Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 09-15-2011, 01:53 PM   #1
avatarr
Member Sales Rating: (1)
Member#: 14010
'04 APS-ified STi
TopSpeed Tuned - Black
Default New In Box Paradigm AMS-350 In-Wall High-End "Audiophile" Speakers
Price: $300 each ($100 off if you buy all 7)
Selling seven (7) new-in-box, never been used or opened Paradigm AMS-350 in-wall speakers with white (paintable) grills. I originally purchased these for a home theater project but it never ended up happening.
I prefer local pickup in the Washington, DC area but will consider other locations.
I have seven of these and the stated price is per-speaker (not pair). I would prefer a single buyer for all seven but I'm open to single / pair sales. If someone buys all seven, I will knock off $100 from the total asking price.
Reviews / Outside Information
Gibby's
Home Theater Review (pdf)
Additional Info:
The Paradigm AMS-350 has superior high-frequency response, exceptional midrange clarity and definition and even better bass performance. Not to mention rigid, high-strength chassis and mounting brackets.
Full-Perimeter Bracket Design. Unlike typical mounting ears, brackets cover the full diameter or height and width of the speaker chassis to effectively sandwich and strengthen the area around the mounting hole.
Advanced High-Power S-PAL Satin-Anodized Pure-Aluminum Domes. Ferro-fluid damped and cooled. The low-mass tweeter domes with treated textile suspensions are exceptionally rigid. Extremely uniform and instantaneous power response.
Advanced High-Power Mineral-Filled Co-Polymer Polypropylene Cones. Large, computer-optimized magnets and high-power motor structures promote natural and detailed sonic reproduction with outstanding extended bass response.
The supremely rigid die-cast structure reduces resonances and standing waves, while the aluminum does double-duty as a heatsink.
High-Strength GRIP Glass-Reinforced Injection-Molded Polymer Chassis and Mounting Brackets. Design strength/rigidity reduces the problems of vibrations and resonances.
Paradigm AMS-350 In-wall Speakers Technical Specifications
  • Design: 3-driver, 2-way in-wall / in-ceiling, die-cast chassis / mounting bracket
  • Crossover: 2nd-order electro-acoustic at 2.0 kHz
  • High-Frequency Driver: 25-mm (1 in) S-PAL dome, die-cast heatsink
  • Bass / Midrange Drivers: Two 210-mm (8 in) mineral-filled polypropylene cones
  • Low-Frequency Extension: 35 Hz (DIN)
  • Frequency Response: On-Axis: 2 dB from 55 Hz - 22 kHz
  • Frequency Response: 30 Degrees Off-Axis: 2 dB from 55 Hz - 20 kHz
  • Sensitivity - Room / Anechoic: 94 dB / 90 dB
  • Suitable Amplifier Power Range: 15 - 200 watts
  • Maximum Input Power: 150 watts
  • Impedance: Compatible with 8 ohms
  • External Dimensions: 51.0 cm x 23.1 cm (20-1/16 in x 9-1/16 in)
  • Minimum Mounting Depth: 7.6 cm (3 in)
  • Cutout Dimensions: 48.6 cm x 20.5 cm (19-2/16 in x 8-1/16 in)
  • Minimum Internal Volume Required: 40 L / 1.40 cu ft
  • Weight (unpacked): 5.8 kg / 12.8 lb each
  • Finish: White, paintable
avatarr is offline   Reply With Quote
Old 11-05-2011, 07:04 AM   #2
speedtripper
Member#: 300073
Default wanted paradigm ams 350
Hi do you still have the paradigm speakers? If so are you willing to include shipping in the listed price? i live in ohio
speedtripper is offline   Reply With Quote
FS : Sold This Clutch James-SLO Drivetrain 5 09-25-2011 12:39 PM
*New In Box* Focal speaker set jpwulf NWIC Private Classifieds 12 03-12-2010 03:07 PM
WTT-New in box Magellan Roadmate 1200 GPS for a new in box Navigon 2100 ScoobyNubieToo! Non-Subaru Stuff 2 11-25-2007 05:29 PM
Logitech 5 watts 2.0 X-120e stereo speaker - Retail New in Box proletariandan MWSOC Private Classifieds 0 12-02-2006 10:15 PM
FS: Polk DB400 speakers new in box 04STiguy Interior/Dressup/Audio & Security 0 10-05-2006 03:17 AM
