Old 09-14-2011, 08:10 PM   #1
clays_obs
Member#: 287213
Outback Sport Badge Mark After Debadging
I did a full debadging on my GF, and the subaru badge on the hatch still left a white outline. After using adhesive remover and a clay bar, I tried gel sanding, and it's still pretty clear. I was wondering if anyone had any products that they think would get rid of it. I feel like I've tried everything and have been thinking about just doing the GF/GC WRX decal on the hatch to take the attention away. Any suggestions???
clays_obs is offline   Reply With Quote
Old 09-14-2011, 08:20 PM   #2
02subiewrxvt
Member#: 163344
2014 WRX
what year? 02-03? if so this is very common, it is ghosting from the badges being on the car so long in sunlight that the paint has faded, nothing you can really do about it... i had the same problem on my 02 after a while it wasent that noticeable i felt
02subiewrxvt is offline   Reply With Quote
Old 09-14-2011, 08:21 PM   #3
tstevensWrX
Member#: 269681
I have the same exact issue on my GD, would be awesome to find a solution. I've used a buffer, 3M Rubbing Compound, Rubbing Alcohol, Clay Bar, Turtle Wax polish and it still is on there. I was told it may be the clear coat and quite possibly have to try and wet sand it or repaint. If you find a solution let me know, would love to try it
tstevensWrX is offline   Reply With Quote
Old 09-14-2011, 08:51 PM   #4
clays_obs
Member#: 287213
Try gel sanding with any kind of circular/rotary polisher. It got most off but i think I'll just have to repaint eventually.
Old 09-14-2011, 10:13 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
The painted surfaces around emblems are typically hard to get at and are therefore easily neglected. “De-badging” reveals the flaws in these areas and will typically result in a crisp, visible border where the emblem once was (especially on older applications). ....appearing like the paint has faded. This is usually the case and using a compound/polish to thoroughly and completely correct the affected area will typically result in an even finish. ....at least in my experience.
Kean is offline   Reply With Quote
Old 02-04-2012, 02:58 PM   #6
crotchbuffet
Member#: 205324
2002 Impreza wrx
midnight blue pearl
a rubbing compound will NOT work for this. for me the only thing that worked was sliding a razor over the lines. because what we are talking about isn't the paint being faded but just being able to see the outline of the badges. i gently slid a razor over the lines and it scraped off although this is dangerous so i only did one line then stopped. im just gonna rebadge until i have money for paint and shaving the keyhole.
crotchbuffet is offline   Reply With Quote
Old 02-04-2012, 04:03 PM   #7
fenderpicks
Member#: 287694
2011 WRX
If compond doesnt take it off... then sanding is probably the best thing to do... but i doubt anyone would want to sand their car just because of that reason.... (Not worth it)
But compound is suppose to remove the clear coat and everything else on top of the base... so if that doesnt work... the badages must have been on the car a long a$$ time
fenderpicks is offline   Reply With Quote
Old 03-14-2012, 03:40 PM   #8
kashmycek
Member#: 269972
blue
Same thing happened to me.. I used scratch remover and it came off right away.
kashmycek is offline   Reply With Quote
Old 03-16-2012, 06:01 PM   #9
seuss78
Member#: 313758
crystaltek makes a product called ghost off which you can try
seuss78 is offline   Reply With Quote
Old 03-23-2012, 12:41 AM   #10
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
I wouldn't really trust any "scratch-remover" or filler or any other liquid product. The only real way to get out these marks would be to buff it out using a two stage polish. If you use a super intensive polish compound, then it will remove the clear coat slightly and even the paint. It should take it right out. You could go to pretty much any detail/body shop, and they would probably be able to take it right out with a quick polish and wax of that area. At the shop I work at, for that process, I'd probably charge around $15 as it would only take about 10 minutes or so.
07STifastashell is online now   Reply With Quote
Old 03-23-2012, 01:51 AM   #11
scx89
Member#: 269388
2011 Impreza WRX
obp
I used a cleaner wax and it became a lot better..
scx89 is offline   Reply With Quote
Old 03-23-2012, 02:52 AM   #12
NMZ_WRX
Member#: 198280
2007 BLACK MONSTER
WINGLESS
clay bar
buff
NMZ_WRX is offline   Reply With Quote
Old 03-23-2012, 12:14 PM   #13
AspenScoob255
Member#: 217405
2006 WRX
A vast majority of today's polishes and compounds are in Liquid form. Your advice slightly conflicts, when you say liquid products wont work in this situation. The term "scratch remover" is generally a marketing term for a mild abrasive (in some cases light abrasives with fillers) polishes to make it easier for consumers to understand what they are looking at.
I see in another of your posts you state you work in a "high end" shop, so I will assume you know what your talkimg about and chalk this up to a proof reading error. Alot of people aren't really in the know, so when you explain things take that into consideration. If you offer conflicting or unclear advice it leads people to do some "interesting" stuff...and they blame it on you, which I'm sure you have dealt with in a shop environment.
AspenScoob255 is offline   Reply With Quote
Old 03-23-2012, 12:25 PM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
....Im also curious about these so called "super intensive polish compounds" on the market.
....I'll wager he's talking about Menzerna PO85RD (aka Super Intensive Polish) which he must be using in his shop.
