Old 09-16-2011, 10:24 AM   #26
amanichen
Member#: 163999
07 WRX
Arrow
Originally Posted by matt06wrxwgn View Post
The WRX's affected by the recall are 02-05, 06+ WRX got aluminum control arms
The control arms on my 07 are steel. 06 was the only aluminum year.
amanichen is offline   Reply With Quote
Old 09-16-2011, 02:59 PM   #27
matt06wrxwgn
Member#: 172027
2006 CGM Wagon
322WHP 355 WTQ
Oops, I would have thought that Subaru would've kept with the aluminum arms. I stand corrected.
Matt
matt06wrxwgn is offline   Reply With Quote
Old 09-17-2011, 09:09 PM   #28
celer
Member#: 10706
2005 STI
Man I wish Subaru had a better rust proofing solution for their steel bits on the underside of the car!
My 05 STi looks pretty darn bad, compared to my 96 Miata. I ended up pulling the sub frame today and wire wheeling all the rust down on it and repainting it, along with the mounts for the control arms which were pretty rusty.
A few years ago, I got under there and sprayed LPS-3 on various rusty bits and that seems to have helped a lot.
Today I wire-wheeled stuff and used chasis saver on it.
celer is offline   Reply With Quote
Old 09-17-2011, 09:58 PM   #29
spaceywilly
Member#: 174268
Originally Posted by LT View Post
It looks like several of the number ranges in the above recall letters have reversed the "From" and "To" numbers. At first I thought my car was out of range, but that just didn't make sense.
Then I noticed the "To" number was smaller than the "From" number for the 02 Impreza wagon... so I am guessing my car is probably in the recall...
Yeah the way they list the VINs doesn't make sense to me. For example, for 02 wagons it says:
from
JF1GG68582H800021
to
JF1GG29652G837226
JF1 = Made in Japan
GG = Wagon
6th digit = engine type. 6=2.5L (2.5rs), 2 = 2.0T(wrx)
7th digit = model, 8 = rs, 9 = wrx
8th = restraint type, 5 = no side airbag (2.5rs), 6 = side air bags (wrx)
9th = check digit, random
10th = model year
11th = transmission type, H = 4EAT AWD, G = 5MT AWD
12-17th = sequential production number.
So I think "from" and "to" are misleading, since the numbers aren't sequential. I think (not sure) that you can just focus on the last 6 digits. The rest doesn't matter. So if your car is between 800021 and 837226 you are covered.
spaceywilly is offline   Reply With Quote
Old 09-18-2011, 08:45 AM   #30
Subarudunk
Member#: 179439
2004 STI
JBP
So this is only for the impreza and wrx? Doesn't affect the sti?
Subarudunk is offline   Reply With Quote
Old 09-18-2011, 10:20 AM   #31
Subaru_Nation555
Member#: 83938
'06 2.5i wagon
CGM
It's interesting that DC and Maryland made the list but not Virginia. I guess we don't get enough snow.
Subaru_Nation555 is offline   Reply With Quote
Old 09-18-2011, 01:13 PM   #32
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Correct, the STI has aluminum control arms and as such will not rust (yes, I know aluminum still "corrodes" to a small extent)
Old 09-18-2011, 06:23 PM   #33
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
Originally Posted by mclmk8d View Post
I'm going to check mine as the VIN is in the range. Even though I'm in Florida, we get plenty of rain down here and the humidity is constant. If they are rusty, I'm going to write to SoA and the NHTSA
Keep us updated.
Don't really understand their logic about only doing the recalls in certain states. If the rust proofing is insufficient, it's insufficient.
richde is offline   Reply With Quote
Old 09-19-2011, 03:59 PM   #34
petergun
Member#: 46425
2004 2.5 TS '15 BRZ
Platinum Silver / WRB
Curious when Subaru will add "Saltland", aka Quebec Canada, to a special recall. We abuse salt ... and my 2003 shows it.
petergun is offline   Reply With Quote
Old 09-22-2011, 06:30 PM   #35
Nematoad
Member#: 295372
2004 WRX Wagon
Java Black
My WRX is registered in MD now. I need to take a look under there now.
Nematoad is offline   Reply With Quote
Old 09-24-2011, 12:14 AM   #36
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
I don't know if they're on the recall or not, but 2007 STIs have steel control arms, so do 2006-2007 WRX Wagons.
I rustproof mine every fall, so they still look fine. I wish I could get a set of 2006 STI arms out of this though. I'm sure I'm dreaming.
gpshumway is offline   Reply With Quote
Old 09-25-2011, 12:17 PM   #37
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
My 2007 STI has aluminum control arms...
