Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 09-13-2011, 12:22 PM   #1
maperformance
Vendor Sales Rating: (78)
Member#: 141043
2013 Boosted FRS
Asphalt
Default Dyno tuning? Engine rebuilds? Porting/Polishing/Machining? MAP does it all in-house!
The MAP Race Program||||Why Choose MAP?||||Our Services||||Inventory Clearance||||What Our Customers Say
The winter season is coming up, and you know that's the best time to get some work done on your car.
MAPerformance can do it all in-house! Need to rebuild yor engine? We do it! Want to port and coat your intake manifold? We do it! Need to tweak your tune so you don't detroy your new build? We do it! Come visit us at our shop in Plymouth, MN, or ship your item to us to get the work done. We utilize many shipping methods to get you what you need when you need it, or to help you save some cash on shipping. Give us a call at 1-888-MAPerformance today to see how we can help you get the work done!
Click to view some examples of the work we can do and to get some more information about our abilities.
__________________________________________________ __________________________________________________
MAP Subaru Shortblocks
We don't settle for anything less than the best in our machining, and portwork, and we certainly don't settle for anything less than the best our engine builds. We have developed techniques and custom solutions for each platform we work on, ensuring our customers get the best builds possible. We choose only the best quality components. When there aren't 'good enough' products on the market, we often times will make our own such as the MAP Ultimate Duty H11 Head Studs for the EJ20/EJ25. We then inspect, blueprint, clean and assemble our engines in our clean room. We have had great success in building countless motors, everything from the weekend warrior to the all out race car.
MAP Porting & Polishing Services
Our porting guru Bob Schreiber has worked on everything from NA applications to boosted nitrous applications, and from single cylinder recreational vehicles all the way to high performance super cars like the Dodge Viper SRT-10, and everything in between. Pulling from his education in fluid dynamics, airflow theory, physics, thermal dynamics, and his real world testing, he is able to bring us nothing less than the best porting and polishing solutions. Over the years he has developed custom tooling (unlike the competition) that allows him to port 'line of sight' and be able to get everything in a manifold even if it is a Viper intake plenum that is ~26" long!
If you are after the most from your setup, and need nothing less than the best porting solutions, look no further than your performance specialists at Modern Automotive Performance.
MAP Machining
As we've grown, we have worked with numerous machine shops that do some things right, and compromise in other areas. It's the same with just about anyone we have worked with. Not willing to settle for anything less than the best in quality, we made the decision to move the majority of our machine work in house to not only better control the quality of the work, but to also minimize time lines.
We have a resurfacing machine that provides a superior RA, or finish, on both cast and aluminum blocks and heads, which is crucial for proper head gasket sealing in modern engines. Ours uses the CBN cutters and provides a superior finish to the older, multi-cutter systems that many shops still use.
Our Boring and honing process is setup to provide a superior bore finish, with tight tolerances in mind. We are able to provide tight tolerances of tenths of thousandths, not half thousandths like many shops do. We do this while still providing a superior finish, plateau finished to perfection for the ultimate in ring sealing, and ring lift.
For our cylinder heads, we have a Serdi seat and guide machine that provides us with some of the industries finest valvejobs. We not only cut seats for the non performance market, but have also designed specific cutters that we use in all our modern 4 valve heads. Every head is also vacuum checked after each seat is cut to ensure that no head leaves with a poor sealing valve. We would then typically set and adjust the installed valve tip height to our specs to ensure proper valve train geometry is maintained.
MAP Custom Fabrication
If you are looking for some of the best fabrication solutions, or products for your vehicle, Modern Automotive Performance has what you're looking for. Our in house fabricators have over 15 years of experience in the import and fabrication industry, and have made everything from simple brackets, to mass produced products, to all out one-off turbo systems, and utilize only the highest quality of materials, tooling, consumables, and processes to bring our customers the best fabricated products and services available at industry fair prices. Whether you're looking to have a blow off valve flange welded and installed, purchase one of the products in our ever expanding MAP product line, build a fully prepped race car, or anything in between, we have what you're looking for. Some of our services and tooling include:
  • TIG welding with back purge capabilities if needed
  • MIG welding
  • Plasma cutting
  • Oxy-fuel cutting
  • Sheet metal bending
  • Bandsaw cutting
  • And much, much more
Whether you have a lightly modded daily driver, a weekend warrior, or a tube chassis race car, the fabricators and staff at MAPerformance will turn your dreams and ideas, into the products and power that no one else can deliver.
