Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 04-14-2012, 10:01 PM   #26
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Originally Posted by spike93
To the OP, what color is your car? There are a variety of things you can try. Many have actually been posted and they are good recommendations. If you haven't tried this yet, get an orbital buffer with a good compound, buff that on around 1000-1200rpms. Then wipe off the residue, and come back with either a really good polish or a wax designed to bring back and enhance color. Use your buffer again at 1800rpms, but use a small amount of pressure on the paint. Basically rest the buffer on the paint and let it do all the work. This should take care of your problems.
You can pm for better directions if you like
Fyi.... the speeds you're describing are for a rotary (not an orbital). Not sure if that's what you actually meant.
Kean is offline   Reply With Quote
Old 04-15-2012, 05:54 PM   #27
spike93
Member#: 190292
2005 stage II wrx
CGM
Ah yea good catch, thank you. My fingers were thinking faster than my brain.
spike93 is offline   Reply With Quote
Old 04-16-2012, 12:16 AM   #28
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
This worked pretty well for me on my car but not as good on my gf's black car.
http://www.allcorsa.co.uk/forums/sho...er-26908.html?
kimokalihi is offline   Reply With Quote
Old 05-02-2012, 04:51 PM   #29
allison_scout
Member#: 318758
2004 Impreza 2.5RS
Java Black Pearl
I'm having this issue on my 04 jbp RS. Its not all that noticeable unless your looking for it, but still annoying. Guess I'll find a friend with a buffer. Are clay bars worth the $20??
allison_scout is offline   Reply With Quote
Old 10-04-2012, 03:07 AM   #30
kelei
Member#: 298485
2002 Impreza WRX
With all this talk about using a clay bar, buffers and polishers, does all this apply to simply removing the solid white outline of the glue?
kelei is offline   Reply With Quote
Old 10-04-2012, 08:22 AM   #31
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
I have never removed any badging unless the car was less than a few months old. Too much risk of fade.
If you still have glue, try a little heat and rub it off
dsn112 is offline   Reply With Quote
Old 10-04-2012, 08:38 PM   #32
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
I have a 2004 Java Black STI. Rubbing compund helped, but did not remove everything. I had to wet sand (lightly) with 3000 grit sandpaper. I then used Meguiars ultimate compound followed by their ultimate polish and viola, no more ghost marks!
Brown Ops is offline   Reply With Quote
Old 10-08-2012, 10:17 AM   #33
RileyD
Member#: 333679
2006 STi
Crystal Gray
After I removed the dealership badget it left a thin layer of residue. Most annoying thing ever.
RileyD is offline   Reply With Quote
Some residual goo after debadging Phx Cobra Car Care & Detailing 21 03-03-2008 12:45 PM
Removing buildup around "subaru" lettering after debadging? iamcgr Interior & Exterior Modification 11 07-18-2007 01:23 AM
I still need help after debadging :( SoareS Car Care & Detailing 44 12-02-2005 04:17 PM
subaru letters still seen after debadging... Otaku64 Car Care & Detailing 16 07-18-2002 11:21 PM
Ideas after debadging.. Tats Car Care & Detailing 11 05-01-2001 09:56 PM
