Old 05-16-2001, 06:09 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Post Scratches on Window!!!
I have a MY99 legacy 2.5 GT and have tinted the car for over a year now!!! I have noticed gradual hairline scrathes appearing on all four windows...WHAT IS CAUSING THIS??? Is the tint scratched from the inside??? Is the window scrathed from the outside??? What should I do???
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 05-16-2001, 06:37 PM   #2
Skeandhu
Member#: 1056
Post
I have the same problem on my RS - the scratches are on the outside of the window; the tint should be fine.
Scratches are caused by the mechanism inside the window - the rollers methinks.
You're not alone in this problem, I assure you. As for what to do about it - dunno
Has anyone else here tried to get this warranty replaced?
Skeandhu is offline   Reply With Quote
Old 05-16-2001, 07:45 PM   #3
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Post
skeandhu is right - your aren't alone. My Legacy has the same problem on the front windows (power windows). In fact, recently, my drivers side window began squeaking when lowering it.
It seems that the brushes on the guides inside the door wear out very quickly, and cause the window to rub against a plastic piece. I'm trying to find the part numbers for replacements.
Good luck
BJamerican is offline   Reply With Quote
Old 05-16-2001, 07:59 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
Post
MY RS did it from day one.. I asked them about it and they said it was normal.... I can't tell on mine if its inside or outside, either way its starting to bother me and makes things look really funny in the rear viewmirror.
STiTuner is offline   Reply With Quote
Old 05-16-2001, 08:00 PM   #5
alexs001
Guest
Member#:
Post
The dealership here is warrantying windows under bumper to bumper (3 yr). This eventually happens to all of the windows. Mine are quite bad. My friend at the local dealership traded me one of my bad ones for another less bad one that they had warrantied. Check your dealer to see if they could do the same for you.
Scratches on window? Gorge Car Care & Detailing 3 11-05-2006 11:49 PM
How to remove scratches on window hp12c Interior & Exterior Modification 4 12-22-2003 04:38 PM
Thin scratch on driverside window? HIHO Legacy Forum 13 11-21-2001 12:04 AM
Vertical scratches on windows digger Interior & Exterior Modification 10 09-17-2001 09:02 PM
Ugly scratches on front windows chuckpfl General Forum Archive 0 09-05-2000 10:38 AM
