Old 09-17-2011, 08:36 PM   #1
darkcrave
Member#: 204753
2002 wrx
Default TD05H STI Turbo
I have the TD05 90* inlet
im trying to adjust the wastegate to run some more PSI, can someone explain to me on how to do this?
darkcrave is offline   Reply With Quote
Old 09-17-2011, 10:19 PM   #2
Subbiespeed
Member#: 276493
2005 STI
y not just get a mbc? u can't really adjust the internal one unless u leave it open but then u'd have to get an external
Subbiespeed is offline   Reply With Quote
Old 10-10-2011, 07:58 AM   #3
subieguy87
Member#: 153412
1998 Impreza wrxRS
For real...
subieguy87 is offline   Reply With Quote
Old 10-10-2011, 12:45 PM   #4
gcMatt
Member#: 278426
1995 wrx
black
Ive done this on my 1.8t vw if you adjust the wastegate actuator arm out more you run more boost. I DONT RECCOMEND THIS.
gcMatt is offline   Reply With Quote
Old 10-10-2011, 12:50 PM   #5
Built Industries
Member#: 33839
If you have threads on the actuator, righty tighty lefty loosey.
Make the arm shorter = more boost/ faster response.
Make arm longer = less boost/ slower response.
Built Industries is offline   Reply With Quote
Old 10-10-2011, 06:47 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yup, I shortened it by 4 turns. Helped a lot with faster spool up.
You must have an MBC or EBC to lower the boost in the higher gears/rpms.
Old 10-17-2011, 11:53 AM   #7
da_coolest
Member#: 236388
once i found that the restrictor pill in the vacuum hose that gets connected from the turbo housing to the wastegate was missing. I took a removed one from a friend of mine and replaced it. Then the boost was increased to 20psi. But i think thats not the proper way to do it!
da_coolest is offline   Reply With Quote
Old 10-23-2011, 09:25 PM   #8
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
LOL. It doesnt work like that...
A MBC or EBC will not be able to lower boost below the wastegate given pressure. Boost can only be increased over the wastegate setting. If you want less boost you will need to adjust the wastegate arm back down then use controller to turn it up.
blkgm8 is offline   Reply With Quote
Old 10-23-2011, 09:36 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Sure it does. The wastegate spring pressure isn't that high on these turbos. It would overboost badly with the factory boost control system and the wastegate actuator rod tightened up.
Old 10-25-2011, 02:36 AM   #10
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
No... You may be going about it differently trying to say the same thing but anyone saying you can lower boost pressure... As in lower than the wastegate spring pressure with a boost controller is absolutely giving false information. Period!
The lowest a boost controller will go is down to the wastegate spring setting. Lets say you have an internal or external wastegate that has a 10 psi spring in it. It will open at nothing less than 10psi. You can use a boost controller to turn boost up, but not lower than the 10 psi set by the spring in the wastegate.
Old 10-25-2011, 07:53 AM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
You didn't read the thread before you hit reply.
If you want to tighten up the wastegate actuator rod on one of these EJ20G TD0516G turbos to help it spool up a bit quicker, you need to replace the factory boost control system with either an mbc or an ebc so you have a method to lower the boost at the top end. If you don't it would overboost with the factory control.
Old 10-26-2011, 12:53 AM   #12
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Ok... I am not a fan of debating the way things work with people. I will only chime in to try and help people on here with usefull information based on my many years building and owning many high hp turbo vehicles. That is pretty much why you see newbie beside my name but I actually have been on here for years. I dont have much to say... Rather be driving or wrenching in my spare time.
360... You do sound like you get what I am saying and I think the misunderstanding is that I am talking general wastegate function and the fact that if you tighten the wastegate spring to lets say 12 psi of boost then no boost controller will turn that down because that is the new wastegate spring pressure. That is now your baseline boost setting. You are speaking specifically our boost control as a system. If you look at it as a whole system you have a valid point.
EJ20G TD05H 16G turbo set up slava from goshen Engine/Power/Exhaust 17 10-23-2008 10:58 PM
td05h 20g turbo RichWRX Engine/Power/Exhaust 3 06-08-2008 12:24 AM
WTB: Stock TD05h 16g Turbo Eatoniashoprat Private 'Wanted' Classifieds 6 01-04-2008 12:04 PM
TD05H 20G Turbo DTSTI Engine/Power/Exhaust 40 03-20-2007 03:12 PM
WTB: 20G TD06h or TD05h 7cm turbo ASAP!!!!! Cstmboxermotorsports Private 'Wanted' Classifieds 1 03-20-2007 12:20 AM
