Old 09-17-2011, 02:41 PM   #1
kgourd
Member#: 141271
2001 2.5 RS
Smile Question on engine swap
Right now I've got a 2001 2.5 RS and I'm planning on doing a JDM V4 STI engine/gearbox swap. The engine comes with ecu and wiring harness, however I've been warned about using the JDM ECU due to the lack of tuning capability, and the loss of the ODB2 Port. I was wondering if anyone could shed some light on to my best course of action. I've been considering buying an 04-05 STI ECU and Harness and splicing the wires onto the existing sensors. I know as well I will need to get an STI rear diff so that the RS one doesn't break on me, and I will need bigger brakes. The swap also comes with front halfshafts, control arms, knuckles, springs and struts. Any insight into my upcoming decision is appreciated.
kgourd is offline   Reply With Quote
Old 09-17-2011, 08:04 PM   #2
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Talk to Rob about chipping the ECU, but generally you are correct, it cannot be tuned via open source. The bigger question is whether the car needs to be OBDII compliant? If it does then you will need to look at other options.
beaviscih is offline   Reply With Quote
Old 09-19-2011, 02:34 AM   #3
kgourd
Member#: 141271
2001 2.5 RS
Default Odb2
Well, becuase of oklahoma laws, It doesn't have to be smog tested or anything, but what I'm mostly after is the tuning ability, if anyone knew if a WRX or an Sti wiring harness and ecu would work with it.
Old 09-20-2011, 08:53 AM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
if thats the case, OBDII is a non issue and I would look at a standalone like the ViPEC, LINKG4 or Haltech. IMHO trying to merge a WRX/STi harness is too much work when you can merge your existing harnesses to the JDM harness and then use the standalone for tuning.
Old 09-22-2011, 07:54 PM   #5
Asianjimmy
Member#: 295386
2003 Impreza wrx
Rally blue
I was thinking about doing an 05 rs to
An 96-00 ej20t swap.
Asianjimmy is offline   Reply With Quote
Old 09-24-2011, 01:34 PM   #6
kgourd
Member#: 141271
2001 2.5 RS
Default Apexi
What do you think about the Apexi FC commander?
Newbie Questions on Engine Swap Brisky Newbies & FAQs 4 05-05-2007 06:56 PM
Question about engine swap PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-10-2005 01:17 PM
some question on engine swap on a GC8 V6 Subaru Conversions 4 05-18-2005 07:32 PM
question on engine swap spacemonkey Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-02-2002 01:33 PM
Stupid but legit question about engine swap Die Civic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-12-2001 12:22 PM
