Old 09-17-2011, 07:18 PM   #1
fantasticfour
Member#: 215453
2000 2.0RSTi
Default WRX catback on swapped GC.
Sorry if this has been covered but I've recently finished my EJ20K swap into a 2000 RS. A friend has been kind enough to donate his stock 2002 WRX catback exhaust. It was about 10" too short so I had a local muffler shop weld me up an extension so it could bolt up to the JDM downpipe/cat.
Now how much power could I be losing using a WRX catback? I didn't want to pass up on the FREE exhaust but will this cause problems later? But if it's negligible, I can live with that.
Also, if I were ever to replace this exhaust, I would have to look for a JDM one correct? Or perform the same mod on a USDM exhaust?
fantasticfour is offline   Reply With Quote
Old 09-17-2011, 07:51 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
if you use a USDM Down Pipe. then any USDM cat back will also fit. the differance is in the down pipe.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 09-17-2011, 07:53 PM   #3
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
You shouldn't notice a power difference with the WRX cat back at this point in the exhaust chain. That said a catless downpipe would be a plus but it sounds like you are set on the JDM DP since you had an extension installed.
beaviscih is offline   Reply With Quote
Old 09-18-2011, 03:13 AM   #4
fantasticfour
Member#: 215453
2000 2.0RSTi
Thanks for the replies guys. My mind did wander though after I read JDM DP. But anyways, yes I wanted to use the JDM downpipe cause that's where the JDM oxygen sensor is.
The USDM sensor pigtail is longer and can bolt into the USDM up-pipe, but I didn't get the up-pipe.
Do USDM aftermarket downpipes have a bung for the oxygen sensor?
Old 09-18-2011, 02:21 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you have to add the O2 bung .. should be cheep i think i paid $12 (with materials) to have one welded on a usdm down pipe
it is slightly more expensive when you move to Stainless but still not terrible
i have had to do it to all three DPs that i have owned
stock wrx turboback on swapped gc? thisisthenewsic Southern California Impreza Club Forum -- SCIC 1 11-14-2008 04:46 AM
Recommend Shop - Mod Wrx catback to fit GC? Reckon Vancouver Impreza Club Forum -- VIC 4 11-14-2005 01:03 PM
Hmmm...mostly stock STi, modded WRX or engine swapped GC? DoinkMobb General Community 25 04-07-2005 02:15 PM
Anyone have a MY02-04 WRX spoiler on their GC? GTBGUY Interior & Exterior Modification 5 03-18-2004 05:17 PM
WRX springs on a GC RS zakats Brakes, Steering & Suspension 0 10-02-2003 11:34 PM
