Old 09-15-2011, 04:06 AM   #1
Airboy
Member#: 72829
2006 WRX
2015 WRX
Default "Boost" in AP not referenced to atmospheric pressure?
Noticed that the Boost item in the AP is not referencing the local atmospheric pressure. It appears to be Manifold Absolute Pressure - 14.7psi.
Airboy is offline   Reply With Quote
Old 09-15-2011, 09:24 AM   #2
Cobb Tuning
Member#: 4803
Hi Sunny,
The AP "Boost" parameter monitors the ECU's manifold relative pressure calculation (manifold absolute pressure - actual barometric pressure). If you can tell me the vehicle in question, I can double check to make sure there isn't any kind of issue. Also make sure you don't have an old firmware version on the AP in question.
Bill
Old 09-15-2011, 05:29 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Originally Posted by Cobb Tuning View Post
Hi Sunny,
Bill
Hi Bill
This was on an 08 STI running the most recent firmware. It had the air pump deleted and originally had the combi-valve removed, causing the Atmospheric pressure readings to go to +21.7psi. Despite that, the data logs that he sent me showed "normal" values for boost. After seeing the car in person and re-connecting the valve the boost readings were still "off". I am at 3500' ASL.
Old 09-15-2011, 06:14 PM   #4
Cobb Tuning
Member#: 4803
Originally Posted by Airboy View Post
Hi Bill
I checked this monitor for the 08/09 STi and it is defined correctly.
The baro. pressure monitor via SSM is determined differently that the baro. pressure subtracted from MAP to determine manifold relative pressure that is logged via "Boost" monitor. I think what is happening here is that the baro. pressure used for MRP has a failsafe value (14.7 psi) when a related DTC is set, while the SSM monitor does not. After reconnecting the valve, did you also reset the ECU?
If you have further concerns about this, take a memory snapshot with the AP (via troubleshooting menu) with key on engine off. Pull the MEM_SNAPSHOT file from AP with AP Manager software (as you would do with a log) and send it to me. I'll be able to tell for sure what is going on then.
Sincerely,
Bill
Old 09-15-2011, 07:31 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
Thanks for the reply Bill. Don't have access to the car any more. May be it is just me remembering it wrong...
Atmospheric Pressure Sensor ElizRN Transmission (AT/MT) & Driveline 12 03-07-2016 07:47 PM
can AP handle aftermarket bov venting to atmosphere? sidwin AccessPort 1 01-12-2008 03:43 PM
v2 AP not linking to pc?? blackdub06 AccessPort 3 03-11-2007 11:35 PM
Atmospheric pressure at altitude and boost compensation? john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-04-2002 01:30 PM
MAP & Atmospheric Pressure Sensor Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-01-2002 12:45 PM
