Old 09-17-2011, 03:04 AM   #1
jayeeyee
Member#: 233640
'04 Subaru STi
Default '04 STi Ticking Noise Under Full Boost/WOT
This noise is starting to bother me more and more. It sounds like it's coming from the driver side and ONLY happens past 3000 rpm when it's under full boost/wot and keeps making the noise till I let go. It's a very audible "tick tick tick tick tick tick" like popcorn popping (best comparison I can think of).
If I were to drive it normally past 3000 rpm even with moderate boost the ticking noise doesn't occur. I'm just worried one day I'll blow my motor. I understand the fuel injectors make ticking noises but it doesn't make sense to me that it would get that loud even on full load. It's not the all familiar heatshield noise either since I removed mine.
My mods consist of:
K&N Typhoon Intake
APS BOV 50/50
Invidia Catless Bellmouth DP
Apexi N1 copy Catback
Grimspeed AOS
Cobb AP Stage 2 Tune
Are there anyone who came across this issue and had it resolved? I'm going to check my stock boost solenoid next to see if thats the culprit but then again... I am pretty sure I'm hearing this from the driver side. I might need to sit on the pass. side to see if I can hear it from there too. Any help/insight is greatly appreciate!
Kudos,
Jay
jayeeyee is offline   Reply With Quote
Old 09-17-2011, 03:33 PM   #2
thecleaner691
Member#: 224641
2004 sti
wrb
Could be any number of things....loose timing belt guide or tensioner, bent valve, knock, loose metal or bolt banging against something....you really need to have a Subaru mechanic look at it. We can't diagnose odd noises over the internetz without at least a video with good audio....log your knock parameters with your ap and post.
thecleaner691 is offline   Reply With Quote
Old 02-27-2013, 02:11 AM   #3
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
did you ever figure this out? im having a similar issue, only difference is mine is one loud pop instead of multiple pops, just like you said, mine is only under WOT.
Karlot is offline   Reply With Quote
Old 03-01-2013, 04:33 AM   #4
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
take a video.
Ticking.. means a lot of things.
DHRDAN is offline   Reply With Quote
Ticking noise under acceleration Spore Normally Aspirated Powertrain 2 12-21-2008 12:39 PM
Loud noise from turbo area under full boost chris124816 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-19-2008 06:37 AM
'04 STi, forged pistons, under 28k miles, under 8k miles on new built motor, 373 WHP size18boarder Private Vehicle 'For Sale' Classifieds 50 08-04-2007 11:19 AM
Noise under full wheel lock, anyone know what's wrong with my car ? itachi1314 Vancouver Impreza Club Forum -- VIC 7 07-06-2007 03:22 AM
'04/'05 Turbo gauge, stock reading under full boost? UltimateLurker Newbies & FAQs 18 04-21-2005 09:40 AM
