
2 questions:
What header?
What cams/size?
eliezerrosario is offline   Reply With Quote
Old 02-07-2012, 12:57 AM   #147
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Originally Posted by eliezerrosario View Post
2 questions:
What header?
What cams/size?
The header is a 1st gen Full Race twin scroll header. The uppipe is a full race twin scroll T4 header. The turbo is a GT4094 with a 0.95 a/r exhaust housing.
The heads are CNC ported B25 heads. They have a total of 1500 miles on them and were 100% brand new when they were machined. During the porting process, the valve seats were enlarged to take advantage of the +1mm intake and exhaust valves. The valves are made by supertech... Nitrided intake valves and inconel exhaust valves.
The cams are Kelford R-199-C cams for an 04-07 STI. 272 / 272 duration. Lift is 11.5mm intake and 11.1mm exhaust. They are setup for avcs but I have not run avcs yet for two reasons.
First reason is my neutral switch operates backwards of how it should which prevents AVCS from working. The other reason is I have absolutely no idea how much advance I can run due to the 9:1 pistons, +1mm valves, and the high lift cams. When the engine was assembled, I did not take the time to clay everything. I have been told that I can run up to 7-10 degrees of advance, but I am not sure running say 5 degrees would really be worth the risk. The car is not daily driven and spool is not my highest priority.
Old 02-07-2012, 01:58 AM   #148
eliezerrosario
Member#: 141949
2004 Wrx
JBP
^thank you
Old 02-07-2012, 06:27 PM   #149
cpturbo
Member#: 49175
2004 STI
Where is MPS and homemade? No comments on this guys results. Seems he has given validation to your collective long rod design. I wish that the boost did not taper as it would have been cool to see the hp keep rising like a supercharger would!!!
cpturbo is offline   Reply With Quote
Old 02-07-2012, 07:17 PM   #150
Maxwell Power
Member#: 190729
that's only half a pound of taper...
What do you want us to say? I'm not surprised by the results at all. I'm very happy to see them here in the thread, but I'm not going to go snubbing people who were naysayers about it. 620whp on a Mustang dyno is no **** jack. I think it says everything we've been trying to say.
I honestly want to change that turbo to a BW. I have a sweet one that flows more and spools faster than a 4094. The larger compressor in that turbo is a slight mismatch and hurts short stroke engines in the spool department.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP leonbmx Proven Power Bragging 75 08-27-2015 03:59 PM
FS : Built sleeved 2.5 block and built 2.0 heads + more sleepysubie Engine/Power/Exhaust 7 06-30-2011 12:50 PM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
What were the results from the Tacoma show? Subarutex North West Impreza Club Forum -- NWIC 6 09-02-2003 01:58 PM
