Old 09-17-2011, 10:03 PM   #1
Kitty93
Member#: 260210
Default No ignition power?
I drive a 93 wrx.
I sent my ECU away for a robs tune. And I pulled my dash and replaced my heater core.
I don't have signal lights, fog lights and I'm not getting fuel. I'm thinking that I'm not getting power to my ignition.
Does anybody have an under dash wiring diagram, or anything to help! Pictures or anything!
I've been with my car for a month now? Maybe someone knows where the power is given to the ecu?
Thanks!
Kitty93 is offline   Reply With Quote
Old 09-17-2011, 10:17 PM   #2
Subbiespeed
Member#: 276493
2005 STI
yeah i have a 94 wrx in my rs and the solid yellow wire controls the relay to my fuel pump and the coil packs and i think it controls the signal for my standalone but i can't remember anyway this site should help u
http://techinfo.subaru.com/index.html
Subbiespeed is offline   Reply With Quote
Old 09-18-2011, 04:39 PM   #3
cmyles
Member#: 275572
2007 Built STi
Without an ECU you shouldn't ?
cmyles is offline   Reply With Quote
Old 09-18-2011, 04:44 PM   #4
Subbiespeed
Member#: 276493
2005 STI
Well i would awesome he got it back before he would post this
Old 09-18-2011, 04:53 PM   #5
cmyles
Member#: 275572
2007 Built STi
Ohh, well if so, if the chip was in the wrong way, it won't show check engine light or oil light, and wont start. happened when i installed my chip.
I popped it out carefully and put it in the other way. Fired up like a charm.
Old 09-18-2011, 05:54 PM   #6
Kitty93
Member#: 260210
Yeah I have my ecu in. I tried flipping the chip around. A relay flicks on and off, and every time it clicks the cel goes on and off and the oil light too.
Really really frustrated right now!.
Old 09-18-2011, 06:07 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Mine did exactly that when my ecu took a crap. I had to put the chip in a spare ecu I had.
But check and be sure you plugged everything back in first and put all the ground wires back on and all the fuses are good. Then check your powers and grounds at the ecu.
Old 09-19-2011, 01:29 AM   #8
pmugabi
Member#: 280926
Your problem sounds like a loose pin on the ECU chip, or a corrupt chip (I once had a chip that was working suddenly get corrupted as I was driving the car, it only ever happened once, but it's a possibility).
Reconnect resistor J1 on the ECU to at least verify that the ECU is fine (this disables the chip). If the car starts successfully, disconnect the resistor and use a multimeter to test each leg of the socket for proper connection to the board/no short circuits between pins. If these are fine, then the next possibility is to swap chips.
pmugabi is offline   Reply With Quote
Defi Gauge Install Ignition Power Question Jard Mid Atlantic Impreza Club -- MAIC 43 06-17-2006 06:17 PM
ignition power flankgent Electrical & Lighting 12 02-01-2006 10:16 AM
05 sti + 05 utec = no ignition. help! T_Rex Engine Management & Tuning 5 09-21-2005 01:26 PM
Electrical problem, no ignition, HELP! InfiniteMotorsports Electrical & Lighting 2 05-27-2005 10:10 PM
Ignition power question Daveish Engine Management & Tuning 2 05-10-2004 12:53 PM
