Old 09-17-2011, 06:45 PM   #1
subbiegal
Member#: 293833
Default With the access port can you....
Can you set your car to anti theft mode with the accessport? b/c that **** just happened to me. then how do you undo it? I went through all the trouble of towing my car from one shop to the next spending over 200 bucks.
subbiegal is offline   Reply With Quote
Old 09-17-2011, 09:18 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
there is an antitheft map that you flash. you would have to enable it though. then reflash your realtime map it think. if you didnt flash it id call cobb cause you have a problem.
424wrx is offline   Reply With Quote
Old 09-17-2011, 11:43 PM   #3
subbiegal
Member#: 293833
ok. so that was the reason why my subaru was disable. solution solved! thanks!
How far can the access port go twigg08wrx AccessPort 6 07-27-2008 11:54 PM
Anybody in NC with 02-03 access port sammyswrxsti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-27-2007 07:15 PM
problem with cobb access port. blur6rider Newbies & FAQs 2 04-17-2007 05:11 PM
2006 WRX with Vf39, STI Tmic, 3" Exhuast with Cobb Access Port Pro Tune by Dyno Flash Dyno Flash Proven Power Bragging 96 12-06-2006 05:00 PM
What Aftermarket intakes work perfectly with Cobb Access Port? essogas AccessPort 34 04-12-2006 03:29 AM
