Old 09-14-2011, 01:11 AM   #1
blackedoutkwrx
Member#: 287582
04 wrx
java black pearl
Default cobb AP not hitting peak boost. solenoid issue. please help
i had my car tuned to stage 2 cobb. it was not hitting peak boost. the car was hitting 13.9 psi. after tons of testing and talking to my tuner the only way my car will hit peak boost is to leave the hose to the BCS off. i only did this once for fear of boost surge. please let me know whats wrong and how i can fix it!
thanks!
blackedoutkwrx is offline   Reply With Quote
Old 09-14-2011, 10:47 AM   #2
Cobb Tuning
Member#: 4803
Hi there. Is this an AccessPORT version 1 (b&w screen) or version 2 (color screen)? If version 2, do you have any logs? Is this an 04 WRX? What is an exact list of your mods? If this is a custom map, what does you tuner say the peak boost target is? What is your altitude? What gear are you in and at what RPM are you starting your wide open throttle run in order to measure your peak boost? Have you had a pressure test or smoke test of the intake tract to look for boost leaks?
Bill
Old 09-14-2011, 11:06 AM   #3
blackedoutkwrx
Member#: 287582
04 wrx
java black pearl
version 2. i have some logs. how do i post them? this i sjust the high wastegate stage 2 93 octane map. it is working now with the stock boost solenoid unhooked. it doesnt spike or anything. a very nice steady 16.9 psi. i have not done a boost test.
Old 09-14-2011, 12:14 PM   #4
Cobb Tuning
Member#: 4803
You can post your logs on google docs and share the link (make sure you change the permissions so that it is public).
I would do a 3rd gear run from about 2000 RPM to near redline (if you can so safely) with the default AccessPORT logging set.
Can you list all your mods?
Bill
Old 09-14-2011, 12:21 PM   #5
blackedoutkwrx
Member#: 287582
04 wrx
java black pearl
ok i will try to post the logs.
3rd gear run the whole way to redline is 13.9 psi. will not budge at all over that. i will log a bunch of stuff and try and post asap!
thanks
mods: spt intake, perrin uppipe, megan racing downpipe, invidia n1 race catback, cobb stage 2 high wastegate map. thats all performance wise
HELP turbo sounds weird and not hitting peak boost Adrenalinecrisis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-12-2010 06:25 PM
Not hitting peak boost with Accessport V2 and extreme taper. BrianMR2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-05-2010 12:00 AM
FS: MA Cobb AP V1 & HOA Boost Solenoid brrrrrbecold Engine/Power/Exhaust 4 11-10-2009 02:42 PM
Not hitting peak boost :( eurospek AccessPort 1 08-30-2007 08:38 PM
not hitting peak boost with vf 34 blackrod punishment General Community 9 03-07-2006 10:45 AM
