Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 09-16-2011, 06:54 AM   #1
Member#: 265265
2004 RSti
Midnight Blue
Default Heavy vibration under acceleration, possible issues?
About a week ago my car (04 wrx) started getting a light vibration around 35-55 mph. I figured it was just my exhaust hitting my unibody because it does that at certain engine speeds.
Yesterday when I went to make a pass I dropped to 2nd and got on it. The problem is now alot more severe. It vibrates heavily when under acceleration, mildly in neutral, and it smooths out when down gearing down hills.
I put the car on stands yesterday and the drive shaft is fine and the motor mounts are tight. The only thing I noticed is the front right axle boot is ripped, it had to happen in the past two weeks because I just put a new suspension set up on the car. I thought that torn boots usually effected turning and not the spinning motion of the axles.
Could this be the source of my issue, are there any other things I should check out?
Elemento1991 is offline   Reply With Quote
heavy vibration under load!!! please help ride918 Transmission (AT/MT) & Driveline 10 04-03-2012 09:36 PM
97 OBS vibration under acceleration only. darksc00by Transmission (AT/MT) & Driveline 3 07-05-2011 11:35 AM
Heavy vibration under braking cdvma Brakes, Steering & Suspension 57 09-17-2006 02:32 PM
Vibration under acceleration vinceGC8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-22-2005 04:26 AM
Rattling under acceleration... possibly clutch? mpaone Service & Maintenance 5 05-09-2003 06:17 PM