Godmal is offline   Reply With Quote
Old 09-29-2011, 09:58 PM   #38
2.5i guy
Member#: 151509
2003 WRX
black
I wonder if we can sneak in an anti lift kit install if our control arm need to be replaced?
2.5i guy is offline   Reply With Quote
Old 09-30-2011, 11:15 AM   #39
SubyMass
Member#: 136493
2015 WRX
GBP
Speaking of, How will having an ALK installed affect the recall status? Would I need to remove the ALK and then bring it in for service? Also, I assume they would align the car afterwords if replacement was the service path.
SubyMass is offline   Reply With Quote
Old 09-30-2011, 11:18 AM   #40
RealDealTarheel
Member#: 142447
**** Texas
Are you the original owner or did you swap them over? I thought they swapped them with steel pieces starting in 07, if they didn't that would be cool.
RealDealTarheel is offline   Reply With Quote
Old 09-30-2011, 02:00 PM   #41
Hondaslayer
Member#: 4562
1995 Legacy LSi
If the control arm is being replaced and it includes the transverse link on the control arm then the dealership may (and rightly so) charge you to swap your non factory part onto the control arm.
Old 10-01-2011, 08:05 AM   #42
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Do the steel control arms come with non-removable front-outer bushings?
I wonder if the balljoints are considered removable, with the steel arms, or sold with the arm, by the dealer.
Old 10-02-2011, 01:05 AM   #43
carverboy
Member#: 182678
2002 wrx wagon
Default More of the same
Well our 02 wrx wagon stank of gas every winter since we got it and Rustaru
finally did warranty it.
Now the passenger side control arm has rusted through stranding my wife but luckily she was in a parking lot not on the interstate doing 65!
Once again Subaru is doing a recall that does not include us even though as others stated Western N.C eastern T.N get plenty of snow and insane amounts of calcium chloride and salt.
I have loved driving this car but when we replace it I am going to look for another option. There have been way to many problems with this car and these asinine recalls (how the heck to you confine a recall to certain locations? The problem is the car not the geography! Inspect all of them fix those that are rusting away.
carverboy is offline   Reply With Quote
Old 10-02-2011, 11:28 PM   #44
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
are you saying 2006 wrx sedan has aluminum control arms and 2006 wrx wagon has steel control arms?
Edit: looks like wikipedia confirmed this for me. Well that sucks. what product do you use for rustproofing might i ask?
mechatricity is offline   Reply With Quote
Old 10-04-2011, 12:34 PM   #45
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
I am the original owner and I wouldn't have made my comment if they were not stock. The only mod to my control arms are the whiteline alk I installed. I'm pretty sure that all US STIs have aluminum arms front and rear (the exception being the rear trailing arms).
Old 10-04-2011, 08:48 PM   #46
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
2004 STI had steel control arms I thought; but I've been away from the technical forums for a while now.
OrbitalEllipses is offline   Reply With Quote
Old 10-04-2011, 08:53 PM   #47
Tecolote
Member#: 264381
2002 WRXWGN | SLVR
When do the dealers begin accepting appointments to perform said recall?
Tecolote is offline   Reply With Quote
Old 10-07-2011, 12:25 AM   #48
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Yep, the wagon with it's narrower track (no fender flares) has steel arms. I believe they're the same as the OBS. Looks like you got that through Wikipedia already though.
I use Wurth Body Cavity Protection Spray to rustproof the suspension arms and other steel parts. It's hard to find on their website, but you can order it directly from Wurth USA. Just give them a call. I use Boeshield T9 for Aluminum parts.
http://www.wurthusa.com/project/en/t...contact_1.html
http://boeshield.com/
Sorry for the delayed response... On vacation to an internet wasteland (on purpose).
Old 10-07-2011, 08:41 AM   #49
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Np, thank you for the info. What do you typically treat other than the suspension arms?
found a place that sells it online i think: http://www.goodspeedmotoring.com/wur...ion-spray.html
Old 10-07-2011, 08:50 AM   #50
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Subscribed for November.
Psychoreo is offline   Reply With Quote
Are SPT and STI and WRX front control arm rear bushings same? paulpat Brakes, Steering & Suspension 0 08-26-2011 03:40 PM
Impreza Front suspension bits, oem control arms, rear transverse link bushing psyber_0ptix Private 'For Sale' Classifieds 0 02-18-2006 10:30 AM
Are '02 wagon and sedan lower control arms the same? WagOn02 Brakes, Steering & Suspension 2 06-15-2005 03:41 PM
Curbed my wheel and bent my control arm and possibly knuckle, should I replace? aznfoos Service & Maintenance 5 11-03-2003 05:43 PM
oops, no recall on impreza ecm suberboy General Forum Archive 2 10-16-2000 11:15 PM