MAP AWD Dyno Tuning
Dynamometer and EFI tuning at MAPerformance is performed by Jordan Schreyer. In July of 2008 Jordan decided to discontinue his own business venture, Consummate Tuning, in order to become a part of the MAPerformance family. With years of tuning experience under his belt he has been a valuable asset to our team and allows us to offer a complete performance solution to our customers.
As with the rest of the MAPerformance team Jordan eats, sleeps, and breathes automotive performance. He has over 10 years of tuning experience ranging from forced induction imports to carbureted big block V8's. Whether you are looking for an aggressive daily driver or an all out race monster your vehicle is in good hands at MAPerformance!
The Dynojet 424x All-Wheel Drive Dynomometer
Dynojet now gives you the ability to run front wheel, rear wheel, and all wheel drive vehicles all on the same dyno. This Model 424x is comprised of a pair of state-of-the-art 224x's, capable of measuring 1500 + all wheel horsepower each. Horsepower and torque measurements can be done on front and rear wheels separately or front and rear wheels combined. This makes tuning or troubleshooting any part of the drivetrain, front or rear, a snap.
We can tune a large number of platforms, including but not limited to:
  • AEM EMS
  • Cobb AccessPORT
  • Open Source ECUFlash
Please contact us for unbeatable pricing on these products & services. Also keep in mind we will match or beat any competitors pricing on so called "package deals"!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
I want to earn your business, PM me and tell us how we can become your one stop shop for performance parts today!
ACL / AEM / ACT / Cosworth / Grimmspeed / Invidia / Ksport / Manley / Mishimoto / PTE / Tomei / Turbosmart / Wiseco
maperformance is offline   Reply With Quote
Old 09-13-2011, 06:59 PM   #2
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-14-2011, 05:35 PM   #3
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
PM Me For Great Deals!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-15-2011, 05:19 PM   #4
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Thursday is YOUR day to save!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-16-2011, 04:42 PM   #5
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Save on the weekend @ www.maperformance.com
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-19-2011, 05:51 PM   #6
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-20-2011, 06:27 PM   #7
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-21-2011, 04:23 PM   #8
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Wednesday Bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-22-2011, 05:38 PM   #9
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-23-2011, 05:47 PM   #10
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-25-2011, 03:40 PM   #11
scoops04wrx
Member Sales Rating: (31)
Member#: 150966
04 WRX
Man. only if u guys were located in MD or NJ
scoops04wrx is offline   Reply With Quote
Old 09-26-2011, 03:23 PM   #12
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Ship your car up here! The price of shipping is generally $600-800 and its how the majority of our customers choose to get their projects here. There is certainly something to be said about a true one stop shop
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-27-2011, 05:15 PM   #13
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-28-2011, 05:17 PM   #14
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-29-2011, 04:40 PM   #15
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
PM's Sent and Replied!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-30-2011, 04:09 PM   #16
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-03-2011, 07:17 PM   #17
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-04-2011, 06:05 PM   #18
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-05-2011, 07:13 PM   #19
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Wednesday Bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-06-2011, 08:43 PM   #20
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Working on the STi bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-10-2011, 01:12 PM   #21
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Monday bump! Hope you guys had a good weekend!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-12-2011, 12:07 PM   #22
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Wednesday bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-14-2011, 03:49 PM   #23
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Have a good weekend!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-17-2011, 11:12 AM   #24
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Monday bump, hope you all had a good weekend.
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 10-20-2011, 02:44 PM   #25
maperformance
Member#: 141043
2013 Boosted FRS
Asphalt
Payday bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Compressor Housing Machining? Who does it? Token-Negro Built Motor Discussion 4 03-18-2009 11:12 AM
to OT man-whores: does it all feel the same? kkulbo0 Off-Topic 29 11-29-2004 09:17 AM
Relaxed, regular, straight, classic... wth does it all mean? NeoteriX Off-Topic 11 11-27-2004 02:11 AM
Car codes GC GF etc... What does it all mean? Mandrich Newbies & FAQs 7 08-09-2003 01:32 PM
205/55-16's 215/45-17's what does it all mean? Matey Brakes, Steering & Suspension 10 04-06-2001 12:43 AM