Old 03-23-2012, 12:27 PM   #15
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Originally Posted by NMZ_WRX
clay bar
buff
/thread
todeswalzer is offline   Reply With Quote
Old 03-23-2012, 12:29 PM   #16
fulltimeW.O.T.
Member#: 120414
2009 WRX 5Dr DGM
Stage 2+Meth
its probably due to the paint at that spot wearing in differently compared to the rest of the pain on the car. if that is the case, no chemical stripper or buffing or wax will fix the issue. You can't fix un faded paint. But if the issue is within the clear coat, you could try 2000+ wet sanding or buffing compound or polishing compound. Try out the cheap turtle wax buffing compound (red in color i believe) then move on to the green polishing compound (white paste i believe).
fulltimeW.O.T. is offline   Reply With Quote
Old 03-23-2012, 03:02 PM   #17
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
You sir, are correct. And to the other guy who said Polish is a liquid...it's more like a paste. I meant any liquid filler that one might see being marketed as a quick fix. As in there are no ways to fill this, a layer must be slightly removed to remove this badge mark.
Old 03-23-2012, 04:10 PM   #18
AspenScoob255
Member#: 217405
2006 WRX
Thats what I figured
Yep...that was me (the other guy). I'm not going to argue consistency with you, I was trying to eliminate confusion. For example, liquid vs paste wax, the "liquid" version isn't watery but it is of thinner consistency compared to the paste. Hence, the term "liquid", as there are paste compound and polishes out there; or whatever it is turtle wax labels them as.
I made this clear in my initial post, just trying to eliminate confusion (for others). Not trying to discount any of your advice, as I am assuming you didn't read my whole post and took my first sentence as a slight. Mostly my fault I suppose, improper post organization and all. Even after I just said something about proof reading....
Old 03-23-2012, 05:07 PM   #19
Kean
Member#: 25187
'08 Foz Prem TGM
While detailing terminology is not standardized in the industry, most polishes folks will relate to are those in bottles that are in liquid form. When someone says "paste", it usually refers to products in tubs/cans like Mothers Aluminum and Mag Polish or those old ones we remember from TW as Aspen explained. In reality, the point isn't the state of the packaged product but more about individual characteristics. Generalizing leads to confusion on these topics IME.
....btw, here are just a few "polishes" in liquid form that I happen to have in my own cabinets that do "correct" blemishes (abrade):
Meguiars UC, Meguiars Swirl-X, Meguiars Scratch-X, M105, M205, Optimum Polish II, Optimum Compound II, polishes from 3M's Finesse It and Perfect It lines, etc., etc.
Old 03-23-2012, 05:32 PM   #20
AspenScoob255
Member#: 217405
2006 WRX
^^^There it is....that's what I was trying to say.
Your so much better at explaining than me .
Old 03-23-2012, 05:44 PM   #21
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Sorry I'm on nasioc app just kind of skimming posts here. Agreed..
There are liquid polishes and more paste-like polishes...just describing constituency of the product with my word choice. Thanks for the clarification for others.
Old 03-23-2012, 11:07 PM   #22
nasiocanuck
Member#: 288559
2004 WRX Wagon
i just did this yesterday on my 03. i used goof-off and then a orbital polisher with a quality wax about 3 times and it looks perfect!
nasiocanuck is offline   Reply With Quote
Old 04-09-2012, 10:16 PM   #23
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Razor will work but make sure they r stainless will really reduce chances of scratching the paint. Any other type will most likely scratch the paint
trev762 is offline   Reply With Quote
Old 04-10-2012, 12:15 AM   #24
methodically
Member#: 315105
2012 WRX
Bluuuue baby!!!
If you have polished the area(s) and still have the issue, I wouldn't risk taking anymore paint off. It's possible that the sun will take out SOME of darker area that has been covered. It will take some time though and likely more than you will want. Polish the area and try to fan out 6-8 inches around where the darker area is and see how that goes. If not.. i'm not sure what to tell you.
I had this problem with my Z and it took quite a few times with the buffer to get MOST of it, but you could still faintly see it if you looked hard enough. Then again, I wound up getting Nissan to repaint all of the plastic since it's almost always at least 1 shade off of the rest of the car due to the properties of plastic painting vs. steel or aluminum.
methodically is offline   Reply With Quote
Old 04-14-2012, 08:51 PM   #25
spike93
Member#: 190292
2005 stage II wrx
CGM
To the OP, what color is your car? There are a variety of things you can try. Many have actually been posted and they are good recommendations. If you haven't tried this yet, get an orbital buffer with a good compound, buff that on around 1000-1200rpms. Then wipe off the residue, and come back with either a really good polish or a wax designed to bring back and enhance color. Use your buffer again at 1800rpms, but use a small amount of pressure on the paint. Basically rest the buffer on the paint and let it do all the work. This should take care of your problems.
You can pm for better directions if you like
spike93 is offline   Reply With Quote
Some residual goo after debadging Phx Cobra Car Care & Detailing 21 03-03-2008 12:45 PM
Removing buildup around "subaru" lettering after debadging? iamcgr Interior & Exterior Modification 11 07-18-2007 01:23 AM
I still need help after debadging :( SoareS Car Care & Detailing 44 12-02-2005 04:17 PM
subaru letters still seen after debadging... Otaku64 Car Care & Detailing 16 07-18-2002 11:21 PM
Ideas after debadging.. Tats Car Care & Detailing 11 05-01-2001 09:56 PM
