Old 09-16-2011, 11:03 AM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
Default OTS Maps Conservative or Aggressive?
I heard different opinions on cobb OTS maps, some say they are safe and conservative, some say they are aggressive. I am using cobb OTS stage 2 and getting 280/290 on wheel and happy with it, is this conservative or aggressive?
What can I get from a protune map?
Let me know your experience.
Thanks.
Sheltonmega is offline   Reply With Quote
Old 09-17-2011, 02:47 PM   #2
NineTwoX
Member#: 232409
2005 9-2x
Brilliant Red
Depending on mods you can pick up anywhere from 10-50hp from a protune. The OTS maps are made safe and generic enough that almost anyone with that model car can run this map and still be safe. Does it leave room for more potential? Of course. If they maxed it out to one specific car that they tuned on, then it may really only be the best tune for that specific car. It may work on others and give them a gain or a loss depending on condition of the car and wear and such. The point is they maps Cobb puts out are as aggressive as they can be without having a great chance of damaging anything. They are completely safe to run for long periods. If you are looking for a protune, they can be had for around $500 from almost any tuner in your area. Agile Auto is in your area, as is PTuning and I think Mach V.
NineTwoX is offline   Reply With Quote
Old 09-18-2011, 09:44 AM   #3
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
also jorge tunes at IAG occassionally in westminister MD.
bluemax189 is offline   Reply With Quote
Old 09-18-2011, 11:03 AM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
torquedperformance.com. best maps ive run. check out 3gwrx.com about erics maps. many people run them with no issues. he will also fine tune any issues should they happen. he has os and accessport maps for sale.
424wrx is offline   Reply With Quote
Old 09-18-2011, 11:14 AM   #5
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Its a shame they dont do anything for 07 and older... They really screwed themselves marketing wise.
2Fast4U1DAY is offline   Reply With Quote
Old 09-18-2011, 11:55 AM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
yeah i hear yah. the guy is a great tuner. everyone has good things to say about his maps that ive read. maybe he custom makes older maps??
Old 09-18-2011, 02:41 PM   #7
Tripintaz
Member#: 245218
2013 STI Limited
OTS maps are on the conservative side in my opinion but rightfully so. I went from Cobb Stage1, to Stage2, to my own custom tune using Access Tuner Race. I definitely have more power than stage 2 by far, but I also have a wideband in the car and used a dyno to measure.
I picked up about 50 awtq and 30 awhp over the Cobb stage 2 OTS map. However, I am also running a FMIC so I can crank up the boost. It's not that Cobb cant make better maps, its just they take the side of reliability. IF you go to a Cobb dyno tune facility for a custom tune they will crank up the power a bit since they can monitor the car and how it responds. That is something they cannot do for mail order products.
If you stick with the stock TMIC you can probably safely pick up the power about 25tq/15hp over the Cobb OTS Stg2 map with a pro tune. I have seen higher gains than this, but the minute the stock TMIC gets heat soaked the car starts pulling timing. You can also get the car to get into boost faster than the Cobb OTS maps. Just keep in mind there is not too much headroom due to the stock TMIC. It sucks.
Tripintaz is offline   Reply With Quote
Old 09-18-2011, 02:49 PM   #8
tablesandchairs
Member#: 294641
Conservative fueling but aggressive in timing for my car.
tablesandchairs is offline   Reply With Quote
Old 09-18-2011, 03:21 PM   #9
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I just wonder why he decided not to touch the 02-07 crowd. One would think that the market would be bigger for those years considering that the 08 and up has a little more power from the factory (stock vs. stock that is). I know if I owned an 02 (after driving my 06 at stock levels) I'd be looking for whatever I could get out of my stock setup to try and make some more power.
Old 09-19-2011, 10:38 AM   #10
Sheltonmega
Member#: 265204
Thanks guys, I am getting a Perrin TMIC and a protune soon hoping to get 300+
Old 09-21-2011, 01:33 PM   #11
FjStix
Member#: 289425
FjStix is offline   Reply With Quote
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 09:01 AM
Protune or OTS maps or Perrin maps questions FlashEngineer AccessPort 0 07-07-2008 12:37 AM
PDX Tuning Protune OTS maps vs. Cobb Stage 2 93 Octane! kinada423 AccessPort 285 12-23-2007 03:07 PM
Stock turbo with sti tmic and protune, or vf34 and OTS map?? scoobtothenoog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 86 02-18-2006 02:39 AM
any cobb 2.5 guys get a pdx custom OTS map yet? anthonyrb98 AccessPort 25 02-15-2006 10:48 PM
