Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-14-2011, 08:25 PM   #1
xVern
Member#: 241860
2008 LGT
Default Blower motor relay location?!
I searched to troubleshoot/fix the problem. I came to the conclusion it was the relay. Ordered the part for 7 bucks shipped, got in the the mail today.
I can not find it! I've been looking around the fuses. All the searching told me it was above fuses, in a vertical stack with other relays. And it is the top one, usually with a clear plug.
Does anyone have a picture of this?
In a 93 L. Hell, i can take pictures of where im looking if that'd help too. This has me so frustrated!
xVern is offline   Reply With Quote
Old 09-19-2011, 11:27 AM   #2
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Find blower motor wiring connection in passenger footwell under dash. follow wiring back to resistor. Should be bolted HVAC box somehow.
Seahawk is offline   Reply With Quote
Old 11-04-2011, 08:37 PM   #3
ProjektPhoto
Member#: 156702
2004 Impreza WRX
Aspen White 52E
this may be fixed by now but for anyone interested, the heater/AC blower motor relay is on the left side of the interior fuse box (sitting in the car) its the top one.
Now if only I could figure out what the bottom one is?
ProjektPhoto is offline   Reply With Quote
Old 11-04-2011, 09:29 PM   #4
xVern
Member#: 241860
2008 LGT
Had a shop tell me they were 100% sure it was the switch, spent 50 bucks on a new one, wasnt the problem . I still have the relay, still can't find where it goes. The relay i have seems pretty big, is there any way you can snap a picture of it? That is, if you have a GC.
Old 11-04-2011, 09:55 PM   #5
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
This is the location on my 93 Legacy, should be pretty much the same for your Impreza.
Clear out this jumble of wiring.
Blower motor relay is the white one. While you're looking around up there you will probably come across a green relay which is for the fuel pump, and a big brown box which is the ignition/main switch.
Jessekrs123 is offline   Reply With Quote
Old 11-04-2011, 10:26 PM   #6
xVern
Member#: 241860
2008 LGT
Is that called an "ac relay" or "blower motor relay"? Because im only finding an "ac relay" at subaruparts.com and http://www.subarugenuineparts.com/. And the "blower motor relay i bought seems to be too big. Here is a picture of the relay i thought it was and bought:
(dont mind the beer spill)
Old 11-05-2011, 06:26 AM   #7
ProjektPhoto
Member#: 156702
2004 Impreza WRX
Aspen White 52E
To be honest with you im not sure what that rectangular part is that you posted. I have an 04 wrx and my fan motor (Both A/C and Heat) run off a relay that looks like the one that Jessekrs123 posted
Old 11-05-2011, 07:24 AM   #8
Jessekrs123
Member#: 236927
1984 BRAT
The dealer part number for the blower motor relay you are looking for is 82501GA240. (I'm pretty sure that is the part number for my legacy, it just says "relay" on the bill but it was around the time I remember getting it)
Get it from the dealer because when I went out looking for this relay, it was more expensive at the parts stores than it was at the dealer. It'll run you around $35.
The A/C relay is a different part located behind the glove box somewhere and is not the same relay.
Old 11-06-2011, 09:59 AM   #9
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
OP what was the original problem?
Are you looking for the blower motor relay or blower motor resistor?
My directions above were for the blower motor resistor, which is bad usually if your blower motor only works on one setting (usually high).
If your blower motor is not working at all, then it's probably the blower motor relay, which is usually in the underhood fuse box. I just looked at the 03 FSM and it is, and I think it will be the same for your 93.
The AC relay turns the AC compressor on and off.
Old 11-06-2011, 01:01 PM   #10
xVern
Member#: 241860
2008 LGT
This is the first i've heard about it being under the hood.
Old 11-06-2011, 01:09 PM   #11
xVern
Member#: 241860
2008 LGT
I just looked, and all of my under the hood relays are labeled "a/c relay".
Old 11-06-2011, 04:42 PM   #12
Jessekrs123
Member#: 236927
1984 BRAT
Blower motor relay is certainly not located in the underhood fusebox, those relays are for the radiator fans/A/C components.
I have a detailed diagram above of where the blower motor relay is located on my 1993 Legacy which should by WAY more similar to the OP's 93 Impreza, rather than what Seahawk's 03 FSM states.
Make sure you didn't blow out the blower motor fuses when you were going through and testing. (Been there, done that)
I even gave you a part number, what more do you need?
Boy I'm cranky today...
I guess you can ignore my advice, despite having dealt with your same problem in my Legacy, and testing everything that has to do with the blower motor under the sun... but what do I know right?
Last edited by Jessekrs123; 11-06-2011 at 04:51 PM. Reason: cranky cranky cranky....
Old 11-08-2011, 08:18 PM   #13
xVern
Member#: 241860
2008 LGT
Wasn't ignoring you, just exploring all options. The part number you gave me is on it way! Now i just gotta figure out how to get up in there.
Old 11-28-2011, 05:35 PM   #14
xVern
Member#: 241860
2008 LGT
It was hard to get to that relay, but it did the trick! That part number was the best info i got, thanks!
Old 12-14-2011, 12:18 PM   #15
Jessekrs123
Member#: 236927
1984 BRAT
Glad you figured it out, it takes a lot of fiddling to fit your hands in there and disconnect the relay.
Old 01-20-2012, 05:17 PM   #16
researchjunkie
Member#: 307533
Default Blower Motor Relay Location Diagram Picture
Go to this link for the wiring diagram for a Subaru Impreza 1999-2001 A/C and Blower Motor Relay Location:
http://ken-gilbert.com/wrx/mans/99-0...%20Diagram.pdf
researchjunkie is offline   Reply With Quote
Old 06-23-2012, 10:44 PM   #17
Mairesa
Member#: 192150
2003 WRX Wagon
blower resistor was located, replacement part received and install successful ... all sorted out and up and running again.
Last edited by Mairesa; 07-06-2012 at 09:19 AM. Reason: previous question was not relevant and I don't know how to delete the post
Mairesa is offline   Reply With Quote
How to test hvac blower motor relay? cueball89 Service & Maintenance 3 03-18-2014 01:34 AM
FS : 94 L Parts: Underhood Fuse Block, Blower Motor, Fan Speed Resistor/Relay haloseven 1993 - 2001 Impreza Specific Parts 1 08-21-2011 01:10 PM
Blower motor/relay problem? szeny Electrical & Lighting 12 08-10-2010 11:06 AM
Blower Motor Relay Location? pdpdad Electrical & Lighting 2 04-17-2008 02:55 PM
blower motor relay location? 25thIMPREZA Service & Maintenance 1 07-22-2006 04:02 PM
