Old 09-17-2011, 10:32 PM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default all G's wired for 5th injector?
Trying to sort out a complete cobble job harness for myself, and I discovered that on plug b4, pin 2, it is the power for the RA 5th injector.. All diagrams but the FSM had that pin as not having a wire..
just wanted to see what anyone thought
eg33GC is offline   Reply With Quote
Old 09-18-2011, 12:23 AM   #2
pmugabi
Member#: 280926
Plug B4? That does not seem to be in the FSM. It lists plug B43 and B44.
However since the stock ECU is not in any way able to control the 5th injector, it doesn't matter much if you leave it disconnected.
pmugabi is offline   Reply With Quote
Old 09-19-2011, 11:21 PM   #3
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Yes it should be wired up to B4. In the RA wiring, the ECU control wire went to a relay, then to the injector. As Paul mentioned, it was wired but not used on the factory ECUs.
rob is offline   Reply With Quote
Instructions needed - Wiring for helix injectors? dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 01-25-2008 04:58 PM
5th injector or wrx injectors for turbo rougeben83 Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-08-2006 05:59 PM
5th injector, how to trigger? reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 20 02-18-2006 01:31 PM
Power wire for injectors ? zaidallas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-18-2005 01:49 PM
need help wire colors for fuel injectors aftermathWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-26-2005 09:37 PM
